Question about Samsung SyncMaster 920NW Monitor
Samsung monitor top half of the screen is faded
    Sergeant:
    Champion:
  • 225 Answers
Good morning! please review the operations manual of the unit for its proper set-up settings. probably, there is a defective part of the unit which should be replaced, try to bring the unit to its authorized service center. best regards.
Posted on May 02, 2009
2 Suggested Answers
  • 84 Answers
SOURCE: samsung syncmaster 920nw LCD uppar half not clear
I think this is not the problem with the monitor. Pl replace a VGA Card or Express AGP Card and try.
Posted on Aug 23, 2009
POLAROID P40LCD12 SCREEN AT BOTTOM COMES ON BLUE FADES THEN GOES GREEN ABOUT 5 INCHES LOST ON BOTTOM TV WORKS OK BUT THE SCREENS STARTS BLUE ABOUT 5 INCHES FROM BOTTOM THAT FADES AND TOP HALF PIC OK BUT...
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
May 02, 2017 | Polaroid Televison & Video
Picture flickering and faded on left had side of the screen
if rebooting the monitor would do no good, try to get a spare monitor cable if the same flickering issue took effect. If it is so, then call your pc provider to repair your monitor..
Nov 26, 2011 | Philips 47 in. LCD HDTV
Lcd have line, but the half is ok, the half is fade.
your LCD screen was damaged, it only can fix by change the LCD screen with new one
Feb 06, 2011 | Acer AL1916W 19" LCD Monitor
On half the screen the colors are faded. when a video is watched on the faded half the colors are really bad
Often problems with LCD monitors can be traced to bad capacitors. The following sites will help you identify if your monitor has bad capacitors, and how to replace them.
www.fixyourmonitor.com and http://www.youtube.com/watch?v=9Q6_TgNJvQw
Good Luck!
May 26, 2010 | ViewSonic VP230mb 23.1" LCD Monitor
Monitor turns on for about a minute then screen fades to a half lit and then goes dark. if you turn it off even for a split second it comes back on and then repeats. This monitor has had less than 20 hours...
If it is left plugged into the wall, the power supply is always running 24/7 even the power switch is OFF.
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
http://www.badcaps.net
http://en.wikipedia.org/wiki/Capacitor_plague
Apr 03, 2010 | Samsung SyncMaster 216BW Monitor
Dim lcd screen samsung 732n
sorry its a defective unit
Oct 20, 2009 | Samsung 732N 17" Monitor
Hi, I just purchased a 22inch 2233BW samsung monitor, the label on top "Syncmaster 2233" and right side "50000:1" is a little faded out, is this normal or it means it was used and repackaged? also the top...
I would return it for a New Model.
Ask to see a display model.
The unit should also have a build date on the tag as well.
Its your money. spend it your way. !
Sep 30, 2009 | Samsung SyncMaster 2233BW 22" LCD Monitor
I have a 204b moniter that the lower half of the screen faded to black then shows two half screens that are filled with so many vert lines that you can't see whats on the screen.
the screen is toast. if its black and not showing whats suppose to be on the other half.if you tried restarting the computer and unplugging the monitor and it is still happening then there is nothing to do. monitors are not built to last long, the cheap ones. it is good to get one with a good warranty because the pixels go out.
Sep 29, 2009 | Samsung Computers & Internet
Samsung syncmaster 920nw LCD uppar half not clear
Aug 23, 2009 | Computers & Internet
Samsung SyncMaster 920NW Monitor Logo
177 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
