Question about ASUS ALi Chipset A7A266 (A7A226) Motherboard
Problem posting with agp video cards
Need help getting this board to post
i am using it in a case that has a 350w power supply and am using 256mb 133MHz memory
IBM T23 wont turn on after adding new RAM
Hi - according to memory suppliers your T23 has the following memory capacity / requirements:
  • IBM ThinkPad T23 maximum RAM capacity: 1GB
  • Your IBM has Two (2) memory slots or sockets
  • Module upgrade PIN count is: 144-PIN
  • The memory speed is: SDRAM 133MHz, PC133
  • The laptop DIMM type for the ThinkPad T23 is: SODIMM, SO-DIMM, Small Outline DIMM
  • Non ECC
If you are meeting these requirements, you may have a defective module.
Also, according to Lenovo's page on the machine:
Memory
The system has 128MB or 256MB of memory standard and can be configured for up to 1GB of addressable memory. Memory options up to 512MB SDRAM SO DIMMs each can be added in the two available slots for memory expansion. The standard 128MB of memory is expandable up to 640MB and the 256MB of memory is expandable up to 768 MB of addressable memory with 64, 128, 256, or 512MB SO DIMMs without removing the 128MB SO DIMM that is standard in one of the internal slots for memory. For customers that need the maximum 1GB to which memory can be expanded, it is necessary to replace the 128MB or 256MB card with a 512MB card plus add another 512MB card in the extra slot. Only 133MHz DIMM memory can be used in this system. The use of 100MHz DIMM memory is not supported in the T23 systems.
This means yo can trouble shoot the 512MB modules individually by installing one of the original 128MB modules and one of the new 512MB modules (for a total system memory of 640MB). If it does not boot, try again with the other 512MB module. This will help you identify a defective module that may be preventing the machine from booting.
I hope this helps & good luck!
Sep 28, 2012 | IBM ThinkPad T23 Notebook
MS 6368 VER 5 MEMORY
It takes SD Ram, Which is no longer available. Below is the lonk to the Specs.
Link:
Mar 09, 2012 | Computers & Internet
Hi! I am using nvidia Ge force 6600 256mb AGP graphic card of m/s pny verto which has an additional supplementary power terminal. My mainboard is Intel D865GLC Board. every time when i start my computer i...
Hi Yasir,
As you can see from the image above the molex power from the PSU is connected to the card for additional power. from your post "Where as the power cable is duly connected" like the image?. If you connected the supplementary power, you have to consider the peripherals connected to your desktop and the brand of your power supply.
The link would help you if your power supply wattage is sufficient. Link
If you are using generic power supply, for example a 500 watt power supply the real wattage can be 300-400 watts only.
Using a tru rated supply might fix the problem. try to test a different power supply for your system or try to turn off or remove additional devices that consumes power that might help.
Hopefully this information helped.
Thank you for using FixYa.
Sep 10, 2011 | PNY Verto GeForce 6600, (128 MB) AGP...
Need a replacement power supply for e machine t3092
Hello sbfca, Here are a couple links to power supplies that will work for you: Any of these will work with you factory system. If you have installed a better graphics card or additional drives, you may want to increase the wattage. I have had good experiences with both of these sites and the ratings and reviews for the hardware are very helpful when making your final decision. Post a reply if you need any other assistance with your power supply or please rate this solution if you found it helpful. Thanks! Edward
Aug 23, 2010 | E-Machines T3092 PC Desktop
NO Power up at all, Nothing!
phalitao, you need to check you're power supply it may be bad.
No PC or notebook will boot without memory. However in your case I would recheck all power connections from the power supply to the board. Remove & reseat all power connections.
Please use you're manual help guide you. Also on the back of you're power supply (on most PSU's), there is a Red slide switch. Please make sure it is set to 115v & not 220v. After all this checking & you do not see life from the board, suggest you replace the power supply with a min wattage of 400w. Or borrow a PSU of 350w or better.
Please post back with you're findings.
In order to stay within this post do this.
How to repost more questions for same problem.
Enter FixYa.com site.
Sign in to your FixYa account.
Locate My Profile on our FixYa's homepage.
Under My Problem locate your problem and click on it.
Answer quwstions from you're tech & add more information.
Good Luck!
Mike
Apr 18, 2008 | EliteGroup Intel Pentium 4 Processor...
NEW ULTA V Series 350w power supply .
yes that fan should plug into the 4 pin MOLEX off the PSU.
Hope this helps
Jan 05, 2008 | Computers & Internet
NFORCE3-A Won't post with 2 sticks of 512MB DDR RAM, only if 1 stick used :-(
U cannot use 2 identical DIMMs of RAM Memory, find two same and faster, couse 233 or 300 is too slow for nForce3 motherboard.
Aug 30, 2007 | EliteGroup nForce3-A Motherboard
Red Light on Board
it is better to use the old power supply because it is compatible to your mother board
Feb 11, 2007 | Soltek SL-K8AN2E (SL-K8AN2E-GR)...
ASUS ALi Chipset A7A266 (A7A226) Motherboard Logo
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
