Question about Honeywell Programmable Thermostat Heater
No heat! Hello, I have a boiler with a hot water tank. When i switch on my central heating it lights up fine and burns for about 2-3 minutes and then switches itself off. I can hear what sounds like water boiling before it switches off (goes back to just the pilot light). The radiators remain cold during this time. The heating system is about 15 years old and has given intermittent problems over the past year, but it has rectified itself after 2-3 days of trying it. Any ideas what the problem might be? Thanks
  • Ger B Dec 09, 2007
    Hello, thanks for your reply. I don't know a huge amount about central heating but as far as I can gather I have two zone valves (small metal boxes with a small metal lever at the end). The lever on one of them loosens when I switch on the water and the other one loosens when I switch on the heat. The levers are still loosening even though the system isn't working. There is also a small pump/circulator close to the valves. That doesn't make any noise when I switch on the heating. The system is called a Honeywell S plan (if that helps). The actual boiler is located behind a false wall at the back of my gas fire so I don't know what temperature it is set to. However, the pilot light and the starter for the light are accessible and that has a temperature gauge beside it, which is currently set on high (no temperature just low-high).
    The water doesn't heat up either (just the same start up of the boiler, which then switches off after a few minutes), however the water does heat up when I switch on the electric immersion.
    I appreciate any advice you can give me.
    Thanks
I took your advice and got someone in this afternoon. He replaced the pump there and then and all is working well again. He charged £135 for the pump plus labour. It was the best price I could get after ringing around a few other companies. I wish I was a plumber and could charge prices like that!
Thanks a lot for your help.
Posted on Dec 10, 2007
  • 1,420 Answers
Ger, do you get your hot water off the same boiler and it that working alright? How many zones and are they controled by zone valves (little boxes mounted on the pipes) or circulators (small pumps)?
Boiling water sounds can indicate hard water deposits in the boiler or that your aquastat is set too high allowing the water to heat up higher than it should. Check your boiler guage and let me know what temperature you are recording. Get back to me with the answers to my questions, we'll figure it out.
Posted on Nov 28, 2007
  • Chandler Ede
    Chandler Ede Dec 10, 2007
    Thank you with the info, it does help. The levers on the small boxes indicate there is a call for heat, however the boiler is not coming on. Either you have a bad aquastat relay or a broken wire going to the aquastat. It is time to get a proffessional in there and diagnosis the issue.
SOURCE:
My central heating turns off when i turn the hot water tap on. when i turn it off the central heating doesn't come back back on until i turn the power off and on.
Combi-boiler-turn hot water tap on/off and the heating stops for ...
singletrackworld.com/.../combi-boiler-turn-hot-water-tap-onoff-and-the-...
Combi-boiler-turn hot water tap on/off and the heating stops for 20secs ... hot watertakes priority over central heating so when you run the hot tap, heating is ... Yeah onmy worcester combi there is a diverter valve - it feeds either the heating or ...
My central heating works but I have no hot water - 24'7 ...
https://www.247homerescue.co.uk/my-central-heating-works-but-i-have-...
Diverter valves switch heat between the hot water and the central heating. When youturn your hot tap on, the diverter valve temporarily shuts off the water supply ...
Does your boiler keep switching itself off? Here's why ...
www.dhs-uk.com/does-your-boiler-keep-switching-itself-off-heres-why/
Jul 7, 2015 - ... Bathroom Suites, - Showers, - Wet Rooms, - Taps and Accessories, Information and ... Low water pressure can cause your boiler to turn itself off. ... boiler is not turning off, you aren't getting the amount of hot water you require. ... If there is air in your central heating system, then your boiler may shut down.
Feb 09, 2016 | Water Water Heaters
I have an ariston 20/24 mffi combi pressure rises when switched to central heating but pressure ok when asking for hot water ? expansion vessel ?
over heat limit stat on central heating circuit ? if hot water is ok and hot to temp when run for 5 minutes the expansion vessel is doing its job.remember hot water is the maximum demand for any boiler ,,heating is secondry?once you establish hot water at maximum rate then the only real problem is on you demand for heating??
Dec 10, 2012 | Water Heaters
No central heating back boiler
back boiler run from a gas fire? check the instructions to operate the gas heat to the back boiler not just the fire
I presume that this a fully pumped system - air lock doubtful There maybe on/off valves on the pipes to and from the back boiler [situate close to cylinder] make sure they are on - anticlockwise turn
or there could be a blockage in the outlet from header tank usually in the loft. or If there is no water in it maybe the mains cold feed it is off.
Note if no water in it DO NOT USE the back boiler
May 03, 2009 | Bosch & Power Vent Water Heater
No hot water from combi boiler
i have a combie bolier when i turn the hot water taps on only cold water comes out central heating working fine can any one give some advise ?and can i fix it myself.
Jan 03, 2009 | Combi Centre DX - Mango
Gas Boiler will supply /fire up to supply Central heating When Room thermastat turned up and switched to Heating and Hot water. When on Hot water Only will not fire up even though thermostat on hot water...
most likly or a shorted wire unhook the wire from the boiler see if it stops then if it's still is on it's in the boiler if off try unhooking it at the t-stat on the heater this should narrow it down for you dan
Jul 19, 2008 | Heating & Cooling
Heating & Cooling Logo
351 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
