Question about Speed Queen AWS45NW Top Load Washer
Help How do I release a tub fronm the inside of the washer
  • 1 more comment
  • duhgonz Apr 11, 2008
    does not spin after rinse cycle
  • tj61 Jun 01, 2008
    machine stopped and could smell burning rubber. is the belt broken and how do i replace it.
  • rallen535 Oct 22, 2008
    how do you replace the drive belt? I found one that was 1/4 in longer and it barley fits. now the motor will not run in spin cycle and overheats/shuts down. The oringinal belt was 28 3/4, and the new belt is 29 in. Do you think that the motor is damaged?
Changing a drive belt
Posted on Nov 27, 2007
Where is the solution?
Posted on Oct 21, 2008
The washer tub won't come out
These drums ride on bearings. Remove the back cover of the dryer and then remove the cabinet from the frame, tub and motor assembly. Reposition the tub for the bearings and reinstall. time est 30 min.
Jan 12, 2014 | Whirlpool GEQ9800P Electric Dryer
GE Washer Mod# wcsr2090d5ww
It's normal for some water to stand in bottom of outer tub. It shouldn't be visible in the inner tub though.
Oct 31, 2017 | Washing Machines
I have a GE toploader washer. The model # is WBSR1060T (VVSRV1040V, & YVSR1040V were also on the washer too) the washer keeps filling to the max setting no mater what the water level is set on, also...
Remove the front panel of the washer by using a putty knife to release the retaining clips, located in the seam between the front panel and the washer's top, about 2 inches in from each side. With an empty wash tub, remove the small hose on the left side of the outer tub and clean out the inside of the hose. Replace the hose. Test.
Mar 15, 2011 | Washing Machines
Whirlpool washer (model LA9100XTW1)
Usually problems like this, you just have to take it apart and see. I can tell you a few things that will help though. It's not a deteriorating belt. In fact this machine doesn't have a belt at all, it's what is called "direct drive". The closest thing it has to a belt is a round piece of rubber in between a gear but that's near the motor and it's not possible for it to get inside the tub. In fact, it's hard for anything to get in there to stain clothes. Usually what causes this, is a build up of dirt, soap, mud, mold, etc that collects under the agitator and finally just gets enough to start releasing into the tub. It's pretty easy to take out the agitator and check under there, here's how.
To remove the agitator on a Whirlpool top-load washer, remove the solid cap or fabric softener dispense from the middle of the agitator. Then remove the white cap on the inside of the agitator. This might be stubborn, so just start off pulling gently and keep pulling until it comes out. Under that is a 7/16" bolt. Remove that and then the agitator will slide off the transmission shaft.
The only other option is removing the inner tub entirely, but that requires a special tool to get a nut off of the drive block, so that limits DIY repairs.
May 29, 2010 | Whirlpool Washing Machines
We have a GE front load washer WCVH6800. Recently we loaded some throw rugs into the washer. These rugs released a large amount of material. We cleaned the pump filter 3 times and it now seems clean. ...
The water inside the tub will drain out when the pump filter is removed from the pump housing and flood the base of the washer. If not, the tub drain hose is clogged preventing the water to drain into the pump housing then out.
The door is locked because the foam switch in the pressure switch is open due to the presence of water after the unsuccessful drain cycle.
Disconnect the washer from the power outlet. Remove the three screws holding the lower front access panel to the cabinet and pull the panel down to access the pump housing.
Squeeze the clamp that hold the tub drain hose to the pump housing and slide it back. Prepare a pan to catch the water to prevent flooding. The tub drain hose maybe difficult to remove and you may need to insert something under it to break the seal and pull it off.
Remove the tub drain hose from the tub by squeezing the securing clamp and pulling it off the tub drain outlet. Clear the hose and the tub drain outlet from any debris.
Reinstall the tub drain hose and manually unlock the door before reinstalling the access panel. Reach and pull the release ring behind and up the right side of the front panel, then open the door.
Feb 14, 2010 | Dryers
I own a kenmore elite heavy duty plus washer. During operation it stops and a message apears saying ob when you open the lid and close it ob disapears and I restart it and minutes later the timer never...
The OB error code is short for out of balance. There are two fixes that you can try: One is to move the clothing around in the tub. or Two the machine isn't level and is causing it to falsely error as out of balance.
Oct 30, 2009 | Washing Machines
Need repair steps to replace the drum boot seal and how to remove the agitator on WWA8350BAL
This will take some time, so gather up your hand tools and get a cup of coffee...
