Question about Stoves Kitchen Ranges
Diassembly of stove
Hi. I own a mid 80's GE stove, model # VJ32YKT-4 and I am just wondering how difficult it is to remove the top portion of the stove that houses the 4 elements so I can clean the outer surface of the oven liner. If you can find time to give me instructions I would much appreciate it.
Thanks you
fridgetech
  • 473 Answers
SOURCE: self cleaning hotpoint stove
Sometimes in self clean it can burn out the element.  Need to check the element with an ohm meter and see if it shows resistance.  If it shows open then the element is bad.  If it shows resistance then the element is ok.  Next see if you are getting 220 volts to the element when in bake mode.  If you are not getting 220 volts then the control is bad.
Posted on Oct 21, 2007
duby1990
  • 370 Answers
SOURCE: ge spectra jbp64, replacement bottom bake element
Take the 2 screws out of the back wall of the oven (inside) holding the element on. Then pull the element out and it will expose the wires and terminals (2). Unplug the 2 wires and plug them on the new element and mount the element back in the oven and your fixed. (make sure to turn the power off to the oven before you start unpluging wires.
Posted on Nov 21, 2008
milten1
  • 1304 Answers
SOURCE: middle section of element on smoothtop stove not working
yes you can
goto appliancepartspros.com
type in your model number
under the section top
you will find your part number...
when it arrives unplug the unit and remove the screws holding the top down under the froont lip
lif the lid and mark where your wires connect, remove the wires, and the two 1/4 scres holding the burner
sometimes 4
switch out the burner, and re plug all your wires
drop the lid and test
Posted on Oct 16, 2009
  • 949 Answers
SOURCE: elements and light in stove work but clock and stove do
The issue would have to be in the clock or the power wire going to the clock.
The clock controls the power to the oven elements and there are no fuses or other devices to control the elements.
Posted on May 21, 2010
SOURCE: GE Medallion 850 oven self-clean instructions
how do i work the oven section i don't understand the settings
Posted on Sep 07, 2010
Hi, I have a wonderful Maytag speckled black smooth top stove. Over Christmas someone caused a big (2 " diameter) stain. I've tried everything to get it out. is it possible to have a new ceramic...
Ceramic cooktop cleaning tips - especially for 2-in difficult-to-remove stain:
Best Idea: "Cerama Bryte" + plastic scrubbie
Cerama Bryte is specifically designed for this cooktop, works on stains, avail at Hardware Stores.
Other ceramic cooktop tips:
1. "Soft Scrub" plasic scrubbie
2. Comet cleanser + sponge
3. Single-edge razor blade held at 45-degree angle - scrapes off material
4. "Cook Top" cleaner (WalMart) + Mr. Clean "Magic Eraser" abrasive pad
5. baking soda on damp sponge
6. soak stain for awhile with Formula 409, Fantastic, or citrus degreaser ("Orange Clean")
7. ammonia + water - in a 1:1 solution
8. Easy Off oven cleaner - it foams on the stain and does the work for you - let it sit 20 min.
9. the nuclear option:
Cerama Bryte under a plastic scrubbie under an orbital sander with sandpaper removed
(just the pad down on top of the scrubbie), after pre-soaking in Citrus Degreaser.
The sander is a power tool which only saves your joints, and speeds up the chore.
Jan 17, 2011 | Maytag MER5775Q Electric Kitchen Range
Hi I love my stove but the cooking grates are difficult to clean. We bought the stove may of 2001. Do they have different ones that are easy to clean. Thanks for your help. Gregg Reutter
Hi, Gregg
Honestly, the grates that came with your GE are the only ones available. The only other solution would be to buy another set.
Please rate me a "4 thumbs" if the information was useful.
Best of luck!
Dec 15, 2010 | GE Profile Spectra JBP95 Electric Kitchen...
I have two burners that don't ignite
FIRST MAKE SURE YOU TURN OFF THE GAS AT THE MAINS , THEN REMOVE THE ALL BUNERS AND GIVE THE TOP PORTION A GOOD CLEAN WITH WARM SOAPY WATER TO EXPOSE THE SCREWS WHEN LOCATED REMOVE THEM AND THE TOP THEN YOU NEED TO FIND THE IGNITE WIRE FOLLOW IT TO ITS SOURCE CHECKING FOR ANY BREAKS AND ALSO CHECK CONNECTIONS . GOOD LUCK .
