Question about Panasonic Palmcorder PV-GS15 Mini DV Digital Camcorder
Palmcorder how do i get my vidios off my palm corder onto the computer without a software
Connect ur recorder to the computer and see what happens!!
If it is thro' USB normally ur stills come. For dumping however u need 1394 connectivity and then ofcourse windows movie maker or studio 8 s/w. After all, computer can't survive without software.
right?
Posted on Jan 08, 2008
SOURCE:
I have a VPW8OU vIDEO CAM CORDER. i AM WONDERING if I can play the tape onto my pc somehow
Tape video recorders are unfortunately old technology. Video sent to a tape is not a fully digital file in the sense that it is not read by computers and has to be captured when you play it back into the computer and turned into a video file. Unless you are savvy with computer connections and software requirements and are able to connect up the camcorder so that it is recognised by the computer AND capture software, the easiest way might be to get someone to put the tapes down onto a dvd for you. Many retailers advertise this service.
Aug 21, 2014 | Video Cameras
I want to put my vidios from my canon powershot camera A520 onto a disc. After reading some of the letters on the pc , not really much wiser but saw solution disc mentioned quite a bit. Does this mean i...
you shald have got a proper program wen you got your camera for your computer so you can download your pics / vidios on to computer then just burn it on to a cd or dvd from the same program
Jul 08, 2011 | Canon PowerShot A520 Digital Camera
I just bought a Palmcorder but dont know how to work it
There should be either a USB Cable or a Analog cable which connects from the cam corder to the PC. Depending on the brand it may need software to copy the clips from the camcorder to the pc, or the connection will create a drive letter from which you can copy the clips from the camcorder to your computer.
Oct 03, 2009 | Panasonic Video Cameras
Hi.. I have a jvc 32 X cam corder that i want to down load my videos onto my computer and am not sure how..
Two things here. Is your cam corder a digital one? If so there should be a connector on it for either firewire or USB, and if not, you will need some kind of video capture device if your cam corder has outputs on it. If not, you will need a player (vhs-c or 8mm or whatever your format) that can send out to the computer. Once this connectivity is done, you need video capture software that will "encode" the video files that will be produced. If your cam corder is already data (hard drive onboard or SCD card recording, you will only have to "demux" the format you have into the format that you are seeking (ie.. MPG to AVI or so on).
I hope that helps you out.. let me know if you need more clarification. It also might help if you give the media you have (VHS-c etc.) and the available outputs that you see on your cam corder. Thanks!
mrstan
Aug 29, 2009 | Video Cameras
Tungsten E problem
Older palm products and vista aren't compatible. You either needs to transfer info via bluetooth or upgrade your palm if you wish to continue using vista.
Feb 14, 2009 | Palm Tungsten E Handheld
I need complete "operation Manual" for Panasonic make "mini-DV" Palmcorder
I have a pv-354d and i cant adjust the tracking, Its old and i got it on line with out a manual
Feb 17, 2008 | Video Cameras
I lost my charger and need to charge tonight.can i charge this with the usb cable and my computer?
i suppose u charge via USB? no need of software but i am not sure usb can handle the power for chrging the cam corder
Feb 05, 2008 | Panasonic Palmcorder PV-GS14 Mini DV...
Transferring vidio from cam-corder to vcr tapes
YOu should have your our from your cam to the input of your vcr and the output of the vcr to the input of the tv... then simply set your vcr to the input channel that your cam is connected to ans it should show up on the tv, if it does not hit the tv/vcr button on the remote ... hit record and our done
Dec 31, 2007 | Sanyo VHR-H607 VHS VCR
Watching video from cam corder on pc or tv
Try using the movie maker in windows or pinnacle studio s/w
Nov 25, 2007 | Panasonic Palmcorder PV-GS15 Mini DV...
Panasonic Palmcorder PV-GS15 Mini DV Digital Camcorder Logo
81 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
