Panasonic CQ-VD6503U Car DVD Player
Problem for Panasonic CQ-VD6503U Car DVD Player
My indash keeps showing a insert disk, and it wont
By jonte_gosby on Aug 09, 2009
my indash keeps showing a insert disk, and it wont open up what do I do?
Comments:
Aug 09, 2009
- my indash keeps showing a insert disk, and it wont open up what do I do?
Aug 10, 2009
Aug 12, 2009
- I did what you told me as far as hitting the eject button and power button at the same time. It work the idash came open and I put a cd in. It was working for a while I put diffrent cds in and everything. Then after one cd was in for a while it wouldnt eject again what do I do? Please help me thanks.
Aug 14, 2009
Solution #1
posted on Aug 09, 2009
Somewhat Helpful)
dnewcombe1
Rank: Guru
Rating: 86%, 455 votes
I'm afraid you'll have to take the unit out for it sounds as though one of the drive belts has either come loose or fallen off entirely. Let me know how you make out. P.S. sometimes there is a very small hole on the front panel try sticking a straigtned out paper clip in about 1/2 inch, it may release the tray manually.
Solution #2
posted on Aug 14, 2009
Not Rated)
hmerchant110
Rank: Guru
Rating: 93%, 278 votes
Press and hold the eject [TILT] button for more than 10 seconds (disc forced ejection).
Hope this solves your problem. If the problem persists, you'll have to reset the unit.
For more help and clarifications, please reply to this post. Thanks
Solution #3
posted on Aug 12, 2009
Somewhat Helpful)
rulds2008
Rank: Guru
Rating: 86%, 1074 votes
This would need to be repaired as the motor is ether stuck or went out completely now if you decide to do the repair yourself be sure to right down any password what I mean by this is the unit will lock you out once its di connect thinking that its being stolen.
My best recommendation is to take it to the dealer if its a dealer system to ensure that you do not lock your self out of the system.
The unit will need to be opened up and probed to see if the motor got stuck or the motor is totaly gone.
Thanks
Rulds2008
Solution #4
posted on Aug 10, 2009
Somewhat Helpful)
taran_2005
Rank: Guru
Rating: 88%, 974 votes
This is a Hardware issue. You need to open the DVD player. Usually, the procedure to remove is simple. Remove the front panel. There might be 3 or 4 screws or clips that you need to remove. In few old models, you need to pull that up and remove the wiring.
Once done, clean all the parts. Make sure there is no broken part.Once you again set up the mechanism, more likely it would be all set.
Note - Run a disk available to clean the lense as well before you open that.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Solution #5
Somewhat Helpful)
ginko
Rank: Guru  Panasonic Expert
Rating: 89%, 5079 votes
Disconnect battery cable for two minutes.
After reconnecting back the cable press repeatedly the eject button while you start the unit at the same time.
Try it twice, if that does not fix the problem, then there is an internal error , and the unit must be taken apart and repaired.
Try to unlock the eject mechanism , and to open the tray first.
Popular Solutions for Panasonic CQ-VD6503U Car DVD
Questions and Unsolved Problems for Panasonic CQ-VD6503U Car DVD
Do you recommend Panasonic CQ-VD6503U Car DVD Player?
Answer
Answer
I have a Panasonic CQ VD6505U I want to know how to activate the Navigation Do I need a disc to... (More)
Answer
it stiil works fine but the screen is distorted,ive noticed that it is worse when the tempeture is... (More)
Answer
cuts off in 10 minutes .. How do u match the wires up to hear the music..
Answer
i need a override code for a panasonic cq-vd6505u
Answer
i unhooked battery and i dont have the security code
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Panasonic CQ-VD6503U Car DVD...:
Top Car Video Player Experts
Rank: Guru Guru
Solutions: 14911
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Car Video Player Experts
Top Audio & Video Equ... Repair
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
