Question about Toshiba E-STUDIO 650 Copier
Ricoh 1022 I have a internal tray 1 full error message, but there is no paper in the output tray
  • 30 Answers
The problem is caused by a black sensing arm that is located at the middle of the exit area and is a long actuator arm that is hanging up and creating an indication that the exit tray is full when it's not. That thing was originally designed to prevent the exit tray from becoming over full and creating a backup and jamming into the the machine. Really bad engineeering. You can permanently rid yourself of this problem by removing the black sensing arm. It pops right out of the two little holders and removing the small front panel and unplugging the sensor. It is accessed by removing a screw from the upper right side of the machine. The panel then pops out exposing the sensor and associated plug. Disconnect the sensor and the error indication will go away, never to return. Too bad I can send a picture. It would really make it clear.
Let me know if this helps. Aloha, Bill Monroe
Posted on Nov 28, 2007
Yes agree with u and ur solutions, cuz i am also working with ricoh ,
Posted on Jan 29, 2009
I keep getting error sayng to remove paper from tray after I try to print. Any thoughts?
In the paper output tray there should be a tab in the center that you can move up and down easily. It sticks out in front of the rollers. It moves up to "tell" the printer that the output tray is full. Check to see if that tab got stuck in the up position. That would cause it to think there is too much paper in the output tray and tell you to remove it.
Give it a go and see if that helps. Good Luck!
Aug 18, 2010 | Ricoh Aficio AP610N Laser Printer
I have a ricoh aficio 220 and it says internal tray 1 is full remove the copy on the display
There is a sensor above the tray where the paper comes out, and that sensor has a long black actuator. Sometimes that actuator gets turned to the side, and this will cause that message to appear.
Reach above the rollers where the paper exits the copier, find the black actuator, and turn it so that it is hanging down over the tray. Once the sensor is reset that message should disappear.
May 04, 2010 | Ricoh Aficio 220 Laser Printer
Error code SC 548 on Ricoh Aficio 1022 copier. Need to reset m/c
sc 548- service call - fusing unit not set properly
the fusing unit connector may be loose.
u can reset the error by entering the service mode (careful -do not change anything )
to enter the service mode press [all clear](yellow button) ,[1],[0],[7],[clear](orange button)and keep the button pressed for about 5 sec.
go in copier options , then mode 5, then option 810
and execute(or 1 & ok)
(careful -do not change anything else)
Jan 15, 2010 | Ricoh Aficio 2022 All-In-One Laser Printer
The display says following output tray is full.
Look at the area where the paper just exits from the machine. You should see a small black plastic arm. Make sure it has not become stuck in the up position or knocked out of place. This arm is what tells the machine that the area is full of paper. Also your machine is the same as Ricoh 1022, Savin 2522 in case you need to do more research.
Oct 19, 2009 | Gestetner 2212 Digital Imaging System...
Ricoh AP3800C "Output tray full"
Check the little black piece of plastic that senses the printed page exiting the machine. Our sensor was stuck and I was getting the same message (an similar Ricoh product). When I gently reset the black piece to center, moving freely, printing worked again. I think the sensor got jammed up when we were trying to remove a bad paper misfeed.
Ricoh manuals very confusing on this error message. They refer to standard tray, tray one, etc. without being clear whether it's a paper feed tray or the so-called "standard OUTPUT tray." The output is not really a tray, it's just the depression where your sheet lands after printing. I wrenched on the paper feed trays and their settings for an hour before I figured out they meant OUTPUT.
Feb 27, 2009 | Ricoh Aficio AP3800C Laser Printer
I have a ricoh Aficio 220 and it says internal tray 1 is full remove the copy on the display
Please you must remove the copies from the output tray.
If you don't have copies in the output tray, check for a black lever at the middle of the exit rollers. It can be either stucked or broken.
If you want this lever can be folded inwards.
Good luck and please rate me, thanks.
Dec 29, 2008 | Ricoh Aficio 220 Laser Printer
Standard Try Full
'Standard tray full, remove paper' is the output tray where the prints exit.
Check also the exit sensor/feeler condition.
Sep 05, 2008 | Ricoh Aficio SP C811DN-DL Printer
Error message for Ricoh C410DN
When that message is displayed, the printer thinks the output tray is full of paper and it won't print any more because there is no room left to spit pages out. If the output tray isn't full of paper, the sensor that detects paper there might just be dirty or dusty.
That sensor is a black sensor that should be located just at the point where the paper exits the machine, above where the paper comes out. Blow some compressed air on the sensor to try to clean it off and see if that clears your error message.
Oct 30, 2007 | Ricoh Aficio CL2000N Laser Printer
229 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
