Question about Brother HL 1240 Printer
Black smudges in printing (Brother HL1240 )
I have a Brother HL 1240. When I print every time, the first page comes out almost black, it gets better from second page on, but there are still black smudges. Is there any way to fix my drum.
I had the same problem at work, what i did is clean the Drum unit corona wire with paper towel cause the moving the blue lever alone doesn't clean it properly.
Posted on Nov 12, 2008
    New Friend:
  • 159 Answers
Change the drum
Posted on Sep 06, 2008
How can I get a 600 dpi from my brother 1240 under XP-home? The only driver on brother site is one dated 2001. The print quality is not 600 dpi; maybe 300 at best.
This printer is almost 10 years old. The original drivers are for Windows 3.1, 95/98, or NT 4.0. Not sure how XP is handling it.
When you go to print and get the print window, you should be able to select Properties (or Preferences) and there should be either a Quality tab or an Advanced tab.
This is where you should be able to change the resolution to 600X600.
You are not going to get a newer driver for this because of the age, but you still should be able to get 600 DPI out of it.
Thanks for using Fixya.
Oct 15, 2009 | Brother HL 1240 Printer
Brother HL 1240 - page runs through printer, nothing prints
Did you pull the plastic tape on the new cartridge?
Jun 29, 2009 | Brother HL 1240 Printer
Black smudging on all the page from hl1440-brother
  • Turn off the printer.
  • Take the toner off.
  • Shake the toner for 4-5 times.
  • Install it back.
  • Then try to print.
Thanks, CF
Jun 17, 2009 | Brother HL 1440 Laser Printer
MY brother HL-5140 quits printing,and also has a black vertical line down the page before it quits. After a while, say 30 to 45 minutes, it will start printing again. But there are black smudges on the...
Sounds like a fusing error ... If your able to wipe the toner off the page its a fuser unit problem (replace fuser unit) If toner is sticking to paper but the print quality is poor , replace the drum unit  (PCU)  good luck
Feb 21, 2009 | Brother HL 5140 Laser Printer
Skidmarks on the printout
Time to think about replacing the image drum unit. Excess toner is not being cleaned off properly and is winding up on your printed pages. The drum unit is separate from the toner cartridge, and you normally replace the toner cartridges several times before needing a drum. Replacements are available from many online sources and at office supply stores. Generic replacements run around $50 and the original part is around $100.
Feb 18, 2009 | Brother HL 1240 Printer
Printing black smudges across the page at 10 cm intervals
Most likely cause by the drum unit. Replace drum or upgrade printer.
Jan 24, 2009 | Brother HL 1030 Laser Printer
Printing correctly on legal size paper
You can get the users manual from
Sep 04, 2008 | Brother HL 1240 Printer
No 600 DPI with Vista
Bonjour, réponse en français je suis pas bon en anglais je mettrai une traduction en anglais juste après, donc la solution est d'installer manuellement le driver de la HL 1250 de Vista cela fera fonctionner la HL 1240 mais avec les 600 dpi (pour information la 1250 est à 1200 dpi mais bridée à 600 dpi sous vista)
Vincent De Lémos (
Hello, response in French I am not good in English I will put a translation in English immediately following, therefore the solution is to install manuellement to drive it HL 1250 of Vista that will do to work the HL 1240 but with the 600 dpi (for information the 1250 is at 1200 dpi but bridled to 600 dpi under vista)
Vincent De Lémos (
Jun 29, 2008 | Brother HL 1240 Printer
Brother HL 1240 Printer Logo
737 people viewed this question
James Cagle
James Cagle
Jim Keysor
