Question about Pantech C120 Cellular Phone
Pantech Duo I need help for the ringtones I downloaded to my phone from PC. How do you use the ringtones that I put on it
  • 1 more comment
  • Tankmech4 Feb 10, 2008
    I'm basically having the same problem with my wife's Pantec Duo, however I've been able to get the ringtones down to size and on the phone. My only problem is that I cannot get the "EDIT" option to come up to set specific ringtones to her contacts. Can some on help.
  • ramyrann0 Feb 17, 2008
    I downloaded music and put it into the ringtone file but it wont let me use it.  It says needs a application to open.  I used the application and I still cant get it to be used as a ringtone....help.....does anyones space bar not work... also I cant get the tone to work on my keypad.  It works for the sound of click but not for the sound of a tone.... if anyone could help me that would be great.  Im really close to trading it in on a different phone....thanks
  • nessa_0224 Oct 19, 2008
    I have songs on my phone how do I get them over to my ringtones
You need to cut a somg below 30 sec and make it under 300kb.put it under thenpantech duo icon in hte active synch and into sound files.
Posted on Dec 20, 2007
SOURCE:
Set ringtones for text messages
You all can try this
I simply opened my computer on my pc's desktop, then opened mobile device, then opened mobile device again, and then just copied and pasted the ringtones we had made on our pc for our old motorolla phones into the ringtones folder on the phone, and they are mixed, some mp3 some wav and even some aac, and they all work, then she just went into contacts, and picked the ringtone she wanted for each person. Hope this helps!
Nov 16, 2008 | Pantech Duo Smartphone
Can i put a song from my SD card as an ringtone on my pantech duo?
You can but the file needs to be labeled My Ringtones. If you have tones in the ringtone folder and its still not working check the size and format of the tones, windows mobile 6 was only designed to accept tones under 320k and in .mp3 or .wav formats.
Sep 07, 2008 | Pantech Duo Smartphone
How do I add mp3 as my ringtones?
Download a software to your computer called Audacity. It will let you cut songs and then you can save them to your phone and use them as ringtones.
Sep 04, 2008 | Pantech Duo Smartphone
Using a ringtone for text alert
Always think carefully about altering your phone's window registry for any reason. If you follow the instructions all should be fine. If you are a complete novice, I wouldn't recommend it, you could seriously mess up your phone. Use at your own discretion.
*WARNING I DO NOT know the extent at which this works ( "How many tones that can be added""How long the ringtones can be"FOLLOW THE INSTRUCTIONS!! I AM NOT/WILL NOT BE RESPONSIBLE FOR ANY DAMAGE CASUED TO YOUR PANTECH DUO BY PERFORMING THIS PROCESS!! Doing this involves tinkering with the phones defaults if you change something that you are not supposed to the phone may not work causing the phones warranty to be void (Solution:If your not sure what your doing DONT DO IT). Before you start make sure all ringtones you desire to be used as alerts for text messages, voicemail, etc. are in the "\My Documents\My Ringtones\" folder. This is very important as you will see. Also make sure all ringtones are short enough (15 seconds MAX) that they will be recognized as useable tones*
1. Download the Mobile Registry Editor (Don't worry it's Free) http://www.breaksoft.com/Blog/Utilities/2005/1/Mobile_Registry_Editor.aspx
2. Connect your Pantech Duo to your Desktop/Laptop and run the registry editor
3. Once your device and has been connected to the Editor open "HKEY_CURRENT_USER" (should be the second file folder down)
4. Open "Control Panel" (this should also be the second file folder down)
5. Click (and only click) "Sounds" (Should be the 15th file folder down *make sure its just "Sounds" and not "SoundCatergories"*)
6. Double Click "All Sounds"
7. In the pop up menu box scroll down to the end of the list of assorted factory tones
8. Put your cursor at the end of the last line and press enter to creat a new line to type in
9. Type in " \My Documents\My Ringtones\ " immediately by the exact name of the file you wish to enter ( EXAMPLE: \My Documents\My Ringtones\342.wow.mp3) MAKE SURE YOU ADD THE FILE TYPE (.wma,.mp3, etc.)
10. Click "OK" when you are finsihed adding your ringtones
11. On your Pantech Duo from the home menu Click Start>Settings>Sounds>Text Message then scroll through the tone options to reveal that tones you added are options and and can be play automatically!!
Reply and tell me if it worked, if it didn't, or if the directions are unclear P.S. have someone text you to double check if it works
Aug 23, 2008 | Pantech Duo Smartphone
Pantech duo ringtones
I get free music ringtones from myxertones.com
Just register and then start downloading the instructions are there once you pick a song and you can listen to it before you download it
Jul 19, 2008 | Pantech Duo Smartphone
How do i get my ringtones from my sd card set as my ringtones?
I got ringtones from my microSD card on my Pantech Duo to set as ringtones by using another phone. I put my microSD card in another phone and bluetoothed them to my pantech duo. When i had bluetoothed all the ringtones i wanted onto my pantech duo, i removed my microSD card from the other phone and put it back in my pantech duo. Then i went to "Settings" on my pantech duo and then "sounds". The first option is "ringtones" so i used the circle button to select the ringtone i wanted and hit "done".
Jun 30, 2008 | Computers & Internet
Pantech duo
i would give it a master reset, take out the batery while its on then put it back in and reboot it up then try to send a text. if thats doesnt work you should save your contacts and pics and ringtones on your computer than clear the phone reset the settings. and it should reset the network mms number. if you need help doign the reset let me know. also let me knwo if this works, it should
May 30, 2008 | Cell Phones
Pantech duo
hi
you can download the manual form here Pantech duo™
riz.
Apr 30, 2008 | Pantech Duo Smartphone
Not able to set my fav song as ring tone
If you convert the song to mp3 format, you can set it as a ringtone.
Mar 29, 2008 | Pantech Duo Smartphone
Pantech C120 Cellular Phone Logo
59 people viewed this question
Top Pantech Cell Phones Experts
Marvin
Marvin
Abdul Mannan
Abdul Mannan
rebecca curry
Are you a Pantech Cell Phone Expert? Answer questions, earn points and help others
