2001 Volkswagen Passat Logo
Posted on Aug 09, 2009
2003 Volkswagen Passat Center Rear Belt Locked
Nice to know it's not an isolated incident. Same problem with this ridiculous design...the belt locks and won't allow the seat to be folded back. Some Fiat forums have discussed the same problem as well. Check out http://www.fiatforum.com/stilo/96010-rear-middle-seat-belt-stuck.html maybe it will shed some light...
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Sep 03, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
705
Points
The fix is:
  • remove the seat bench,
  • unscrew the bolt attaching the seat belt to the body,
  • return the seat back to its upright position and make sure it latches
  • reattach the seat belt
  • replace the seat bench
To prevent this from happening again:
  • Leave the seat belt latch in its receiver when not in use.
Passat serpentine belt diagram v6
Here's a link to your belt,put wrench on bolt a tensioner,turn to take tension off,then remove belt,need 2 people to do this. 2000 Volkswagen Passat Serpentine Belt Routing and Timing Belt Diagrams
2answers
I own a 1999 VOlkswagen Passat. Just 15 minutes ago, my power steering locked up, battery light came on, temperature gauge went to the far right (hot) AND I have no heat. I'm sure they're all...
chances are there is 1 belt that runs all of the componets and the belt has either came off or broke replace it and you should be good to go.
7helpful
2003 volkswagon passat v5, looking for diagram fro the serpintine belt?
The serpentine belt routing diagram for 2003 VW Passat V5 2.3 liter
CS = Crankshaft
F = Fan pulley
Gen = Alternator
G = Guide pulley
T = Tensioner pulley
AC = Air Conditioning
PAS = Power Assisted Steering
1helpful
I have 2003 Passat with 140K on the clock, 8 months ago it developed a screeching noise turning the wheel left and right when stationary like the belt was screeching. The garage could not see a problem,...
the screeching noise could be rubber deposits on the belt pulley or pulley bearings for the power steering pump BUT its also a big clue that the timing belt tensioner is about to give up...CHECK BOTH please.....
Have to replace the timing belt on my 2003 vw passat and would like a belt diagram
Hopefully you mean a sepentine belt and not the timing belt. There is a diagram under the hood for the serpentine belt. Look on the radiator shroud or close to it. The timing belt requires a great deal of engine disassembly and probably is more that most home mechanics can handle.
05 VW Passat - work-around rear hatch always being locked?
A VW dealership can change the programming for you with a VAG-COM device.
2answers
Alternator warning light displayed 2003 1.9 tdi
check belt for slipping or broken belt tensioner.
2helpful
2answers
2005 volkswagon passat tdi belt replacement
you need to remove front bumper , remove front into service position , remove aux belts set timing marks up ( you will need to use locking tools ) lock crank and cam shaft remove belt replace belt and tensioners . please note it is also use full to check water pump
Belt configuration 2003 v6 3.0 VW Passat
go to google and type the year ( 2003 3.0(vw passat belt diagram ) i hope this works for you
Timing Belt 2003 Volkswagon Passat V6 30V
i would like to advice you not to do this job, the person who is doing this work must have more knowlage about mechanical mainy must know how is the timing belt fitted,
timing belt is not like altaranator belt.
find a good mechanic,
if you are intersting to do like this job easy go technical schools, .
Top Volkswagen Experts
ZJ Limited
ZJ Limited
Bradley
Bradley
Thomas Perkins
Thomas Perkins
Are you a Volkswagen Expert? Answer questions, earn points and help others
