Motorola SURFboard® SB5101 Cable Modem
Problem for Motorola SURFboard® SB5101 Cable Modem
This is my modem log any ideas for a solution to my random DC's
By hordedo on Aug 09, 2009
Time Priority Code Description 1970-01-01 00:01:15 3-Critical D001.0 DHCP FAILED - Discover sent, no offer received 1970-01-01 00:00:56 3-Critical R004.0 Received Response to Broadcast Maintenance Request, But no Unicast Maintenance o 1970-01-01 00:00:24 3-Critical R005.0 Started Unicast Maintenance Ranging - No Response received - T3 time-out 1970-01-01 00:00:08 3-Critical R002.0 No Ranging Response received - T3 time-out (US 3) 1970-01-01 00:00:07 6-Notice M571.1 Ethernet link up - ready to pass packets 1970-01-01 00:00:17 3-Critical D001.0 DHCP FAILED - Discover sent, no offer received 1970-01-01 00:00:15 6-Notice M571.1 Ethernet link up - ready to pass packets 1970-01-01 00:00:03 6-Notice M571.4 Ethernet link dormant - not currently active 1970-01-01 00:00:21 3-Critical D001.0 DHCP FAILED - Discover sent, no offer received 1970-01-01 00:00:02 6-Notice M571.1 Ethernet link up - ready to pass packets 2009-08-07 11:17:58 3-Critical R005.0 Started Unicast Maintenance Ranging - No Response received - T3 time-out 1970-01-01 00:01:15 3-Critical D001.0 DHCP FAILED - Discover sent, no offer received 1970-01-01 00:00:55 3-Critical R004.0 Received Response to Broadcast Maintenance Request, But no Unicast Maintenance o 1970-01-01 00:00:23 3-Critical R005.0 Started Unicast Maintenance Ranging - No Response received - T3 time-out 1970-01-01 00:00:12 6-Notice M571.1 Ethernet link up - ready to pass packets 1970-01-01 00:00:12 3-Critical R005.0 Started Unicast Maintenance Ranging - No Response received - T3 time-out 1970-01-01 00:00:06 3-Critical R002.0 No Ranging Response received - T3 time-out (US 2) 1970-01-01 00:00:02 6-Notice M571.4 Ethernet link dormant - not currently active 2009-08-04 21:23:11 6-Notice M571.1 Ethernet link up - ready to pass packets 2009-08-04 21:23:03 6-Notice M571.4 Ethernet link dormant - not currently active 2009-08-02 16:48:18 6-Notice M571.1 Ethernet link up - ready to pass packets 2009-08-02 16:47:56 6-Notice M571.4 Ethernet link dormant - not currently active 1970-01-01 00:00:25 3-Critical D001.0 DHCP FAILED - Discover sent, no offer received 1970-01-01 00:00:04 6-Notice M571.1 Ethernet link up - ready to pass packets
Comments:
Aug 09, 2009
- Downstream Value Frequency 567000000 Hz Signal To Noise Ratio 34.1 dB Power Level -15.0 dBmV
The Downstream Power Level reading is a snapshot taken at the time this page was requested. Please Reload/Refresh this Page for a new reading
Upstream Value Channel ID 1 Frequency 30600000 Hz Power 54.0 dBmV
Solution #1
posted on Aug 09, 2009
Not Rated)
dbucyk
Rank: Wiz
Rating: 84%, 84 votes
The router actually has major issues. First, check the power cord to make sure that it's operating in the right voltage.
If it is, then through the command line type tracert followed by a website. If there is no response from the first address, then it will not detect the router.
If this happens, change the router.
Was this helpful?
Yes
No
Popular Solutions for Motorola SURFboard® SB5101
Questions and Unsolved Problems for Motorola SURFboard® SB5101
Do you recommend Motorola SURFboard® SB5101 Cable Modem?
Answer
Answer
My internet modem from COX only has one ethernet plug and i dont know where to plug the ethernet... (More)
Answer
modem is off line. Comcast can't get it to connect. When it is hooked up my ip address starts with... (More)
Answer
motorola cable modem sb5101 the receive light blink an the same as the send light
Answer
power come on receive come on but not the othere light don't come on
Answer
I need a circuit diagram for my Motorola SurfBoard SB5101. Specifically, I need an alternate... (More)
Describe your Modems problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Modem Experts
Top Computer & Laptop Repairmen
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
