Question about Pioneer CD Receiver - DEH-P3700MP - CD/MP3 Player 2005 Model
Pioneer DEH-p3700MP Head unit and CD stuck
My Head unit does not seem to be broken...there is a CD that will not come out. When I put the head unit on....the cd just plays and no controls work and no lights on the Head unit.....HELP!!!
I stuck another cd half way in the slot and then pulled it out and this seems to work
Posted on Jan 15, 2008
  • 626 Answers
Had the same problem with a burned CD with a printed label.
I had to press the eject button and help it with some plyers.
Best of Luck.
Posted on Nov 28, 2007
SOURCE:
How to remove my pioneer deh-p3700mp headunit without the keys
You can slide in two flat thin blades or screw driver and push aside the LOCKS that hold the head unit to the frame so as to release the unit from the fittings.
Please do not use force but a simple flat AXE-SAW blade machined to fit into, must solve the issue-
Jul 02, 2011 | Pioneer DEH-P3700MP CD Player
Need the owners manual for Pioneer DEH-P3700MP
I can scan and e-mail any pages you may need.
Nov 01, 2009 | Pioneer DEH-P3700MP CD Player
Hooking sat to car stereo
that plug at the back is not for sat radio. It is for use with steering wheel controls. You have the blue plug at rear of stereo and that is the plug for sat radio. Ericson electronics is contracted to build the sat compatible units that wire into this radio through the blue. plug. if you are using 3.5 plug audio control from a portable sat receiver, the you will need to buy an aux input cable for your stereo..
Sep 25, 2009 | Pioneer DEH-P3700MP CD/MP3/WMA/WAV...
No sound w/ pioneer DEH-P3700MP
chrystler sometimes has an amplifier. the blue with a white stripe wire on the radio is for that. connect it to a black wire that was left over. ps it isn't on the wireharness on the radio. it is the one just laying inside the dash accomidating the other wires. it should turn on just fine.
Apr 06, 2009 | Pioneer DEH-P3700MP CD Player
Ipod worked with my pioneer deh-p3700mp before
this works on some other pioneer head units i encountered it may work on yours.
Shut it off and hold the function button until the options appear then you can scroll through and change a bunch of settings including the aux input
Dec 31, 2008 | Pioneer DEH-P3700MP CD Player
IT ONLY TOOK MY TWEETERS WHY?
factory aplifier in your car. you need a bypass harness to circumvent the factory amplifier.
Dec 20, 2008 | Pioneer DEH-P3700MP CD Player
Pioneer head unit plays in accesory mode, but not when vehicle is fully started
he tapped into starter wire instead of accessory. Remove radio and verify the switched power (red) wire is properly hooked up to an accessory wire that stays on after vehicle is started.
I believe the wire is white/black behind the radio. Check with a voltmeter to be sure.
http://www.the12volt.com/installbay/stereodetail/967.html
for the wire codes to that vehicle.
Oct 18, 2008 | Pioneer DEH-P3700MP CD Player
Pioneer DEH P3700MP CD reciever
Unless you are familiar with servicing them, it's risky, but can be done. Gently pry the top cover off. Remove four #1 philips screws from the CD mechanism. Gently lift out and unplug the ribbon cable connecting it to the motherboard. On the right side (as viewed from the front) there is a set of gears. These control the eject/intake motion. Start spinning (i can't remember which direction off the top of my head.).
Dec 07, 2007 | Pioneer DEH-27MP CD Receiver w/ MP3/WMA...
Help
do u like ur head unit (Pioneer DEH3700MP) , cuz i bought mine @ a car show for $40.00
Sep 17, 2006 | Pioneer DEH-P3700MP CD Player
Car Audio & Video Logo
210 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
xxxxxx xxx
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
