Question about IBM Wheelwriter 30 Typewriter
IBM Wheelwriter 2 Typewriter will not respond
When my typewriter is turned on two lights flash (the 1" and 2") and that is all that it will do. It will not respond, it is frozen. You can turn it off and on but it stays the same. Any suggestions on why it is doing this and what happened
  • 2 more comments
  • kristylou Dec 10, 2007
    I am having the same problem and I dont know what the T/W Button is if you can please describe that would be helpful. thank you
    How do you unplug the keyboard
  • Anonymous Feb 12, 2008
  • markeshia_jo May 11, 2010
    how do i unplug the keyboard?
You probably hav a keyboard problem, unplug the keyboard and turn on t/w, if the condition is the same it's the keyboard.
The right connector has a groug of 6 etchings bussed together, wrap a piece of foil over the connectors and plug in and test.
BE SURE TO ONLY JUMPER THE 6 BUSSED CONNECTORS!
Posted on Dec 08, 2007
  • IBM Master
  • 3,594 Answers
To get to the keyboard connectors on a personal ww you must remove the cover, onthe base of the T/W on both sides there is a slot insert a scrwedriver into th top of the slot while lifting on that side of the case, once the case is loose in the rearlift it up povoting it at the front. Press the two lower rt keys and lift. BE GENTILE YOU DON'T WANT TO UNPLUG THE LIGHT PANEL.
Now you can see and unplug the ketboard.
DickyO
Posted on Dec 31, 2007
How to solve a problem with an IBM Wheelwriter 10 Series ll Model 6783
It is most likely a bad keyboard. You can try my fix under WW1000 or contact Geo. Beyers Co. for a rebuild.
DickyO
Feb 28, 2013 | Swintec Ibm Wheelwriter 10 Series Ii...
The margin lights are flashing and nothing is responding. It seems locked up. Have turned off and back on several times and nothing changes. This is a Lexmark 6781-025 IBM personal Wheelwriter 2.
Your keyboard is probabily bad. If you h ave mech. abilities try my tip under WW1000. If not Contact Geo. Beyers Co. @ 800-392-8085 for a rebuilt KB. Tell them O'Reilly sent you.
DickyO
Oct 20, 2010 | Lexmark Wheelwriter 15 Series II...
Typewriter doesn't work. IBM wheelwriter 2
The keyboard is going bad. You can try my tip under WW1000 or have it rebuilt, contact Geo. Beters Co. @800-392-8085 for a rebuild, tell them O'Reilly sent you.
DickyO
Jul 20, 2010 | IBM Wheelwriter 30 Typewriter
My ibm wheelwriter 15 series II TYPEWRITER HAS FLASHING LINE SPACING LIGHTS 1, 2 &3 WHAT SHOULD I DO TO REMEDY THIS CONDITION
Rattling the brain cells...., I think tyhis used to happen when the print wheel was bend and couldn't roate freely, check the daisywheel hasn't any bent arms and that ribbon or corection tape are not stopping it from spinning, ensure it is locked in place, try another whell if you have to ensure.
Nov 06, 2009 | IBM Wheelwriter 30 Typewriter
IBM Wheelwriter 6---when I turn it on, it appears to lock
There are a few possibilities. First lube the silver shaft that the carrier slides on (WD40 works well). Remove the printwheel and check for paper or ither debris in that area. After that you e
will probably need a tech.
DickyO
Jul 27, 2009 | IBM Wheelwriter 30 Typewriter
Typewriter only beeps and lights blink. Nothing else.
the beeping and the lights are error codes, meaning the machine will need repair
Feb 25, 2009 | Lexmark Wheelwriter 30 Series II...
IBM Personal Wheelwriter 2 - Machine comes on and is stuck with flashing lights on the left . . .
If the 1 &2 lights are flashing check the keyboard conectors and see my tip under WW1000.
DickyO
Dec 11, 2008 | IBM Wheelwriter 30 Typewriter
IBM Wheelwriter 30 Typewriter Logo
218 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
jasbo
jasbo
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
