Question about Husqvarna Designer I
Obtaining actual sewing and embroidery hours on machine
Hi, does anyone know (absent of taking this machine into the shop) how to obtain the actual hours on my machine?
Any help much appreciated!
To find out the running time of your Des. 1 machine; Switch on machine touch 'SET' on the screen then press ' More' 3 times and you will see' Running time' hours and minutes.
Posted on Dec 23, 2007
    Novelist:
  • 196 Answers
Dupina is correct, go ask your dealer to check it for you.
Garneta, the "Running Time" in Set Menu 4 only lists the hours since it was last reset. The button next to the time display will zero the counter. A dealer can tell you how long the machine has been on, sewn on, and embroidered on ,to the minute, with the circuit board that is currently in the machine. If the main circuit board has been replaced, these numbers will not be accurate.
Posted on Jan 13, 2008
    Scholar:
  • 110 Answers
Good day to you.
The only way to check your working hours, is through your dealer. He uses special software to download the info. You can ask your dealer to do it free of charge. I am a Husqvarna dealer.
Posted on Nov 28, 2007
SOURCE:
Where can I go for sewing classes in Kempton Park
Type of classes formal/ informal Sewing classes and ******** Beginners/advanced/quilting/embroidery Beginners/Advanced Duration (hours/days/weeks/months) hours/days/weeks/months Teacher or school name Marie Odendaal Town or City KEMPTON PARK. email address/WEBSITE [email protected] Phone number Register for new sewing classes Kempton Express
Feb 04, 2018 | Sewing Machines
My machine does not recognize that the embroidery unit is attached. It keeps saying attach embroidery unit. Has anyone had this problem
What make and model of sewing machine do you have? I have seen this problem with a Husqvarna Viking Designer I (or similar older Viking machine). In that case, the problem was corrosion on the contacts between the embroidery unit and the sewing machine. The solution was to use an electronic contact cleaner to clean the contacts; this is one product: http://www.amazon.com/CRC-05101-QD-Electronic-Cleaner/dp/B000CCMLD0 . Make sure that the machine is unplugged. Spray the contact cleaner on the contacts. (In some cases, you should then connect the embroidery unit to the machine and remove it a few times.) Allow the product to dry before you plug in the sewing machine again.
In another case, the solution was actually easier. The owner had two similar embroidery machines. She managed to mix up which embroidery unit went with which sewing machine. Neither embroidery unit could be properly seated on the machine that she attempting to use it with. Once the embroidery unit was paired with the correct machine, both pairs worked.
I hope this helps.
Aug 03, 2015 | Sewing Machines
Cant embroider on toyota quiltmaster 50
The Quiltmaster 50 can only do free-hand embroidery. Use the darning foot. Set the machine for a satin stitch with a stitch length of 0 and lower the feed dogs. Manually move the hoop to stitch your design. (Trace the design on the fabric and place on a stabilizer if needed. Center the design in an embroidery hoop and move the hoop under the needle. In my limited experience, all fabrics need stabilizers. Some require multiple sheets of stabilizer.)
Personally, I have trouble moving any fabric under the pressure foot. This is mostly a matter of practice. You have to make a lot of scrap piece trials.
This site has the manual for the Quiltmaster 50 (European version): http://www.home-sewing.com/WebRoot/Store/Shops/homesewing/4AAF/95FA/5ED9/1505/56BA/4D44/240A/754B/QUILT50_0020_EFNI_0020__0020_679111-CEA10.pdf . See page 37 (49 of the PDF).
I hope this helps.
(who actually cheats: I either use an embroidery sewing machine or I use a late 1960s Singer Sewing machine with its Monogramming accessory. This has pre-programmed designs on little discs. That's why I don't practice free-hand stitching.)
Jun 15, 2012 | Sewing Machines
Embroidery machine is making grinding noise and carriage doesn't move. Then, screen says malfuntion, turn machine off.
Just because the hoop holder has been moved during transportation. Shut down the machine, manually bring hoop holder in central position in both X and Y, it will restart.
Apr 20, 2012 | Brother PE770 Computerized Sewing Machine
I have singer 2259. i dont know how the machine automatically threads the needle. I also want to know can i do embroidery with this machine, if so, how?
You do not have an embroidery machine, or an automatic threader. This is a basic sewing machine, you can free style embroider by covering the feed dogs and, using an embroidery hoop plus the darning foot but you don't have an embroidery attachment per se. Read your manual, if you do not have one go to www.singerco.com and download a free copy under customer support and save it to your computer. Embroidery machines usually start at $600 and up. $600 is a very basic one. If, you want one take that machine back and buy one from a place that gives lessons on it, (check out JoAnn's and private shops). You will enjoy it more if you know what all of the features are.
Jan 03, 2011 | Singer 2259 Sewing Machine
Pe-150 embroidery power cord
Two places you can check. The first is Ron at a1sewingmachine.com or Wendy at [email protected]
Aug 24, 2009 | Brother PE-150V Computerized Sewing...
Viking designer se limited
You can find this information by touching the configuration icon (this looks like pliers). The item that shows you how many sewing hours is called Timer. You should know that this can be reset to 0 by anyone.
Dec 22, 2008 | Husqvarna Viking 1
Obtaining a manual for Euro Pro 9125 sewing machine
I have the same machine. Mail me your address and I will copy the manual and mail it to you. [email protected]
Nov 21, 2008 | Euro-Pro 9125 Computerized Sewing Machine
Sewing Machines Logo
481 people viewed this question
Top Husqvarna Sewing Machines Experts
radcal
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
