Question about Sony Handycam DCR-TRV140 Digital Camcorder
Issue everytime I turn on the camcorder either to play the tape or to record, I have message on screen C:31:23 and beeping at the same time Sony Handycam DCR-TRV350. could you please help me.
  • 2 more comments
  • Anonymous Jan 23, 2008
    I have the same problem. I can be contacted at bigred1@maine.rr.com
  • estaban Mar 07, 2008
    i get a c31:23 everytime i try to playback or record. i changed taps and battery nothing works
  • yaboitee0321 Mar 13, 2008
    error
  • Anonymous May 15, 2008
    I have the same problem. Error 31:23. Took it to a tech and they could not help. The tape receiver raises, but does not open so that you can put a tape in. Before it would open, but ate the tapes. Now it doesn't open at all. When I depress the reset button, the receiver raises, but again, does not open.
oldripinsurfer@aol.com
Posted on Mar 07, 2008
Change the tape
Posted on Mar 05, 2008
Sony DCR-TRV460 not playing back, blue screen
Follow this procedure to troubleshoot if a blue screen is displayed when attempting to playback video from the camcorder.
  1. Stop the tape.
  2. Ensure the tape has been rewound to the beginning of the video recording.
  3. Play the tape.
  4. If the issue is not resolved, stop the tape and remove it from the camcorder.
  5. Clean the video heads of the camcorder using a dry head cleaning cassette.IMPORTANT: Follow the instructions for use provided with the head cleaning cassette. It may be necessary to use the head cleaning cassette more than once per session.
  6. Reinsert the tape into the camcorder.
  7. Play the tape.
  8. If the issue is not resolved, stop the tape and remove it from the camcorder.
  9. Insert a different tape with video footage into the camcorder.
  10. Ensure the tape has been rewound to the beginning of the video recording.
  11. Play the tape.
NOTES:
  • If a blue screen is still displayed, then the camcorder may require service .
  • If the tape plays back correctly, then the first tape may be faulty or there is a problem with the video recording.
Aug 13, 2009 | Sony Handycam DCR-TRV460 Digital Camcorder
I have a blue screen during playback mode on my Sony DCR-HC32. I am not able to see anything I recorded. What should I do?
  1. Stop the tape.
  3. Play the tape.
  7. Play the tape.
  11. Play the tape.
Aug 06, 2009 | Sony Handycam DCR-HC32 Mini DV Digital...
Sony Handycam CCD-TRV21 won't play tapes.
no that u must remove ur camera and try to clean all strip that connect with board and mechanisum and all connectors legs solder then it will work .any doubt call u.a.e no 00971503853766
Jul 04, 2009 | Sony Handycam CCD-TRV21 Camcorder
560X Camcorder Handycam won't record or play
This behaviour is relaterd to tape reading / tape detection. You may have a dirty or worn-out head on the video heads drum.
You may try to use a cleaning tape in order to retrieve normal perfoming of your camcorder, BUT you should take care, as cleaning tapes are also abrasive tapes, and the amount of cleaning cycles a video head can support is limited.
Then it should be possible that after cleaning the result is nul or worse (I had this lately on an old Sony Camcorder, it was recording with much losses in the film, after using the cleaning tape it doesn't record any more).
All that means you may repair your camcorder with the cleaning tape, but you may finish it too, if the video heads are too old.
In any case take time to read the cleaning tape user manual, cleaning time is very short (10 seconds generally) and must'nt be overtaken.
Hope you would have the good result !
Jun 17, 2009 | Sony Handycam DCR-TRV130 Digital Camcorder
Sony ccd trv218e, recording & playing back does'nt work
I had that problem also and I found that using smaller tapes helped. I was using the 120 minute tapes, I think they may be too heavy.
Feb 13, 2009 | Sony Handycam CCD-TRV21 Camcorder
Not recording or playing back recorded tapes
first leave your camcorder with the cassete draw open in a warm room for 24 hrs.
then, use a brand new cassette & re try.
if you get the condensation message, it means the unit has detected moisture on the heads, the unit will not operate... hence your problems.
May 09, 2017 | Sony Handycam DCR-HC14E Mini DV Digital...
Will not record or play back.
the head may be dirty, try cleaning the head with a cleaner tape and try recording again.
Oct 23, 2007 | Sony Handycam DCR-TRV340 Digital Camcorder
Will not playback or record
I have a Sony handy cam ccd-trv108 Hi-8 and I can not get it to play or record, everytime I insert the tape and hit play the display screen flashes c:31.22 Please help me?
Aug 10, 2006 | Sony Handycam CCD-TRV108 Camcorder
LCD won't project
You may have a problem with the image sensor device (CCD). From October 3, 2005 through October 2, 2007, Sony will repair, free of charge, affected products exhibiting the above-mentioned problem where it is caused by the image sensor device. Sony will also cover the cost of shipping and handling from and to addresses within the United States and US Territories for service to correct this issue. To see if you have this problem: Power On your camcorder (make sure the battery is fully charged). Check the LCD screen and verify that the display icons are turned on. If you cannot see the icons, press the Display button until the icons are visible. Put a tape in the camcorder. With the lens cap off, record some video. NOTE: Be sure to speak during the recording so the video will contain your voice. Rewind this section of the tape (using tape counter to verify start of your recording). Play back the recorded video and use the LCD screen on the camcorder to view it. You should hear the audio you recorded and the Display icons/text will still appear. If your camcorder is affected by this CCD issue, the picture will either be extremely distorted, or there will be no visible picture (just a blank LCD screen with the display icons still visible).
Mar 22, 2006 | Sony Handycam CCD-TRV318 Camcorder
Sony Handycam DCR-TRV140 Digital Camcorder Logo
233 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
