Question about Sony FD Trinitron WEGA KV-32FS100 32" TV
Channel numbers scrolling
When I recently turned on the set, the channel numbers show in the top right corner and continuously scroll from 99 to 0. The channel does not change, it's just the numbers displayed in the upper right scroll non-stop from 99 to zero. The words Auto-Sap are displayed as well. The remote is inoperative and teh front panel controls do not work properly. If I push the Menu button it will start the channels changing downwards, until I repeatedly push the menu button stopping on channel 3. Once it stops on channel 3 and acquires the main signal it will stay there, but the numbers in the upper right continue to display and count-down. Thanks for any help.
Joe
  • levyk Dec 31, 2007
    I have a 36" Sony Trinitron. Sequential numbers (0-99) continue to scoll indefinitely in the upper right-hand corner and the front panel buttons (Menu, Channel, Display) and remote no longer funtion. Volume is only accessible manually, but all manual buttons have the impact of advancing the channel by one.
    The tv is hooked up to TIVO and once the television is on channel 3, all non-remote television operations can be completed without problem through the TIVO remote. Volume and Power are the 2 remote functions that continue to be impaired.
  • 179 Answers
The tac switches have gone bad.this happens from age or sometimes from washing the screen of the set and moisture gets on the.. it is not a big job but it does involve soldering skills
Posted on Nov 28, 2007
SOURCE:
The volume of sony wega kv-sw29m61 set always to maximum when it turned on
On your remote control (with tv off)
1. press Display, channel 5, Volume Up and then Power
this brings up the service mode (you will see some green text on your screen)
2. Press channel 2 to scroll through options until you see "Micro" in the upper left of your screen
(channel 2 cycles up through the options, channel 5 cycles down)
3. Press channel 1 to scroll through suboptions until you see "DIOF" appear under "Micro"
(channel 1 cycles up through the suboptions, channel 4 cycles down)
4. Press channel six until the default value (12:60) changes to 12:40
(channel 3 increases the value, channel 6 decreases the value)
5. Once the value has been changed to 12:40, press Muting and you should see red text in the upper right hand corner that says "Write"
6. Simply turn the power off and back on for the change to take effect. Your volume problems should now be fixed.
Jan 16, 2010 | Televison & Video
Have a Samsung LE19R86BD which is stuck in DTV mode showing channel 303 303 ( showing 303 twice) Prior to this I could only scroll down to channel 32 then it woudn't let me scroll down any further. This...
Solved the `stuck in DTV mode' by pressing 01 numbers on the remote. This freed the problem.
Still cannot get scroll to pass channel 32 though!
Nov 22, 2009 | Televison & Video
No user manual for CE28DN9-B. Bought TVonics
HELLO
Follow these instructions:
Select a spare channel on your TV say 6 on your remote.
Press MENU.
Scroll down and select PRESET.
Using RIGHT button of F/OK/ENTER press it and this will go to TUNING.
Press RIGHT button again which will let you go to SEMI or AUTO tuning (for your purpose select "SEMI").
Scroll DOWN to highlight the actual UHF channel number or CH:C21 as it may appear on the screen.
Press the RIGHT button again yourself manually and you will see the channel number change anywhere from 21 to 69 until you come to your freeview box's RF channel output.
When you have done that scroll down to Memory and you'll see a box beside it. Press the RIGHT button and a tick will appear in the box.
You have stored your Freeview box RF channel on your TV.
Press MENU button THREE time to come out of the MENU setting.
Use this procedure again if you wish to change the RF channel on your TVONICS box.
GOOD LUCK (:-)
Oct 03, 2009 | Televison & Video
IN HDMI MODE MY PLASMA TURNS OFF WHEN I SWITCH FROM HD CHANNELS TO REGULAR CHANNELS
OK, Great ! I have the same box. What you do is press MENU on the remote. Scroll down with arrow keys and goto SETTINGS and press select. Scroll down to VIDEO SETTINGS and press enter. Press the right arrow key to go into VIDEO FORMAT. Make sure you have 1080i selected if you haven't had it selected already. Click continue and not your box will output only 1080i. Now, one more thing. While still in VIDEO SETTINGS, scroll down to SD OVERRIDE. Press the right arrow key and make sure you have this setting turned OFF. Press Menu few times to exit out. Now, your Motorola box will only output 1080i and will upconvert SD channels to 1080i. To test this, just simply switch from and HD channel to a SD channel and your TV should stated 1080i on both stations. You TV will not have to switch between resolutions. Hope this helps...
Mar 14, 2009 | Televison & Video
Talk about frequency change
To change channel & code press talk and monitor while turning radio on. Radio will speak current channel. Release both talk and monitor. Press talk to change to next channel or press monitor to keep current channel. Press monitor when desired channel is selected, radio will speak current code. Press talk to change to next code or press monitor to keep current code. Press talk to change code as desired then press monitor when done. Will speak channel and code selected. Set all units in same manner to communicate.
Oct 15, 2008 | Motorola Talkabout T5800 (22 Channels)...
Change channel lineup
1.) Press the TiVo button on the remote (at the top)
2.) Scroll down to "Messages & Settings" and press 'Select' on remote
3.) Scroll down to "Settings" and press 'Select'
4.) Scroll down to "Channels" and press 'Select'
5.) Press 'Select' on "Channel List"
6.) Pressing the "ENTER" button on remote will let you change Channel Line-Up
Aug 28, 2008 | Tivo Series2 TCD649080 Video Recorder
Changing channels with XM radio
Push the button just to the right of present number 1 and this switches the setting between scan and scroll while in XM mode.
Jul 02, 2008 | Alpine CDA-9883 CD Player
Rca model p61960 projection tv dead
More likely a bad flyback transformer......T.
Mar 24, 2008 | RCA P52960 52" Rear Projection Television
PIONEER DEH P 5450
turn it off press the time display button located in top left corner then time will display,then pres and hold top right corner button until 12:00 flashes first the 12 will use your channel buttons on right side to scroll up the the time then when you get the correct time set press the clock display button again in top left corner of face plate!merry christmas!!!
Dec 12, 2007 | Car Audio & Video
Manual
What you want to do is set your radio to the proper S.A.M.E. (Specific Area Message Encoding) code for your county. You will find this information on the NOAA website which can be found at www.weather.gov/nwr/indexnw.htm. Find your state and it will list S.A.M.E. numbers by county.
Setting the code:
1. Push the CNTY/CH button on your radio. 4th button from the top /2nd up from bottom. This will prompt you to set the county.
2. Push the SET button. Button at bottom right. This will prompt the screen to show a set of 6 numbers flashing with the first number.
3. Under the screen you will see a set of 5 numbers and a 5+ with its corresponding button underneath. Use these for setting the code. For numbers above 5 use the 5+ button (e.g. 7 = 5+2). You will be able to set your radio for 10 different S.A.M.E. if needed. To do this you scroll through each S.A.M.E. number by pushing the CNTY/CH button.
4. After you set the S.A.M.E. number, push SET again to prompt you for the proper channel. The channels are A - G. You will want to have your radio on for this to be able to find the clearest channel. Turn your radio on and push the NOAA button under the screen. Push the CNTY/CH button till you get prompted for the SET CHANNEL. Push the SET button and the channel will blink. To scroll through use the TUN- OR TUN+ buttons and find the clearest channel.
You should be all set! Hope this was helpful.
Feb 04, 2007 | Jensen SRWS-1000 AM/FM/Weather Radio
Sony FD Trinitron WEGA KV-32FS100 32" TV Logo
142 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
