Question about Dishwashers
The top arm of my Bellini dishwasher has com off the in pipe of the dishwasher
5 Suggested Answers
SOURCE:
  • 1462 Answers
SOURCE: neff dishwasher
if the arm is rotating freely when you give it a push by hand, then the problem is blockage in the jets in the arm - the arm only rotates with water coming out of angled jets at the end. take arm out, spray water in centre hole and whatever is blocking the jets should become visible. prize out with a paperclip or similiar
Posted on Aug 07, 2008
  • 338 Answers
SOURCE: Dishwasher top arm won't spray
sump motor assm needs to be cleaned out
Posted on Nov 25, 2008
sclarke7
  • 222 Answers
SOURCE: top spray arm in dishwasher will not spray
poor water pressure due to a clogged flowplate assy if the flowplate assy is not clogged with gook and hard water then you may need a new motor, a weak motor may not push the water well enough to get up to the top
first check entire flow are impeller etc
Posted on Oct 08, 2009
  • 65 Answers
SOURCE: Dishwasher top arm replacement.
This task is a cake walk and very easy. The upper spray arm is held on with a plastic nut that just has to be unscrewed by hand. The new one should come with a full replacement nut and spray arm.Part #154607802 which retails around $8.95 and can be purchased from most major part houses like www.marcone.com or www.searspartselect.com
Posted on Jan 18, 2010
The top arm will not rotate.Have checked to make sure that no holes blocked and arm rotates freely.Bottom arm works ok
Check the transfer pipe that takes water to the top arm, it could be cracked, loose, kinked or blocked. Try back pressurising it from the top rotating arm attachment pipe. This will give you an indication where a leak could be or blow out a blockage.
Jan 23, 2011 | Neff 24 in. S5456 Built-in Dishwasher
My dishwasher does not clean my dishes good
You may have debris in the sprayer arm jets. It is usually simple to remove the sprayer arms. Usually in the center of the spray arm is a wing nut. Simply unscrew this to remove the arm(s). Then rinse them well using the sink sprayer for forceful water power. I have sometimes had to use a tweezer to remove bits of plastic, paper, bone, or food particles. Once you've remove the debris, rinse well forcing water through to dislodge any other debris. Once you've reattached the sprayer arms, you should have cleaner dishes. Also, some brands of dishwashers have a pipe that runs up the inside back wall and connects to a pipe that runs under the top shelf. Water flowing through this pipe under the top shelf propels the sprayer arms. If the connection at the back is not flush with the "propel" pipe there won't be enough water pressure to turn the sprayer arm. Check to see if your dishwasher has this type of set up.
I hope this works. If it does, please let Fixya know by rating my solution.
Dec 05, 2010 | Kenmore Dishwashers
LOW WASH PRESSURE ON UPPER SPRAY ARMS
You may have debris in the sprayer arm jets. It is usually simple to remove the sprayer arms. Then rinse them well using the sink sprayer for forceful water power. I have sometimes had to use a tweezer to remove bits of plastic, paper, bone, or food particles. Once you've remove the debris, rinse well forcing water through to dislodge any other debris. Once you've reattached the sprayer arms, you should have cleaner dishes. Also, some brands of dishwashers have a pipe that runs up the inside back wall and connects to a pipe that runs under the top shelf. Water flowing through this pipe under the top shelf propels the sprayer arms. If the connection at the back is not flush with the "propel" pipe there won't be enough water pressure to turn the sprayer arm. Check to see if your dishwasher has this type of set up.
Dec 04, 2010 | Kenmore 24 in. 17032 Built-in Dishwasher
The top section wont wash clean
Dec 04, 2010 | Maytag 24 in. MDB5651A Built-in Dishwasher
Water does not spray or circulate
Dec 02, 2010 | Asko D1776 Stainless Steel Built-in...
Machine runs but not cleaning dishes
Dec 02, 2010 | Maytag 24 in. MDBH950AWS Built-in...
Dishwasher fills up, but doesn't spray.
Dec 02, 2010 | Dishwashers
The spinner on top of the dishwasher, that I guess shoots out the water is not spinning. I think?
Dec 01, 2010 | Maytag 24 in. MDB3700 Built-in Dishwasher
Internal Water Pipe Keeps Coming Out
There is a bracket held in with 4 screws under the lower spray arm, near the filter that has 4 lugs which the feed pipe for the top spray arm plug into. They are very common for breaking.
Mar 19, 2008 | Whirlpool 24 in. ADG6340 Built-in...
Dishwashers Logo
26 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