Nov 17, 2009 | GE Spectra JGBP35 Gas Kitchen Range
We have a GE gas oven/stove top and the stove top is lighting as well as the broiler but we can not get the oven to heat up. What do you suggest we try?
i just moved and our stove in the new place doesnt bake things right. it seems that the top coil doesnt come on. its very difficult to bake anything. seems to come up to temp for pre heating, but only the bottom coil comes on. If you put it on broil, then the top coil gets hot. that works fine. tired of burning pizzas and biscuits. can anyone help with a cheap fix? dont have alot of cash.
Nov 12, 2009 | GE Ovens
Can am Hitachi 50GX49B rear Projection TV be diassembled to move it to an area where narrow stairs prevent the complete unit to be mover through this area? I have noticed that inside there are 3 screws on...
Removing the screen is your best bet -
1 Remove speaker grill
2 remove 4 screws holding the screen frame
3 then lossen the bottom corners where the screen meets the frame by pulling outward (some force is required) and work your way upwards towards the top (two people may be required for support)
4 tilt the loosened frame(20-30degrees) from the bottom up and the top shoul lift and seperate from the frame.
After the screen is of you'll be able to tell what to remove next.
Good Luck!
Sep 21, 2009 | Hitachi 50GX49B 50" Rear Projection...
Oven wont turn on and f7 keeps beeping, but stove top burners work on ge spectra xl44 on model number jgbp86bea3bb
Well, F7 error code occures due to
A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC)
Replace the ERC there are ten screws 3 on each side and 4 on the control leave the hex screws alone all you need is a phillip screwdriver.
REMEMBER TO SHUT OFF THE POWER FIRST lift and fold out the control panel remove the ribbon cable and remove the four screws that hold the control board . replace control panel in reverse order.
Good Luck!!
Have a nice Day!!
Thanks
Mar 07, 2009 | General Electric Stove/Oven/Range Chrome...
Burned Copper Bottom Pot on Glass Stove Top. This left a ''melted'' portion of the pot on the glass. Any ideas on how to remove the melted residue?
sorry to say no , if you try to peal it off or scrape ot off you will crack the cooktop . this keeps happening i have seen it at around 4 times for some reason revere ware melts . there should be a warning in the manual ( i know ge does have the warning about copper bottoms ) . replaceing the cooktop or the whole stove is the only "true" answer .... sorry .....Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob
Mar 02, 2009 | GE Profile JP930 Electric Cooktop
I BOUGHT A GE GLASS TOP STOVE IN FEB. 2008. I WAS WONDERING IF THIS MODEL JBP62DMWW, IF I CAN PRESSURE COOK ON IT. CAN YOU HELP ME? VERNA
yes you can but consult your owners manuel as certian type of cook ware will scratch the top but if your careful and not move the cooker around it wont scratch but the cook top is strong enough to support the cooker
Jul 10, 2008 | GE Kitchen Ranges
We need to replace our cook top. For some reason it cracked in several areas. Model number is jbp68soh2ss. Serial number is zf2107020. The entire top part of the stove will have to be replaced. How can we...
Most appliance repair shops can order the part(s) for you. Replacement isn't difficult as long as you are careful. Just under the top lip (above the oven door) there are screws that hold the front in place. Carefully check the scews to determine which ones need to be removed to release the top.
Jun 04, 2008 | GE Kitchen Ranges
Ge profile electric counter top stove
I did not receive instructions with my G E Profile cook top Model No. 80030750434). There is a build up on the elements which I am having problems removing. Should the top be scraped while the stove is hot or cold? What is the best cleaning product to use?
May 01, 2008 | GE Profile JP930 Electric Cooktop
Kitchen Ranges Logo
32 people viewed this question
Top Stoves Kitchen Ranges Experts
Paul Carew
Oloyede Monsuru
Ned Halaweh
Ned Halaweh
Are you a Stoves Kitchen Range Expert? Answer questions, earn points and help others
