Operating Systems
Problem for Operating Systems
Generic problem for all Operating Systems
The magic jack is pluged
By kaykay4u2 on Aug 08, 2009
the magic jack is pluged into the phoneline directly
Solution #1
posted on Aug 08, 2009
Not Rated)
DellTech1
Rank: Master
Rating: 91%, 8 votes
OK.. First of all, I am hoping you understand the basics of the MagicJack concept ?? Highspeed Internet connection on your PC, MagicJack plugged into your USB port, with a phone plugged into the other end of the MagicJack ? It requires High Speed, no dial up, and marginally works on my wireless Broadband due to atmospheric influences. It DOES work on my bluetooth wireless cell modem just based on the better speeds I get from the modem vs. my wireless Broadband.
1. If you have a Cable Modem or Wireless Broadband Dish for internet, follow the steps below.. IF you have DSL, skip to # 2.. if you have Dial-up skip to # 3,
I personally own wireless Broadband, so my ongoing experience is from here. I own a MagicJack for traveling and a Vonage line, for my house fax line service because the MagicJack is not strong enough, power wise, to push through my CAT/5 house, phone lines. Vonage does provide phone for the entire house, for the most part, cleanly, because Vonage uses a powered router to provide the final signal, which I then jumber over to a phone jack to connect into the house. It also requires that you disconnect your external phone lines, that would normally go back to the "Big Bad Phone Company". This can be done at the demarcation point, where your regular phone lines connect into a box, outside your house ? The internet I have, is in my shop, about 150' from the main house, Vonage's router power's the whole house, just fine.
2. With DSL, you will have good solid speeds, but you will still have the issue of, MagicJack, being too low in it's power source, because it comes from the USB port of your PC. You are basically going to be stuck with a single wireless or corded phone, for the MagicJack service. In this case, since the DSL is fed through the BBPC phone lines, you will not be able to 'pipe', even Vonage back through your house phone lines.
3. If you're on dialup, you're going to have poor service, out of the box.. you're just not going to be fast enough to be clean.
As an added note.. Your query for help is concerning.. again, high speed internet into your PC, MagicJack plugged into your PC's USB port, the phone plugs into the MagicJack's RJ-11 phone port.
Thank you for your time in these matters.
Respectfully,
Toby White-Beebe
P.O. Box 474
Penryn, CA. 95663
(916) 300-9410 Cell
(916) 473-7409 Home Fax
2008 VA Certified NACI Low Risk Security Clearance
2008 VA OCIS/ROB Affirmation of Compliance
2008 VA Certified OIT Contractor
2008 Dell Certified Lead Systems Expert - DCSE
1999 A+ Certified Service Technician
Was this helpful?
Yes
No
Popular Solutions for Operating Systems
Questions and Unsolved Problems for Operating Systems
Answer
How can I upgrade my royal 660 cashregisterlink to cashregisterlink pro
Answer
disc driver broken ,need to program webcam to pc
Answer
i have bsnl wll.model no is wf836f.i want to sofware for update this device. main problem is the wll... (More)
Answer
widows 7 icidu driver 7.1 pci
Describe your Operating Systems problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Operating System Experts
Top Computer & Laptop Repairmen
in Newport, KY
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
