Question about SanDisk Sansa e260 MP3 Player
Music DB? Whenever i power on my sansa e260 it says not enough disk space for music DB, Please free 6mb What is going on?????? also it doesnt recognize it on the computer
  • 626 Answers
You have put too many songs on the device.
It needs some free space to create the Music Database or the Artist, Album, Song information.Generally between 6 - 10 MB for each GB of music on the device is sufficient.
If it shows up in My Computer, you can manually delete some files from the MUSIC folder.
If not, you can use the following software to erase everything and start over.
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted.
http://rapidshare.com/files/67740173/e200fw01.00.12.exe____
You need to put the device into "recovery mode" before you run the tool.
- Turn the device off (hold power for 20 seconds)
- Slide the hold switch into "hold" position.
- Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer.
Then run the recovery tool. Select format when prompted.
Best of Luck.
Please RATE my solution at the bottom.
Posted on Nov 28, 2007
When i turn the player on it says Not enough space for music DB Please free 6 MB. But it says in the info Memory 0MB and Free 0MB
Connect to your computer copy music to a folder and save as whatever name you give it Then format Check the folder with the music in it to see if there is a file thats not MP3 delete it if there is one then replace the musicto the sansa keep about 6MB of free space
Dec 23, 2010 | SanDisk Sansa e260 MP3 Player
(Sansa 2.0 GB e250R) Player shows an empty database...
DO YOU GO TO YOUR COMPUTER ICON ON YOUR COMPUTER AND THEN PLUG IN YOUR SANDISK SANSA AND THEN DRAG YOUR SONGS TO IT BECAUSE THAT IS WHAT I DID AND IT WORKED
Apr 15, 2009 | SanDisk Sansa e260 MP3 Player
PLEASE HELP I CAN"T LIVE WITH OUT MY SANSA
"Please free 6MB for music DB" means that there is not enough MEMORY for the MUSIC DataBase. Therefore, you cannot see the music on your device.
To resolve this, you need to delete music until your device is less than 6MB of being full.
Generally 10 to 15 songs should do the trick.
Best of Luck,
Oct 31, 2007 | SanDisk Sansa e200 MP3 Player
My sansa wouldn't work
The device needs 6MB free for each GB of music.
Delete about 10 or 15 songs and you should be all set.
Best of Luck.
Oct 30, 2007 | SanDisk Sansa e200 MP3 Player
I lost my free space@!!!
The error message says, please free up 6MB for Music DB (database).
Connect the device to your computer and remove several songs. Restart the device, and you should be back to normal.
Best of Luck.
Oct 13, 2007 | SanDisk Sansa e260 MP3 Player
My sansa is messed up
It is referring to the "database", or the menus on the device. (i.e. - songs titles, music, artists) It needs at least 6MB of free space on the device to create this. If you freed up what you think is 6MB, it may not be enough. Even though you have a 2GB player, there is only 1.85 of usable space on it. So try deleting some more tracks. If not, format the device and start over. Right click on the device in My Computer and select format. Best of Luck.
Sep 14, 2007 | SanDisk Sansa e250 MP3 Player
Sansa e280r "not enough space for music db. please free 6mb."
RECOVERY MODE
Switch your Sansa E260 to its Recovery Mode:
1. Make sure the player is powered off
2. Enable the "Hold" switch (located on the top of the player). You would know it's enabled when you see the "orange-colored" surface
3. Press the "Record" button. Make sure you keep it pressed while pressing on the "Menu" button.
4. keep your fingers pressed on these 2 buttons until the E260 LCD screen displays "Welcome to Recovery Mode"
5. Connect your E260 to your computer. (Just a reminder: The minimum Operating System requirements for a Sansa E200 player is Windows XP and above)
6. Double-click on "My Computer" and you would see your Sansa E260 appear as a "16 MB" drive. Note: If you do not see that "16 MB" drive/partition, please repeat steps 1-6.
Next, Apply the firmware for the E260 (your player should be connected to your PC at this time):
Step 1:
Use this link to download the firmware for your Sansa E260 (for better results, please save this file on your "Desktop":
http://www.sandisk.com/Assets/File/Downl...
Step 2:
Double left-click on the downloaded file, and follow the on-screen prompts. The file will automatically re-flash your player and format it as well, thereby clearing all possible file/system corruptions that may have occurred which caused the player to keep resetting.
Step 3:
When the process is complete, unplug your E260 from your computer, and please make sure you disable the "Hold" switch
Step 4:
Power up your E260 and 90-99% of the time, it would boot up successfully. If not, try to repeat steps 1-4 again.
I hope this helps.
Aug 01, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
95 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
