Washing machine belt
What does the washing machine belt do?
  • 213 Answers
Allows the motor to turn the transmission and on some models allows the motor to turn the transmission and drain pump
Posted on Nov 28, 2007
SOURCE:
Whats tricky about the remover and replacement?
How to Replace a Washing Machine Belt: 12 Steps (with ...
www.wikihow.com > ... > Washing Machines and Dryers
wikiHowLearning how to replace a washing machine belt can be tricky, but will save you from.... specifics of the location and method for removing and replacing the drive belt. ...your washing machine, then your model has what is called a direct drive.
How to Clean a Washing Machine Inlet Screen ' The Family ...
www.familyhandyman.com/...repair/washer...repair/...washing-machine...
A washing machine that takes forever to fill may have an inlet screen clogged with mineral deposits and tiny ... How to Repair a Leaking Washing Machine ... The onlytricky part is removing the screens without wrecking them (Photo 1).
Speed Queen & Amana Washing Machine Repair Manual ...
www.appliancerepair.net/washing-machine-repair-8.html
Online washing machine repair manual CHAPTER 8 - written ESPECIALLY for do-it-yourself ... Belt driven pumps are replaced by simply removing the pump mounts. Tension ... Pump or belt changing on a direct drive machine is a little trickier.
How to Remove Mold and Mildew from Front-Load Washing ...
www.todayshomeowner.com/how-to-remove-mold-and-mildew-from-fr...
Jan 10, 2016 | Washing Machines
My Defy DAW 365 washing machine goes through the whole washing cycle but it just won't spin. It does drain between the washing cycles.
If the poly-vee drive belt in your washing machine has snapped, the motor will no longer be able to turn the drum. The drive belt is an important component of any washing machine as it drives the motion of the unit where the clothes are washed and spun. If your washing machine is making a loud noise or no longer spins, then the belt is probably worn or damaged.
Oct 23, 2015 | Washing Machines
Maytag washeing machine, Below belts, are they available in Saudi arabia
The belts in a Maytag washer
www.do-it-yourself-washing-machine-and-dryer-repair-help.com/belts-...
To check and replace the belts in your Maytag washer do the following ... With RepairClinic's 365 Days return policy you could try any parts, if the new part ... Belt Kit - Part # 402507 Mfg Part # 12112425 · Motor Mount Spring Kit - Part ... Copyrighted 2011 Do-it-yourself-washing-machine-and-dryer-repair-help.com All rights ...
Sep 13, 2015 | Maytag Washing Machines
I can't find supra washing machine SW5C18 belt in UAE. BELT NO 1333 J6
MODEL NO SW5C18
Jan 23, 2015 | Supra Washing Machines
Candy washing machine grand go f 662 stops mid cycle and the cold wash light flashes and the softener isnt used
Hello.
Washing machines, like any other mechanical device, occasionally needs servicing. A common problem with an older washing machine is that the spinner, or agitator, drain,or stops rotating during wash cycles. Fortunately, most washing machine problems are easy to troubleshoot. Any do-it-your selfer can fix it; here's how.
TOOLS NEEDE TO SOLVE PROBLEM ARE BELOW.
Bucket and rags,Screwdriver,
New drive belt (if necessary),
New drive motor (if necessary).
1 Unplug the washing machine, and turn off the water supply to the machine. If necessary, remove the water hoses from the back of the washing machine because they may be in the way of the access panel.
2 Check that the agitator is seated correctly by opening the lid of the washing machine. If it's loose, pop off the top of the agitator--if there is one--and tighten the bolt that holds the agitator in place. Or, in some models, simply pull straight up and then reset the agitator.
3 Remove the access panel located in the back of the washing machine by unscrewing the screws holding it in place. This allows access to the drive motor.
4 Press on the drive belt that works the agitator. If the belt moves more than 3/4 inch, tighten the belt to fix the spinner problem. If the belt is worn or cracked, replace the belt.
5 Replace the drive motor, if tightening or replacing the drive belt doesn't fix the agitator. Purchase a new drive motor at a wholesale retailer. Disconnect wiring, remove screws holding motor in place and insert new motor. Screw into place, and connect wiring.
6 Check for any black substance leaking under the washing machine. This might indicate a clutch problem, if the washing machine spinner is not working. Contact a professional repairman to replace the clutch.
Thanks.
Nov 08, 2011 | Washing Machines
Washer makes a buzzing noise when it tries to spin
Hello. Loud noises coming from a Washing Machines are most often caused by looseobjects inside the unit or by a broken dryer belt. The Washing Machines beltallows the dryer's motor to run smoothly. Continuous wear and dry conditionsmay cause the belt to dry out, eventually Washing Machines cracking and thensnapping. This will cause a loud noise within the unit. Repair and fix thedryer belt of a Washing Machines to get rid of loud noises. Instructions And Things You'll Needed to solve the problem.
