Question about Samsung SC 140 (SC-140) Internal 40x CD-ROM Drive
Samsung SC-140 driver......
Hey i need help on getting a whole new driver
because for some reason
the driver is no longer in tha c drive.....
how can i get this back??
  • mrjones3306 Jul 28, 2008
    my computer detechs the cd-rom but says it cant down the file for the drive needed something about code 39
  • Anonymous Dec 21, 2008
    My samsung sc-140 cd driver will not read cds. Tried looking for downloads, and nothing will work. Any suggestions?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 175 Answers
The drive is no loger in the C drive????
it must not be in MY COMPUTER.
check the Data cable or the power cable of the Drive.
and go to setup utility page and see if it is detected.
Posted on Jan 07, 2008
Will a samsung sc 140 in a dell inspiron 531
Hi Grannyking - Sorry, the answer is no. Your PC only has connectors for drives using the current standard SATA connectors. The Samsung SC140 uses the old IDE standard for connections so there is nowhere to connect the Samsung,
Regards, Mikeyaf
Mar 06, 2011 | Samsung SC 140 (SC-140) Internal 40x...
Error 41 this is what i get when i trouble shoot
WARNING: If you use Registry Editor incorrectly, you may cause serious problems that may require you to reinstall your operating system Microsoft cannot guarantee that you can solve problems that result from using Registry Editor incorrectly. Use Registry Editor at your own risk. ;)
To resolve this behavior, follow these steps:
Start Registry Editor (Regedt32.exe).
Locate the UpperFilters value under the following key in the registry:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Contro l\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
On the Edit menu, click Delete, and then click OK.
Locate the LowerFilters value under the same key in the registry:
Quit Registry Editor.NOTE: After you remove the Upperfilters value and the Lowerfilters value, if you notice lost functionality in a particular program, such as CD recording software, you may need to reinstall that software. If the problem recurs, consult with the software vendor for assistance.
Restart your computer.
Nov 01, 2009 | Samsung SC 140 (SC-140) Internal 40x...
Samsung CD-ROM SC-152C not reading CD but is found
maybe cd lens is damaged in which case u may need to change the drive itself
Sep 18, 2009 | Samsung SC 152 Internal 52x CD-ROM Drive
I need the jumper settings for CD-Master 40E MODEL SC-140. FCC ID A3LSC140B Thank You
When you look at the cdrom driver connectors, the following are the right jumper setting for all CDROM drives.
Left - Cable Select
Middle - Slave
Right - Master
Jul 19, 2009 | Samsung SM 352 CD-RW/DVD-ROM Burner
My samsung cd rom sc 148c is not working i am getting this message under properities Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39) i have...
If it's not a SATA drive try to set your IDE Controller in Device Manager to use DMA mode not the PIO. If it won't help try to find updated firmware for your drive and install it. Read Carefully Installation Manual Before! If it won't help that's a sign that your PC wants you to upgrade it with DVD/RW instead.
Good Luck!
Apr 17, 2009 | Samsung SC-148 CD-ROM Drive
Cd-rom
It is only a CD rom is a reader not a writer you can't burn data through it..
Feb 28, 2009 | Samsung SC 140 (SC-140) Internal 40x...
Usb driver
Try a google search for "Samsung sc-363 ntsc camera drivers".After you find and download the new software,uninstall the bad driver and reboot your machine.Install the new drivers and you should be good to go.
Peace
Oct 04, 2008 | Samsung SC-D363 Mini DV Digital Camcorder
Samsung SC-D363 Question
first of you need a driver. i will put a link if you dont have. this will recognize your device to your computer(i use USB for this) so that you can use it.
second have an editing video software to put your videos in to one or arrange it to make a whole video. i use ULEAD MOVIE MAKER to edit and put something like music, titles, etc..
third, now you can upload your video to a website like youtube or any video hosting site. hope that helps!
here the link
http://www.samsung.com/download/Model_Select.aspx?type=Camcorder&typecode=7&subtype=Mini-DV&subtypecode=701&model=SCD363&filetype=DR&language=
dont forget to rate my solution! THANK YOU!
CHARCOIS
Jul 24, 2008 | Samsung SC-D363 Mini DV Digital Camcorder
Samsung SC-D353
here the link
this is the same problem from my previous post
Jun 27, 2008 | Samsung SC-D353 Mini DV Digital Camcorder
Samsung SC-D363 won't load to my computer
If you are trying to move video that is stored on TAPE, you need to get a Firewire cable. Using the USB cable, you can only transfer photos and video that is stored on the Memory Stick Pro memory card (user-supplied). The Firewire cable has a standard IEEE-1394 male connector on the computer end and a mini IEEE-1394 male connector on the camera end. If you don't have a Firewire interface on your computer, you will need to get one. Good luck.
Nov 21, 2006 | Samsung SC-D363 Mini DV Digital Camcorder
Samsung SC 140 (SC-140) Internal 40x CD-ROM Drive Logo
697 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
