Question about Denon AVR-1905 Receiver
Denon avr-1905 I have the 1905 Denon & about a month ago  it started to switch back & forth from Dig To analog. This was annoying because every time it did that the sound goes off. Well I turned it off for a couple days then back on & it worked fine for about 2 weeks & started it again. No it just stays in Analog & cuts off. This happens even when I listen to the radio. Is this unit dieing? is it worth having it fixed?
  • Ellhead Sep 12, 2008
    i have the same problem as koma74. the unitis useless. i have done everything i can think of to fix it. gone through all the settings tried different connections even tried just using it as a pre-amp. i have descovered that sometimes just wacking it a few times on the top fixes it. if it doesnt help its the good old unplug and wait a few hours. briliant when your in the middle of watching a film. not good denon!
    Problem Solver:
  • 5 Answers
Yes...and no it's not worth saving,,,,don't ever buy another Denon....! Worst Warranty, Worst Tech Support!!!! Cheap units...
Posted on Aug 25, 2008
We have a DENON L.C twin transformer amplifier PMA-735R that has an input selector that freaks out now and again. Recently it has gotten worse, it just goes back and forth between tuner and cd etc. for...
Hi Readers to of Fixya,
This entry is January 22, 2016.
I own a Denon PMA 735R which I bought new in 1999, it is very good Amp; starting about a few years ago the input selector would occasionally randomly jump from CD to Phono to Tape etc., but would always end up back at CD so it was not terribly annoying until a few days ago when it started happening all the time. I am a very knowledgeable electronics person (I built musical keyboards at one time) so my thought was just that it was a dust problem and I started with that premise. I fixed it using an Electrical Parts Cleaner spray and here is how I did it:
I unplugged it, removed the CD input RCA cables and removed the L & R speaker cables and took it off its shelf and set it on a towel on my soft sofa; I removed the casing by unscrewing four big silver screws on the sides (my model is silver) and the three small black screws on the back top; I removed the Input Selector indicator knob on the front and the Record Out Selector indicator knob and the Volume knob, I then removed the small nut that holds the three of them tightly in place to the front panel; I then stood it on its back so that the front was facing up; I then sprayed my Electrical Parts Cleaner spray into the Input Selector indicator post liberally and then put the knob back in place and kept turning the indicator back and forth for a few minutes to work the cleaner inside the post down into the circuit board connection; I did the same with the Record Out Selector indicator post and I did the same with the Volume post; I then put the small nuts back on the three posts and tightened them; I then put the knobs back on the three posts; I then stood it back on its normal upright position and put the casing back on and then the screws; I placed back on its shelf and hooked up the cables and switched it back on and played my CD's, it has been working perfectly fine. The whole process took less than 30 minutes.I hope this helps.
Feb 20, 2012 | Denon Audio Players & Recorders
I have a Denon 2800 hooked up to a Pioneer DV-C302D and while DVD's thru the Denon, the sound will come on and off. At the same time the Denon will be switching between analog and digital mode. Is one of...
It's a cable or connection.
The Denon apparently has an automatic selector to choose the digital input over the analog input if both are present (my Pioneer does this). The random switching is telling you the digital input is intermittently dropping out and coming back. You don't say if you're using the optical or coaxial digital interface. Coaxial is less prone to connection problems. If you use optical, make sure the ends are clicked in and there are no small radius bends in the cable. Tight curves reduce the optical power. Either way, check the connections and wiggle them to see if you can cause the problem to return.
Jan 18, 2010 | Denon AVR-2800 Receiver
My Denon AVR-788 receiver switches off by itself after it has
If you've changed it's location or added speakers, or placed anything on top of it since the problem started then consider that it may just be over heating.
Dec 19, 2009 | Audio Players & Recorders
We have a Denon AVR 1905/785 We cannot turn the volume down.... it is at -70 and full blast... the volume turns up and gets even louder.... but can't turn the surround sound down... help
if the volume control as been forced the conection in the switch as jammed +vol .this is usually a small preset under the knob the right hand one.pull the knob off pulling straight as not to bend spindle some time's the two presets are visable.a cotton bud dipped in spirits could solve your problem but some times you need to pull the top of the preset .it might need removing and replacing . this could be a more complicated problem caused by a variety of things here are a few,dry joints,cracked pannel .hope some of this helped . if in dire straits skype me farr64
Apr 27, 2009 | Denon AVR-1905 Receiver
Hi again,
Any new developments?
May 25, 2008 | Denon AVR-1905 Receiver
No sound on cable TV for Denon AVR 1905 Receiver
Audio setup on the TV, needs to be swited to Fixed or both, this is usually the same on all T.V.s....
Jan 20, 2008 | Denon AVR-1905 Receiver
How to hook up xbox to denon avr1905?
I've hooked up an xbox to the front aux jacks with no problems. you can change the device to use the aux through the selector knob.
Jan 06, 2008 | Denon AVR-1905 Receiver
Denon AVR-1905 Receiver Logo
176 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
