Refrigerators Logo
Posted on Aug 09, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Buzzing sound there is a buzzing sound that wont stop unless you open the fridge.
Anonymous
Level 2:
  • Expert 69 Answers
  • Posted on Aug 09, 2009
Anonymous
Expert
Level 2:
Answers
69
Questions
0
Helped
71169
Points
374
If noise stops when you open the door, you may have a noisy fan (or could have ice build up, causing fan blade to hit ice and cause noise). I gather it is a frost-free model ie has a fan in the freezer compartment. If noise is caused by fan hitting ice build up, you may have a problem with the auto defrost system, as you should not get ice build up in a frost free.
Noise stops when you open door because fan turns off when door is opened.
  • ramaza ozge
    ramaza ozge Apr 13, 2015
    Little box behind of the ice box at the freezer. Sounds comes from there. Ice stock the fan or something. If you hit couple times, sounds will go away.
  • ramaza ozge
    There is a little box behind of the ice bucket at the freezer. Sound comes from there. If you hit couple times, sounds will go away.
ramaza ozge
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Apr 13, 2015
ramaza ozge
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
904
Points
My ge fridge is suddenly making a loud buzzing/ rattling sound when I open the fridge door. Any idea why?
first thing to check is the light bulb, take the light bulb out and see if noise stops.
Samsung fridge problems
Not much to do, it is normal unless the fridge stops working
Want to stop the buzzing sound when drivers door
you can't unless you job a hole in the little speaker don't cut the wires because you'll have a real headace
Yesterday started hearing a buzzing sound from the fridge. Came home today with a pool of water in the kitchen coming from the fridge. Opened the freezer, ice is melted and inside is relatively warm....
I would check for a bad starter relay first unless you can verify that the sound is comming from the compressor. How to check stuff> http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Buzzing sound clicks on and off from underneath fridge
that would be your relay going bad it will stop the fridge all together change it to a 3 and 1 relay
Buzzing at my cell phone near the flexible
remove the battery... and dont return it so that the buzzing wont come back....
Kenmore dryer wont stop buzzing
The ECU is faulty - or the timer.
Check/replace as needed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Frigidaire Freezer Buzzing
thats not a valid model number open the fridge door and look up at the top by the light bulb on a white sticker and ill try to help ok
Top LG Refrigerators Experts
ZJ Limited
ZJ Limited
Jay Finke
Jay Finke
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
