Question about Panasonic CT-36G34 36" TV
    Problem Solver:
As a home renter minor details are over looked. Only after having a problem with an outside breaker did I notice the main breaker was only a 60 amp. 100 amp is bylaw. I too was blowing fuses often. Gladly after the breaker was changed I have yet to blow a fuse for 3 months now. I'm no tech and can't explain why, but this fixed my problem. Hope it helps you and any others.
Posted on Sep 26, 2008
  • 232 Answers
Means you have a part that is dead shorted after the line fuse, usually a bridge diode, regulator IC or possibly the Horizontal output transistor. Not really something a non tech will be able to find, a volt Ohm meter is required as well as soldering equipment.
Posted on Nov 27, 2007
Toshiba 32c100u keeps blowing fuse and my tv wont come on
If fuses keep blowing, the power supply may have shorted.
Jun 23, 2014 | Toshiba 32C100U 32 in. TV
Fuse keeps blowing, tech replaced a 'faulty' battery but it continued. Tech then fixed a 'short in th wiring and still the fuse keeps blowing. Not sure if this is a glitch or an actual problem with just my...
What fuse keeps blowing (drive or hyd HEAVY FUSES or light fuses probs for invertor controller LIGHT FUSES), low batteries or running on discharged batteries for a period of time can blow the fuses. Have the motors been tested? Is the drive an AC and hyd a DC?
Sep 20, 2013 | Crown Walkie Pallet Truck Electric 6000 lb
My tv keeps blowing a fuse when I turn on set.
DO NOT keep feeding it fuses more damage can accur-check rectifiers in power supply-then check regulator-chech H.O.transistor.if you need more help im gonna need a model number to go furthor
Sep 04, 2009 | Televison & Video
It keeps blowing fuses - two 12 inch cls subs 1
sounds like the audio stage riving the channel has a short circuit on it.need to go through the amp stage
Jul 16, 2009 | Cerwin Vega CLSC-12S Subwoofer
My ILO brand tube tv keeps blowing fuses, what could be the problem?
If you tv is blowing fuses it might mean you have a short in it. The fuses are a safety feature. Best thing to do is bring it to a repair shop. I do not suggest for anyone to open a tv without the repair knowledge.
Feb 18, 2009 | iLO IWT3206 TV
When you refer to the "sound fuses" are you referring to the speaker protection fuses or the power supply fuses?
Jan 14, 2009 | Audio Players & Recorders
Tv keeps blowing fuses when its plugged in...
There should not be any reason for the new TV to blow a 15 amps fuse in the house.
The TV has an internal short circuit even if it is new, I would suggest to return it and get another one.
Good Luck.
Jan 06, 2009 | Televison & Video
My sd-533hd5 keeps blowing the 5 amp 125v fuses
Yes! it sounds like a power supply problem! or the flyback in the main board needs replaced ( part is in the $70.00 range
Dec 12, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
Replaced fuses & they keep blowing
there could be a shortage in any of the dc line that cause the fuse to blow up again, either overloading or chortage will cause this, try to see for any sign of other componenet failure, wires that has been bended and cripped, transistor that has been twisted or alike
Sep 04, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
Proscan PS32610
Tv keeps blowing fuses it is due to short ckt in your tv in 1 power supply. 2 horl output section it is mainly due to 1 switching transistr 2 main fil cap 3 rectifier diodes 4 print short 5 h/output tra. 6 eht transformer
Sep 25, 2007 | Proscan PS36810 TV
Panasonic CT-36G34 36" TV Logo
1,251 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
