Mitsubishi VS-60707 60 in. Rear Projection Television
Problem for Mitsubishi VS-60707 60 in. Rear Projection Television
Try to turn on shuts down right a way ws_65809 7yrs old
By mammauv2 on Aug 08, 2009
my big screen tv will not stay powered up need to know if can be fixed?
Solution #1
posted on Aug 08, 2009
Not Helpful)
nicolocarlo
Rank: Guru
Rating: 85%, 219 votes
You may just need to replace a few components in your tv or there mmight be something loose. First part of the TV that usually shows up with a problem is the power supply. Check the power supply for loose soldering or leaking capacitor. If there are none on those circuit make your way up to the main board and have it checked.
Was this helpful?
Yes
No
Popular Solutions for Mitsubishi VS-60707 60 in.
Questions and Unsolved Problems for Mitsubishi VS-60707 60 in.
Do you recommend Mitsubishi VS-60707 60 in. Rear Projection Television?
Answer
Answer
my tv does not want to power on but green timer light blinks on
Answer
t.v. will not stay on. when i turn it on i hear a double clicking noise and the power light flashes... (More)
Answer
i have a 60" mitsubishi projection tv model vs-60707.turns on and plays fine for awhile then... (More)
Answer
I have a vs 60607 tv / input menu code is 1 2 lights come on for 1 sec then dim good audio
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Mitsubishi VS-60707 60 in....:
Top Projection Television Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more Projection Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
