Question about Philips 32PT5441/37 32" TV
Help the tv turned off during a show, then on then off with no picture. now just flashes the on/off lite 3, 2 ,1 times over and over
    Genius:
  • 1,694 Answers
Install horiz driver kit # 483513057673...applies to all L04.01U
chassis.......+ replace 47mf/25v cap in driver circuit.........T.
Posted on Nov 28, 2007
Toshiba 62hm84 dlp
Sounds as though the system may have overheated. Do you regularly check the filters and clean them? An airduster can also help to blow dust out of hard to reach places.
Apr 14, 2014 | Office Equipment & Supplies
I try to turn it on but it just blinks on stand by
Probable Lamp. If lamp hasn't bown the red Lamp Lite won't flash but other lamp issues cause stby timer light to continue flashing. If stby red lite is flashing, count the no. of times flashing - could open thermal fuse (6X flashing)
Nov 27, 2009 | Sony KDF-E42A10 42 in. LCD Television
Sony Trinitron TV. No picture; red standby/timer light flashes.
My Sony trinitron has the stero lite on steady and standby lite flashes four times then pauses and repeats. Can you tell me the circuit/condition causing the set to not turn on.
Jul 15, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
No sound or picture, 2004 pt50dl54j
remove back panel. blow out all the dust from all the components except the fan on the right.
Vacuum out all the dust.
Have you replaced the lamp? that would help too.
There are 2 small red lamp. One indicates HEAT problem. The other one is the LAMP indicator.
Jun 13, 2009 | Panasonic PT-50DL54 50" Rear Projection...
Tv Problem
Sony TVs generate an error code. The front panel LED (red) will flash anywhere from one to eight times which can isolate the problem circuit. It is not always accurate.
If you have a test meter which can read DC voltages and resistance in ohms, you can locate the problem area. If you lack the expertice to do so, contact a sony authorized servicer. If you have the ability, start by checking fuses on the "G" board ( power supply board) and the "D" board or deflection board.
A major problem area in this TV is the convergence circuit. There are six fuses around the convergence output ICs on the "D" board.
If any are open, replaces the output ICs.
Feb 13, 2009 | Sony KP-61HS10 61" Rear Projection...
No sound or pix
3 times flash of standby light shows that Lamp Cover is not mounted properly after replacement of Lamp.
Please fix lamp cover properly because cover has to press protection switch in circuit.
Sep 17, 2008 | Sony Grand WEGA KDF-60WF655 60" Rear...
Sony Wega
Please count light flashing again. Light flash time is "0.3 Sec" and there would be pause (light Off time) for "3 Sec". Start counting after pause to next pause.
May 31, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony tv repair
I own a Sony T.V. model #KV36HS510, Serial # 9024184,Event# E36002407 and it"s aTrinitron brand name. Like the problems before no picture or sound, stand by light on front of unit flashes. When trying to turn it back on you can hear the power click, like it wants to turn on, but does not.
Dec 22, 2007 | Televison & Video
Hot to test tthe lamp bulb Samsung tv
bad lamp will cause 90% of problems you can take it out to see if it is broken filament is usually shattered
Oct 07, 2007 | Samsung HLN617W 61" Rear Projection HDTV
WHY WONT IT COME ON?!?!?!?
If you would like us to help you, you must tell us what brand and model TV you have.
Aug 28, 2007 | Televison & Video
Philips 32PT5441/37 32" TV Logo
80 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