Screwdriver ,Replacement Washing Machines belt 1 Stop the Washing Machines and look inside the dryer's drum for any looseobjects such as coins, pens or anything else that may have been in a pocket ofclothing. Remove the object and restart the dyer to determine if the noise hasstopped.
2 Unplug the Washing Machines from the wall outlet to disconnect all power tothe unit. 3 Remove the lint trap from the lint compartment on the top of the dryer. 4 Remove the screws that hold the top panel in place. Pull the panel off toaccess the
dryer belt.
5 Tilt the dryer forward and lift the dryer drum to remove the belt. Check theWashing Machines belt. A belt that is worn, cracked, split or broken will causeloud noises. 6 Slide the old belt off of the drum and pull it out to remove it. Take noteon how it is positioned over the drum.
7 Install the new belt. Lean the front panel away from the Washing Machines andslip the new belt over the drum. Locate the position of the old belt and slipthe new belt following the old belt's position ensuring the grooved side of thebelt faces down. Push the idler pulley towards the motor to allow you to slipand loop the belt around the motor pulley.
8 Place the top panel on the Washing Machines and screw it in place.
9 Open the Washing Machines door and use your hand to rotate the drumcounterclockwise a few turns to ensure the belt is secured.
10 Plug the Washing Machines into the wall unit and begin use . Thanks.
Sep 13, 2011 | GE Energy Star WCVH6260F Front Load Washer
Hi i have a speedqueen awm373w-3062 have noise on
Hello.
Loud noises coming from a Washing Machines are most often caused by loose objects inside the unit or by a broken dryer belt. The Washing Machines belt allows the dryer's motor to run smoothly. Continuous wear and dry conditions may cause the belt to dry out, eventually Washing Machines cracking and then snapping. This will cause a loud noise within the unit. Repair and fix the dryer belt of a Washing Machines to get rid of loud noises.
1 Stop the Washing Machines and look inside the dryer's drum for any loose objects such as coins, pens or anything else that may have been in a pocket of clothing. Remove the object and restart the dyer to determine if the noise has stopped.
2 Unplug the Washing Machines from the wall outlet to disconnect all power to the unit.
4 Remove the screws that hold the top panel in place. Pull the panel off to access the
dryer belt.
5 Tilt the dryer forward and lift the dryer drum to remove the belt. Check the Washing Machines belt. A belt that is worn, cracked, split or broken will cause loud noises.
6 Slide the old belt off of the drum and pull it out to remove it. Take note on how it is positioned over the drum.
7 Install the new belt. Lean the front panel away from the Washing Machines and slip the new belt over the drum. Locate the position of the old belt and slip the new belt following the old belt's position ensuring the grooved side of the belt faces down. Push the idler pulley towards the motor to allow you to slip and loop the belt around the motor pulley.
9 Open the Washing Machines door and use your hand to rotate the drum counterclockwise a few turns to ensure the belt is secured.
Aug 02, 2011 | Washing Machines
I need to replace the belt on my Miele washing machine. Can you tell me how to do it?
Open the washing machine's back access panel.Depending on the make and model of your washing machine,you may need a screwdriver to unscrew the screws that hold the panel up.Locate the washing machine's drive belt.It will be in clear view,detach the old drive belt.Use the screwdriver to unscrew the pump coupling.Then gently slide the old belt off of the drive belt notch.If the belt is broken,be careful not to leave any pieces in the washing machine's interior. Slide the new washing machine drive belt over the drive belt pulley in the machine.Carefully stretch the belt up and over the second pulley before releasing.Use the screwdriver to re-attach the pump coupling.Test the drive belt's tension.If it is looser,tighten the pulleys to increase the belt's tension.Replace the access panel and resume using your washing machine.
Aug 27, 2009 | Miele Washing Machines
How to change a washing machine belt
Unplug machine. Remove back panel. loosen three nuts holding motor clutch assembley from bottom side of motor mounting plate with deep well socket, allowing motor mounting plate to slide. Remove clamp holding flexible drive coupler just above belt. Remove belt. Reverse to install, but remember to give a little tension to the belt by holding motor toward the back left corner while tightening up nuts. Tighten the nut closest to the center of the machine first.
Jul 09, 2009 | Washing Machines
Kenmore washing machine
the belt is slipping if this model still has belts.
lean/tilt it back and look under for belts.
its the belt in the center
Feb 29, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
22 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
