Question about Singer 7442 Mechanical Sewing Machine
Singer machine 7442
I've been having a problem with the auto tension, and my machine is not even 6 months old! The thread breaks when I pull the fabric away from machine after sewing. Very frustrating! Any suggestions?
Are you making sure that the needle is in the up position when you pull on the thread.
If not you will break the thread for sure.
Good luck
Posted on Nov 28, 2007
My singer 8500q keeps coming up with a 06 error (top thread breaking) buts it's not breaking. Also now has a tension problem that won't adjust. Any suggestions?
Other manufacturers call this the Thread Out Sensor. You don't need it as you're watching the machine all the time anyway.
Take it in for a Service and have them unplug that sensor.
Mar 08, 2015 | Singer Sewing Machines
Singer - 241-12, bobbin thread not stitching
I have a 241-12 Singer. New to me. It was running great. Then the bobbin thread ran out. Put in one prewound bobbin that came with it, even though the bobbin appeared different. The bobbin thread didn't feed and the machine jammed up. I finally wound the old bobbin and put it in. It will only feed about 6" of thread before the bobbin thread breaks. It becomes so tight I can't get it to feed. Both bobbins will not feed. However I don't believe it's the bobbin tension because thread will pull through fine when pulled manually (if it hasn't been in the machine yet). What am I doing wrong?
Sep 15, 2013 | Singer Sewing Machines
Need a manual for Singer sewing machine, model number 7442...need to know how to thread needle
You can download a manual for free from the Singer website, link is
just copy this link into your browser window and give it time to download as its a large pdf file. Once open on your screen, you can click the "clipboard" icon to save the file to somewhere on your PC. Then print it out and either bind up or put pages into a display book so its easy to flip through and stays with the machine.
Just remember to always thread up the top thread with the pressure foot up - this opens up the tension device so the thread can seat it correctly and is something often missed.
Also, use a new needle for each new sewing project, ie about 4-6 sewing hours change the needle and throw out the old one. A blunt needle is often the cause of bad stitching.
All sewing machines, whatever the make, will have similar key parts that are critical to threading up. These will be thread spool holder, the top thread tension device, thread take up lever, a couple of thread guides, the needle bar and needle. Thread in order from the spool down to the needle as per the threading diagram in your manual, ensuring you get the the thread into each thread guide fully, then thread the needle from front to back.
Place the wound bobbin into the bobbin case, it should rotate anticlockwise when you pull the thread tail. Now place the bobbin case into the machine using the latch, and it should lock into place when you let go the latch.
Now hold the top thread tail, wind the balance wheel (big one on the side of the machine) towards you to lower the needle through one stitch sequence so that the needle goes down then back up, now pull the top tail and the bobbin thread should be caught and pulled up to the top of the needle plate. Always hold both threads at the back of the needle plate as you start a new seam to ensure the threads don't get pulled down into the bobbin case/rotary hook area.
Nov 02, 2011 | Singer 7442 Mechanical Sewing Machine
When i start sewing my top thread bunches and you can hear a clinking as the thread wraps the bobbin case. Is this tension? It is set at auto. and standard thread setting.
just a guess, but when mine would do that, it was because I had put the bobbin in the case up-side-down. Try flipping the bobbin over in the the case and see if that helps.
Jul 30, 2011 | Singer 7442 Mechanical Sewing Machine
My singer curvy 8780 has a timing issue the needle is scraping on the bobbin casement and will not sew,cleaned and oiled, changed needle turned off and on. any suggestions?
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Jun 06, 2011 | Singer Curvy 8770 Electronic Sewing...
I have a singer simple 3116 sewing machine and it stitches loose upper threads. I?ve tried adjusting the tension, re threading, flipping the bobbin around, and even different fabric. But nothing seems to...
Insert a new needle, (flat side facing rear of machine), now totally rethread. Try this, with presser foot up, pull top thread, it should pull smoothly, now lower presser foot, the thread should barely move. This should seat the thread in the tension discs. If that doesn't work, call Singer at 1-800-4singer.
Dec 27, 2010 | Singer 3116 Simple
Thread is bunching up and pulling fabric into feed dogs. also breaking top thread. i have cleaned and oiled,adjusted stitch length,changed needle, re-threaded, and adjusted tension. i should note i am a...
If the thread bunches up on the bottom sometimes it is the bobbin tension. You can remove the bobbin housing and may notice a screw. This screw "tensions" the tab where the thread goes through, creating tension on the thread. Another thing to check if the machine is on a "loose/stretch" stitch setting, this will allow the elastic to freely expand and contract. You may need to also adjust the "speed" of the feed teeth, to compensate for the slack. Often there is "stray thread" in or around the bobbin, which can cause problems, One of these may be the solution, Im being general in my information.
Mar 21, 2010 | Singer 7442 Mechanical Sewing Machine
Singer touch n sew 750 winding bobbins
You can find Singer bobbin winding instructions at
"Birdnesting" occurs when there is no tension on the needle thread to pull the bobbin thread. This is easily corrected by rethreading the machine, following the threading path carefully and making sure the thread is fully engaged in the tension mechanism.
Jun 21, 2009 | Singer 7442 Mechanical Sewing Machine
Singer 7442 will not sew
Had the same problem as mommyb2 - it was the bobbin spindel was in the wrong position. Push bobbin spindel to the left and it works for sewing.
Have the same problem winding my first bobbin - pushed spindel to the right to engage bobbin fuction and the machine locks up and wont wind the bobbin. Irig did you bring it in for repair? I'm thinking its broke - which **** as mine is a brand new machine
Mar 23, 2008 | Singer 7442 Mechanical Sewing Machine
Singer 7442 Mechanical Sewing Machine Logo
91 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
