I can`t install the os in the laptop i think its thei can install the os in the laptop i think its the hard drive that is damage what can i do
Replacement hard drives are pretty cheap ($50 to 100) at places like newegg.com I could give more detailed information if you posted the model of the system in question, as you need to ID if the system has an EIDE or SATA drive
SMART error is definite HDD replacement.'
http://www.newegg.com/Product/Product.as...
it`s a ACER ASPIRE 9410
ok every time i turn it on it show this message
SMART failure predicted on Hard Disk 0:WDC WD1200UE-22KV TO-(PM)
Warning: Immediately back-up your data and replace your hard disk drive . A failure may be imminent.
Press F1 to continue
And i use HDRegenerator from the hiden boot cd , to see if i can make it work, and everything was good for the first few minutes and it show me this message
Hard drive is not ready
Switch off your computer , then switch it on to reset the system. After the system is reset , start the process again.
Press any key to exit
If your sata controler works in AHCI mode , change it to compatible IDE mode (in the system BIOS).
I try a couple times and it say the same thing , so I dont know where i `am now , can you help.
