Question about Linksys (NH1005) 5x10/100 Mbps Networking Hub
Help finding a wep or wpa key for my linksys nh1005,v2 when i put in nothing happend there is no reset key on this system and it was giving to me help me please
    Problem Solver:
  • 17 Answers
Can you please clarify on this question? This device is not a wireless device and would not have a WEP or WPA key that would need to be entered...
Can you also detail what exactly it is that you are trying to do with this device,
Posted on Nov 27, 2007
Finding the wep or wpa key for my Linksys e1200 router
You will have to log in to the Management interface of the router.
You can use Linksys Connect for that.
Nov 04, 2013 | Linksys (NH1005) 5x10/100 Mbps Networking...
Lost disk for my links ae1000 need driver
Driver: AE1000 Linksys, based on the Ralink chipset.
Driver (September 15, 2011). (Updated December 24, 2011). Now digitally signed! The error with the Cisco CTV1W USB Key has been fixed. Supports the following wireless adapters: Belkin: F5D8051v3 ' F5D8053v1 ' F5D8053v3 ' F5D8053v4 ' F5D8055v1 ' F5D8055v2 ' F6D4050v1 ' F6D4050v2 F7D1101v2 ' F9L1103v1 Cisco: AM10 ' CTV1W USB Key
Linksys: AE1000 ' WUSB100 v1 ' WUSB100 v2 ' WUSB54GC v3 ' WUSB600N v1 ' WUSB600N v2
i use that driver too, best driver for that AE1000.
Feb 22, 2012 | Linksys AE1000 IEEE 80211abg IEEE80211n...
Want a secure line
kb19073-001_en.png NOTE: Image may vary depending on the type of router and computer you are using.
To setup your router's wireless security settings:
i. Accessing the web-based setup page
ii. Setting-Up the Wireless Security
Step 1:
Access the router's web-based setup page by opening a web browser. On the Address bar, enter your router's local IP address then press [Enter].
NOTE: The default IP Address of Linksys routers is "". For instructions on accessing the web-based setup page using a Mac computer, click here.
Step 2:
When the login prompt appears, enter your router's Username and Password.
NOTE: The default password is "admin" and the Username field is left blank. If you have set a password before but forgot it, you need to reset the device. For instructions on how to reset a Linksys router, click here.
Step 3:
On the Setup page, click the Wireless > Wireless Security.
NOTE: If some of the tabs are missing in the web-based setup page, upgrade the firmware of your router. For instructions, click here. You can also set the wireless security of your Linksys E-Series routers with Cisco Connect. To learn how, click here.
On the Wireless Security sub-tab, there are various wireless security options that you can choose from.
However, as mentioned earlier, the three most commonly used security modes are WEP, WPA Personal (or WPA Pre-Shared Key), and WPA2 Personal. The instructions below will show you how to set up the following security modes. On the other hand, the WPA2/WPA Enterprise Mixed Mode, WPA Enterprise, WPA2 Enterprise, and RADIUS security modes will only work if the router is connected to a RADIUS server.
Wired Equivalent Privacy (WEP)
WEP can be a 64-bit key with 10 hexadecimal digits or a 128-bit key with 26 hexadecimal digits. This encryption will prevent other users from connecting to your wireless network. It will also protect your wireless transmissions from being accessed by other users.
NOTE: In case the screen on your router's web-based setup page looks different, click here.
Step 1:
On Security Mode, select WEP.
Step 2:
Under WEP Encryption, select 40 / 64-bit (10 hex digits) and enter a unique word in the Passphrase field.
NOTE: The 128-bit key uses a higher level of encryption compared to the 64 bit WEP. It uses a 104 bit (26 Hex Character).
Step 3:
Click the Generate button and copy the string of letters and numbers displayed in the space provided for Key 1. The Key 1 contains the wireless password.
NOTE: You can also create your own Wireless Password (Key 1) given that it is in hexadecimal format. The hexadecimal system consists of the characters 0,1,2,3,4,5,6,7,8,9,A,B,C,D,E, and F. You can only choose 10 characters (in any given order) from that set.
Step 4:
Click kb19073-007_en.png.
