I have an iBook G4, 1.07 gHz, 1.25 gb RAM computer, running os x 10.3.9.
Sometimes the computer is very unresponsive. If I try to type, say into the search box on the firefox browser winder, the computer gets very congested, and it takes several seconds to display what I have typed. If I try to make other changes, like click or move the cursor, visualization of those changes is also delayed.
This problem seems to improve if I restart my computer, and it seems to get worse the longer I keep my computer on or if the battery had been turned off due to a loss of power (my battery connection fails sometimes if I move my computer around).
This problem also improved for a short period of time when I upgraded my RAM to 768 mb to 1.25 gb, but now it is bad again.
I have noticed recently that streaming video is also choppy now. This problem happens constantly: the video is choppy, but the sound is fine...eventually the audio and video become out of sync. I used to be able to stream videos with no quality problems.
Does this sound like a hard drive issue? I have an extra harddrive at home I could put in, but I want to make sure this might be a problem before I go through the effort to swap it out.
How much HD space do you have left? Most macs run best if you keep abou 10gb of HD space free. Furthermore, cut back on excessive app loads (bells and whistles. The ultimate solution is to back up your files and reinstall the mac os. If the problem persists it is possible that the CPU is starting to break down. This is replaceable at significant cost from mac repair shop. Maximizing RAM helps some, but age of the equipment will reduce performance.
Bios stuck on my toshiba L305D-S5934 it not doing nothin when pressing F2 or F12 but CTRL/ALT/DELETE...
(More)
Bios stuck on my toshiba L305D-S5934 it not doing nothin when pressing F2 or F12 but CTRL/ALT/DELETE then it just restarts.. i took out RAM, then computer will not boot up replace ram one at a time bios stucks wont go pass boot screen
I updated my mac software and now i have a continous loop when logging in. it trys to load for like...
(More)
I updated my mac software and now i have a continous loop when logging in. it trys to load for like 2 seconds
Flashing question mark on startup, but ive replaced the hard drive and 2 days later the flashing...
(More)
Flashing question mark on startup, but ive replaced the hard drive and 2 days later the flashing question mark on startup came back, what else could it be?
