Question about Microsoft Xbox 360 Console
3 red lights.
Does the blanket thing work??
  • toniisss Nov 28, 2007
    Does the blanket trick work?
  • 30 Answers
I would not reccommend that you try it, as it does not work usuaully, in rare cases when it does it does not completely fix your console. Hope this was helpful, what is your problem? If it is the three red lights. i wouold get in touch with microsoft as they have extended their warranty to three years for the three red lights problem, and they will either repair or replace your console.
Good Luck
Mick (please rate if helpful)
Posted on Nov 28, 2007
Sunbeam blanket blinking 2days now frustrated please help me
Despite what Sunbeam instructions say, washing an electric blanket can shorten its life.
Jun 23, 2017 | Cozy Heating & Cooling
Why does the light keep flashing red on my sunbeam electric blanket control remote? It just keeps flashing on high I try ed unplugging from the outline and the blanket nothing works. It started doing this...
There is a problem with the blanket. Since it started doing this just after washing (as per instructions), I suspect that somehow - running it thru the washer caused the problem.
Since it is an electrical device, if allowing to air dry thoroughly doesn't let it work as expected, you should stop powering it - and use it only as a non-powered blanket or discard and replace.
Feb 03, 2015 | Miscellaneous
What does the light flashing on a sunbeam electric blamket controller mean and why wont the blanket heat up
The flashing red light is designed to notify you in the event that
a problem has been discovered by flashing the light on the base unit.
Before resetting the unit. First, check the blanket/mattress
pad for visual damage.
If no visual damage is found, unplug the system from wall outlet.
Check that the base unit is well connected to the module. Plug the power cord into the wall outlet. Set the base unit to "On." If the system still does not operate after two or three times trying to reset, disconnect the power cord and get it checked out by a specialist!
Nov 02, 2014 | Home
The output(w) is indicating o.oo and it's indicator light is red .I only have a couple of floor model fans plugged. Should it be showing something and should the light be green?
inverters run on a square voltage unlike normal 110 runs on a round voltage, the only 2 things that won't run on the inverter is fans and electric blankets
Jul 22, 2011 | Cobra 2500w Power Inverter
I bought a Sunbeam electric blanket in december and only used it for about 3 months until it stopped working. i have done nothing that would cause this to occur and after searching online found that this...
The only thing you can do, other than pull all the wire out to test it, is check the temperature control. If you have another you know works or can borrow one to test the blanket, that's the easiest. Else, you will need to use a "Glow Stick". A Glow Stick is an electrical tester that does not require physical contact with a bear conductor to detect voltage. They are available at Hard Ware stores, Menard's, Home Depot, etc. Plug the blanket controller into the wall outlet and touch the 2 wires near the thermostat. If it glows, the cord is good and the outlet has power. Now test the wires coming out of the thermostat that go to the blanket. Turn the thermostat way up and down and see if the light glows. If no, the thermostat is bad. If it glows, indicating power has made it through the thermostat, continue to test along those wires to the blanket. If you have power at the plug on the blanket, continue onto the blanket along the wires that provide the heat. The light will continue to glow on-till you get to the break in the line. When the light goes out, that's the break point. If you do find a break in the blanket and would like me to walk through the repair, I will be happy to. The Glow Stick is a good investment for safely testing anything electrical without the risk of being shocked. Please rate this for me. I am new to the site and need to improve on writing what I am thinking. Let me know how it goes for you, OK?
Apr 02, 2011 | Heating & Cooling
Red and green light flashing and wont work
Apr 27, 2009 | Washing Machines
Sunbeam Electric Blanket Model 972 A5 Type 692 (or 592) with temperature control 1 to 9 with 75 mins and 12 hrs and off control positions. The light blinks red and the blanket won't heat up. Please...
Did you get helped last year? If so please ignore. Otherwise....
Hi. You can locate a Sunbeam Service Centre via
You're looking at $69,95 recommended retail.
BTW have you checked that it's not the blanket? Swap the controls over, if the problem follows the control it's the control. If the problem stays on the same side of the blanket, it's the blanket.
Also note Sunbeam has a 3 year warranty on electric blankets. If Date Of Purchase is less than 3 years ago call 1800025059 option 1 to speak to their Customer Service,
Apr 08, 2009 | Sunbeam 4237 / 4238 Iron with Auto...
Dreamland electric blanket not heating
Yes we had an electric duvet from this company and it stopped working. Was replaced very kindly and no fuss by John Lewis and the same thing happened. (They had said they wouldn't replace again) . Spoke to the company but the woman was very rude. Said that if we lived in a rural area that was our tough luck basically. (A power surge or something). I don't think that's acceptable but we have given up on it now. I think there are 'known' issues with these products that are beingswept under the carpet.
Dec 17, 2008 | Heating & Cooling
My Sunbeam electric blanket controls blink when I plug the control cable into the blanket. I cannot turn the controls on or off.
Same problem, but now it is ok.  I emailed Sunbeam and was told that if my blanket was not plugged directly into a wall outlet it was not getting enough power and I needed to plug it into a wall outlet taking these steps:
1) Unplug from the surge protector/extension cord 2) Unplug from the blanket 3) Plug back into the blanket 4) Plug into a wall outlet
Jul 21, 2008 | Heating & Cooling
Microsoft Xbox 360 Console Logo
32 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
