Question about Vizio L37 Television
Green screen vizio lcd
My vizio lcd 42 inch i just bout a month ago was working but then i just turned it on and there is a green screen on the hdmi input. it works on the av input but is solid green on the hdmi input.. any suggestions?
  • 8 more comments
  • ThePepster Nov 28, 2007
    My Vizio is a 32" screen. When the TV is first turned on I see light green fuzz on the screen. I see this no matter what input I'm using (HDMI,Component or TV via an over the air antenna). The problem does go away after about 15 minutes. I purchased the TV in July 2007.
  • kings Dec 02, 2007
    I have a Vizio 50" 1080i. When I first turn the TV on, there is a greenish speckling on the brighter images (sort of a fluroescent mold effect). This generally lasts for no longer than 5 minutes and sometimes a channel change will correct this. I have owned this for about 5 months and this problem only started about a month ago.
  • Anonymous Jan 07, 2008
    37" Vizio bought from Costco Seattle Dec 2007. Same problem, green screen on all inputs.
  • heroes52 Sep 14, 2008
    I have a 52'' vizio and the screen will turn green where there is black, and pink where there should be whites. Usually after the tv has been on for a little while. I can sometimes change channels back and forth, and it will go away. Only to happen again 20 minutes later. Vizio support told me it was the hdmi cables, so I changed them with no luck.
  • dfo319 Sep 28, 2008
    42" LCD, same problem, all inputs. comes and goes - sometimes changing channels, sometimes, turning TV on and off, sometimes turning cable on and off. Purchased 9/14/08 at costco
  • mawawilson Dec 10, 2008
    We have the same problem, brand new TV two weeks old started doing that. At first it cleared up after turning it off and then on again, but now two minues after it's on and it doesn't clear up. Do other brands have this problem or is it only Vizio? Vizio offered to send out a replacement but will take 7-14 days. Taking it back to Costco right away, but am leary about Vizio now.
  • Anonymous Mar 10, 2009
    my tv generates green color in the area that seem to be reserved for the blackest portions of the video. I first thought it was the HD digital signal (HDMI) but then the problem arose while watching DVD (Component video input). The Vizio tv is a 47 inch with the 1080p and 120hz.
  • Anonymous Mar 12, 2009
    I have the same green screen problem!
  • seco7 Mar 30, 2009
    Green pixel mold fills in the blacks. I have the 47 inch and it goes across all inputs. I am returning it to Costco since I have only had the set for 2 weeks. I will never buy a Vizio product again.
  • Anonymous Mar 15, 2014
    No picture just green w/streaks. Input button does not do anything except turn sound off.
My 37" vizio I bought in Dec 2007 did this (green screen at start-up on all inputs). At first it went away by itself after you left the unit on for 15 minutes, but then 2 days later the whole thing DIED. Luckily Costco has a 90 day return policy on TVs.
Vizio tech support suggested this (before it died that is):
Please try to reset all setting and then to see if the problem is solved. 1. Press the Menu on your Remote Control;
2. choose Set up on the OSD;
3. then choose Reset All settings;
4. Press the Exit on your Remote Control to remove the OSD.
Posted on Jan 09, 2008
My vizio 42 inch, the green light at the bottom comes on but the tv screen wont and every 21 seconds the turns off then come back on over and over every 21 seconds.
I don't know if your refresh rate on your TV is adjustable or the signal being fed is inadequate. What connection are you using with the TV? If it's HDMI, make sure the cables are HDCP-certified. Otherwise this will always happen. If it is simply your TV, are environmental variables (dust, cold, heat, etc.) causing the TV to malfunction? Give it room to breathe and avoid cases without holes for the TV to breathe. TVs don't operate properly when they are stressed out.
Sep 23, 2013 | Vizio VW42LF 42 in. LCD HDTV
We purchased a Vizio 42"
This is more of a provider problem. Report the signal problems to the service you subscribe to for tv.
Mar 23, 2011 | Vizio E420VA 42 in. LCD HDTV
My Vizio LCD TV screen fades to dark. Sound stays on.
I w having this same issue when watching a Blu-Ray disc. I found it to be dependent upon what picture mode the TV was set to. By this I mean certain picture modes would cause the TV to dim during dark scenes of a movie. Changing the picture mode helped a lot.
Feb 28, 2010 | Vizio VW42LF 42 in. LCD HDTV
Insignia 37 inch lcd inputs not working except for hdmi inputs
TV when hooked to Direct TV by HDMI will not work, it must be hooked by RCA cables. I now have 1080i rather than 1080P. The HDMI cable and the direct TV box has been changed. What can the problem be?
Jul 01, 2009 | Televison & Video
Vizio 42" lcd powers up with sound only - no picture
It sounds to me that the unit has a faulty inverter board which could be due to an overheated/bulged capacitor. I would send in a claim on it to the factory if it is still under warranty.
May 28, 2009 | Vizio VU42L 42 in. LCD TV
Vizio GV42L LCD TV screen black when turn TV on first time
If you are using a set top box this might be caused by turnig the box on at the same tie as you turn the tv on or slightly after you turn the tv on.  If you are using compnent or HDMI inputs the set needs to see the signal as it is turned on to know what formt the signal is in.
I’m happy to help further over the phone at https://www.6ya.com/expert/dewayne_4a10eab6caecdb92
Oct 15, 2007 | Vizio P2 42 in. HD-Ready Plasma Television
42" Vizio LCD
Emilie, I have the same issue. I have to press the input on the TV to go through all of the inputs and whenI get back to HDMI 1 it usually goes back to nomral - but sometimes that doesnt even work. I tried calling support, but waited 40 minutes and hung up. chris
Jan 06, 2007 | Vizio L30WGU 30 in. HD-Ready LCD...
Vizio L37 Television Logo
7,342 people viewed this question
Top Vizio Televison & Video Experts
Steve Allison
Steve Allison
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
