Question about Toshiba Satellite A60 Notebook
Toshiba satellite pro A60
Hard drive completeley gone. Cannot enter bios to reformat, recovery disk will not work and can undertake any drive fitness tests. If I replace the HDD is there a maximum capacity of HDD that I can put in the machine
No - have just put 120gig in my sons & its running at 5400rpm - slightly worse battery life -but much quicker !
Posted on Nov 28, 2007
Toshiba Satellite Pro 4600 laptop - which Keys to reinstall all windows after a formated hard drive error?
Do you have the Recovery Disks? I hope so because if you reformatted the drive you wiped out the Recovery Partition.
Apr 25, 2012 | Computers & Internet
How to unlock toshiba satellite laptop BIOS and HDD
If you are the original owner Toshiba will reset the bios for a fee and it is not cheap, they may include the HDD reset, if not! type password, or hard drive password. I would check bios password, probably a lot cheaper if you can find the right seller, also check some software may be free.
Mar 21, 2012 | Toshiba Satellite L455D-S5976 Notebook
How do I remove the hard drive in Toshiba SatellitePro A10 EN? (Removing the plastic cover exposes only the end of the hard drive. I'm reluctant to just start pulling on it!
  • The original Toshiba Satellite Pro A10 HDD is fitted into a Toshiba Satellite Pro A10 Hard Disk Drive cradle - Toshiba Satellite Pro A10 HDD caddy.
      • Gently remove the cradle from the laptop, yes pull on it
      • Unscrew the original Toshiba Satellite Pro A10 Hard Disk Drive & remove it from the cradle.
      • Screw the new Toshiba Satellite Pro A10 Hard Disk Drive into the cradle & refit the cradle into the laptop.
      • Re-install XP or Vista
          Aug 21, 2010 | Toshiba Satellite A10 Notebook
          Recovery Disc will not load OS on HD
          laptop panasonic toughbook bios password pro
          Apr 07, 2010 | Toshiba Satellite Pro L300 Notebook
          I have toshiba satellite L305d-s5934, Blue screen error appear and hang, when i boot or when i press F2 to enter bios... if i full out the hard disk the computer says: no bootable disk and if i press F2 to...
          Sounds like your HDD may have gone bad. What is the name/number of the blue screen error? Google it and see what it means. It may be possible to reinstall the operating system to the original factory settings using the recovery partition (this is usually accessed by tapping F10 or F11 while booting, although I read somewhere that you might be able to gain access to the Toshiba recovery partition by pressing "0" (zero) while the computer is powering on).
          You can try to recover the computer to factory settings. If your hard drive has enough life left on it, you might be able to then clone it to a new drive. Drive Image XML is a free software that will do this for you (get that from This way, when you clone the drive, you will also clone the recovery partition, so you don't lose that option. Once you have a new hard drive up and running, use the Toshiba Utility to make System Recovery Disks for the future.
          One more thing: If you have recently upgraded/replaced the RAM - this might be your problem. Put the original RAM back in and see if the computer boots. If so, you found the culprit.
          Feb 26, 2010 | Toshiba Satellite L305D-S5881 Notebook
          Toshiba Sattelite Pro
          r u check settings in bios
          for harddrive there its showing or not in bios otherwise first try to configure the harddisk then try for hardware part
          Aug 24, 2008 | Toshiba Satellite A60-S1561 Notebook
          I need to replace my hard disk notebook with a bigger capacity hdd
          Toshiba is rather secretive with their documentation. It is hard to find. Google TOSHIBA SATELLITE A10 SERVICE MANUAL and check the available offerings.
          You now have a 5400 RPM, ATA 100 drive. You should not have any drive size restrictions. Shops are advertising many large drives as compatible.
          I suggest that you purchase only a 7200 RPM drive. The faster speed will perk your machine right up.
          I have not worked on Toshiba machines but suggest you have all restore disks and passwords at hand.
          Feb 18, 2008 | Toshiba Satellite A10 Notebook
          Toshiba A60, Won't Load Windows XP.
          did you try with diferent memory ram may be that is your problem because the memory can not prosses all the data to download windows
          Jan 01, 2008 | Toshiba Satellite A60 Notebook
          Need help for Toshiba Satellite A60
          You have to order replacement disks from Toshiba - probably about $30 for a set.
          If you are getting errors with installing just plain XP, you probably have a hardware problem - Probably a bad hard drive or stick or RAM. Try pulling one stick out (if you have 2) and reinstalling XP.
          You can get hard drive testing software here:
          Get the ISO download on that page. If you need to know how to burn the ISO to CD properly look here:
          Dec 31, 2007 | Toshiba Satellite A60 Notebook
          Toshiba Satellite A60 Notebook Logo
          240 people viewed this question
          Top Toshiba Computers & Internet Experts
          Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
