Question about Hitachi 55HDM71 55 in. HD-Ready Plasma Television
Vertical red line on 55 hitachi plazma
I have a 2yr old plasma with very little use and when i turn it on for the first ten minutes it's crystal clear. Once it's warm it develops a red vertical about 12 inches long. I've shut down viewing for fear of burn in. Is this fixable? It seems like it would be because the first ten minutes it looks great. If you can let me know what my options are I would be very appreciative.
The vertical line, in my case, was due to a bad contact on the flexible printed circuit. I fixed the problem by using a piece of a rubber eraser to apply downward pressure on the flexible circuit as shown in the picture. To locate the faulty section lightly push on the flexible circuit from lef to right untill the line dissapears.
Posted on Dec 02, 2007
Lg55lv4400-va 55" flatscreen tv ( not a plazma) has developed a wide flickering vertical flickering stripe down the screen. Has been fine . Goes away once in a while. An Ideas what is wrong ?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Nov 03, 2014 | Televison & Video
Have red vertical lines in center of screen from top to bottom
iam also facing same problum,that problum wont start immedietly,when we r watching after 1 hr it will start
Oct 21, 2012 | Hitachi 42HDS69 42 in. Plasma Television
Random 3'' vertical red line on 42'' Hitachi Plasma TV
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.////
Sep 04, 2017 | Hitachi 42HDS69 42 in. Plasma Television
Vertical lines on screen
1. Frist on the BURN MODE.
2. Check whether same
Vertical lines on screen ?? 3. If yes ..?
4. Then change the LOGIC BOARD or PDP
Jan 11, 2009 | Hitachi 42HDS69 42 in. Plasma Television
Red box half way down screen
I am getting re or blue lines running vertically on my Tv. They are not there all the time just now and then. Can I fix it with my remote or do I need a tech?
Jun 16, 2008 | Hitachi 55HDS69 55 in. Plasma Television
Red vertical Line on 55" Hitachi plasma
check the MAIN -Y- SUSTAIN BOARD i believe that your problem is there
good luck
caypianan@yahoo.com
Mar 16, 2008 | Hitachi 55HDM71 55 in. HD-Ready Plasma...
Black vetical line
It's either x-main or logic board... Take it to a qualified shop and I think you'll be impressed... Most of these are repaired at module level now and it makes the repair relatively inexpensive.
Bill
Nov 19, 2007 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
My tv is hitachi 55pd plasma
have a tech check your tv the vertical module needs to be replaced.good luck
Apr 18, 2007 | Hitachi 55HDT51 55 in. HD-Ready Plasma...
Vertical, pencil-thin blue line appears after 10 minutes of viewing (any source)
I would suspect a connection breaking down as the set heats up. A shop will probably have to put the set in a stand to hold it while they check for loose connections or defective components inside. Not a DIY job by any means. If this line went completely through the picture either vertically or horizontally and stayed there then this would have indicated a failure in the Panel itself. A thin Line any where on the screen consisting of one pixel in width is a Panel Failure according to Hitachi.
Jan 01, 2007 | Hitachi 55HDT51 55 in. HD-Ready Plasma...
Hitachi 55HDM71 55 in. HD-Ready Plasma Television Logo
479 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