Wi-Fi Protected Access (WPA)
Wi-Fi Protected Access (WPA) is a Wi-Fi standard designed to improve the security features of WEP. WPA is stronger than WEP encryption. PSK and PSK2, the two types of WPA, give you a choice between two encryption methods: the Temporal Key Integrity Protocol (TKIP), which incorporates Message Integrity Code (MIC) to provide protection against hackers, and Advanced Encryption System (AES), which utilizes a symmetric 128-Bit block data encryption.
NOTE: For older versions of Linksys routers, WPA Personal is also referred to as WPA Pre-Shared Key. Refer to the image below for an example.
To set up WPA Personal on a Linksys router, follow the steps below:
Step 1:
On Security Mode, select WPA Personal.
NOTE: If you are unable to find the WPA Personal or WPA2 Personal in the list of choices for the Security Mode then you might need to upgrade the firmware of your router to its latest version. Upgrading the firmware can fix the bugs of the previous version and update its other features.
Step 2:
Enter your Passphrase.
NOTE: The Passphrase must consist of at least eight characters and is case-sensitive.
Step 3:
Click kb19073-011_en.png.
Sep 19, 2011 | Linksys Wireless-G WRT54G Router
Where can I find the WPA or WPA 2 Key on my Cisco N?
The router's password is a Passphrase or the WEP or WPA orWPA2 encryption key. The Passphrase generates the WEP or WPA or WPA2 encryptionkey and this is in the router's wireless settings. To connect to your wireless router, it needs the router'swireless settings configured ie SSID, WPA or WPA2 encryption key and also thewireless cards in all the laptops and or computers needs to be configured withthese router's wireless settings. Then the laptops and desktop computers cancommunicate with your wireless router.
Mar 19, 2011 | Cisco Linksys Wireless N Home Router...
Have a wireless arudter by linksys model #wrt310n v2 can t get my wii on line er c 51330 need help
well what you need to do is go to the wii settings then find internet then use connection 2 use wireless then it ll ask to search for the router then select the router your using then security code down it could be wpa-psk or wep key then input that code and then it should want to upgrade it self then it should jump back to the wii main menu
Jan 11, 2010 | Video Game Consoles & Games
Were would i find the wep key or the wpa for the WUSB54GSC Wireless -G USB Network Adapter/
The Wep Key is located in the wireless router settings and will not be found on the network adapter. The network adapter needs the wep or wpa key to connect to the wireless router. You will need to use a computer hooked up directly to the router and enter the router settings menu to find or change the wep or wpa key. Most routers use or to enter the router menu. When you input the IP address above a screen should come up asking for a username and password. Enter those and that will allow you to get into the router menu. If you do not know the username and password you can reset the router with the reset button and that will restore the default password which is usually no username and password is admin.
Oct 16, 2009 | Linksys WUSB54GSC Compact Wireless-G USB...
Ok so I have a wireless adapter and I recently lost the password for it I was wondering if you had anyway to reset it or find it. I know it was just a bunch of letters and numbers nothing I set up.
The password you are referring might be WEP or WPA which assigned by your router. So you need to reset your router not the Wireless adapter. After you reset the router's Network Key (WPA/WEP)
You can reset your Range extender too; Press the Reset button on the back of the Range Expander for about ten seconds. This will reset the unit to its
default settings
Good Luck
Nov 10, 2008 | Linksys Wireless-G Range Expander (WRE54G)
Orange livebox
a bit confused with the question. This question is listed under "network hub" meaning you have a physical cat5 cable running to the xbox 360. and the xbox 360 is asking for a WPA key.
WPA is one of the standards for wireless security. please clarify the question and let us know more about your home network.
Jan 03, 2008 | Linksys (NH1005) 5x10/100 Mbps Networking...
Network key
Can you go into your router from IE? like http://192.168.x.x, then from this configuration page of your router you can find what key you had put into your router. Make sure the type of security you are using like WEP, WPA, PSK, WPA2 etc. This key should match on your desktop or laptop machine to gain connection to your router.
If you are unable to find your key like this then:
You could refresh your router to factory defaults by pressing for 5 seconds, you will find this hole at the back of your router. try going again into your router like I said above and make up any other key.
Hope that helped!
Dec 07, 2007 | U.S. Robotics MAXg USR5461 (738168036790)...
Linksys (NH1005) 5x10/100 Mbps Networking Hub Logo
318 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