OK, unplug the washer and turn off the water supply valves to the washer. Now open up the top washer door and pull off the top of the agitator (the fabric softener dispenser on some models). There could be a screw inside holding the agitator onto the transmission shaft, so remove that if present.
To get the agitator to come off the transmission shaft, you might have to rock the bottom edge back and forth, all the way around it, to help loosen it from the tranny shaft. Once you get that off, there might also be a spacer bushing underneath it (a plastic hub looking thing) remove that too.
Once you've go those items off, you can then use a small metal putty knive, about 1 - 1 1/2 inches wide to release the top panel from the cabinet. If you get down and look straight at the front edge of the washer, you'll see two (2) indents where the locking clips are located. Just push in with the putty knive about an inch and it will release. Do this in both places and the top will be able to be lifted up and back exposing the inside of the washer and tub.
Now you can remove the fasteners (screws or hex screws) that are under the hub spacer and that hold the tub onto the transmission. With these removed, you can now lift the wash tub out of the washer cabinet.
Once you've got the tub out, you'll see the wash tub boot. It's held in place with two (2) large diameter hose style clamps. Loosen and remove these with either a 1/2", 5/16" or 3/8" nut driver, (depends on where and when made as to the size that was used).
Once you have the clamps off the boot, you can carefully remove the boot from the outer tub and the transmission body. Once you have the boot off, clean the surfaces of the outer washer tub to remove any gunk that might make the new boot leak. Also, on the transmission side, use the putty knive to carefully scrape around the rim to remove any water deposits that have built up over the years, etc. Get it as clean and free of gunk as possible, again, so the new boot won't leak.
Carfully install the boot around the transmission first and tighten the clamp, now carefully put the boot around the outer tub lip and use your finger along the inside to help get it over the lip. Once it's on, make sure it's lined up and all the way over the outer tub lip and install the clamp. With the clamps, you want them tight, but not so tight that the clamp deforms or the boot gasket gets cut, so go easy and tighten them carefully.
You can now complete the re-installation of the remaining parts and you'll be back in working order in short order. If you wish, before you put all the other parts (tub, hub, agitator, etc.) back in. you can add some cold water to the outer tub to check for leaks, but you should be fine, if you cleaned the surfaces before putting on the new boot gasket.
Here's a link that shows your GE Washer and the parts described. It will help you better understand the repair and lists the parts, in case you need other components, etc. Just click on the "tub, basket, and agitator" link to see the affected parts.!retrieve.pd;jsessionid=qqur5KYuTMdHVEqkYLRyIQ**.shcapp3205?modelNumber=WWA8350BAL&pop=flush
Hope you find this Very Helpful and best regards!
Sep 01, 2009 | GE Washing Machines
The water will stay inside washer tub
Hi, What is the make/model# for this machine?
Did the water come out onto your floor?
I want to help.
Jun 20, 2009 | Washing Machines
Clothes smell on some cycles
You need to clean the tubs.
Unplug the machine.
Remove the agitator top. Remove the screw or plastic sleeve that holds the agitator down. A 1/2 inch socket extension will fit in the plastic sleeve. Pull the agitator out.
Now you will need to remove the nut that holds the inner tub. A spanner wrench is the best way, but you can use a large screwdriver to lossen the nut. Pull the inner tub. If it doesn't release take a hammer and a driving tool aka anything that will reach and not destroy the crown and tap all the way around the crown. If that doesn't release it, get someone to tap while you pull the tub. Be careful not to break the fill tube. I have broken quite a few being in a hurry. Haste makes waste.
Now with the tub pulled, clean the inside of the outer tub and the outside of the inner tub. Reassemble the machine.
FYI, liquid fabric softener and/or using too much detergent will cause the sewage smell. Liquid fabric softener is terrible for your machine. Use dryer sheets if you can adapt to them.
Nov 26, 2008 | Kenmore 23822 Top Load Washer
Bra underwire stuck
disconnect from electricity. take back panel will see heater at bottom of tub held in by 1 10mm nut.disconnect wires to it. loosen this nut and pull heater out - you may have to help it with a screwdriver. you can then see into the gap between tub and drum and fish for the bra wire.
tell her not to wear bras with wires!!
Jul 14, 2008 | Electrolux EW1000i Front Load Washer
Speed Queen AWS45NW Top Load Washer Logo
113 people viewed this question
Top Speed Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you a Speed Washing Machine Expert? Answer questions, earn points and help others
