Question about Sony FD Trinitron WEGA KV-36FV310 36" TV
Tv takes a minute to get picture
My tv takes a minute or so to get a picture when it is first turned on the audio is fine but there are what seems too be grey sparks then the red light flashes 3 or four times then the video goes on and stays on.............. i just bought it used so i was wondering if this is normal
  • 232 Answers
Greg , Sounds like a bad "jungle IC" but without knowing specific voltages it`s really hard to say, picture should show up in approximately 15 seconds not a full minute, it`s normal for the audio to be heard almost instantly way ahead of the video, part number for the IC is 875210104, generic number is cxa2154as, be prepared they are not cheap IC`s, I would probably run the set for awhile and see if it gets worse as time goes by. good luck
Posted on Nov 27, 2007
My Sharp LC-42SB45U takes 15 min to an hour to turn on. Also, sometimes picture blacks out for 10-15 seconds. Any suggestions? Pat Courson
Have same problem. Not the proper fix though I found that taking the back off and heating it up with a heat gun for 30 seconds to 1 minute and tv works fine till you shut it off over night.Maybe someone can offer a solution with that in mind. Pretty strange
Sep 17, 2012 | Sharp LC42SB45U 42 in. LCD TV
No sound
Sounds like a loose connection that has finally failed in the audio out circuit
Jun 04, 2008 | Hitachi 61HDX98B 61" Rear Projection...
I have a 2 year old LG LCD TV (model 42LG60) and I am having problems with the screen. I turn it on and everything is fine for a few minutes and then the screen goes to red or green lines that are fuzzy....
Not really a solution, sorry, but I've got the very same problem. I haven't noticed the time before tv faults, but nontheless, it greenscreens or like in your case, redscreens as well. I've been told to open the back, which I did to check the status of the capicitors, which I've done. But, the capacitors "seem" fine. No bulging or popped tops. So, I'm at a stand still...not sure what to do at this point. If someone gives you solution, I sure would appreciate your forwarding it on to me. Thanks. Robert
Oct 23, 2011 | LG Scarlet 42LG6000 42 in. HD-Ready LCD TV
I have a Sony KP-48S35, Rear Projection TV and the picture goes on and off but the audio works fine. When I first turn the TV on, it takes around minutes for the picture to even come on.Which meens for...
i would say the bulb is on its way out and needs changing. on the back there is a hatch with one screw remove the screw and unclip the bulb holder, then pull out by the handle part number is on the bulb housing or the tv case.
May 23, 2017 | Sony KP-48S35 48" Rear Projection...
Take out the plug and hold down the power button on the TV itself down for a minute then plug it back in and turn on your TV it should be working perfectly fine after that.
Sep 17, 2010 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Sound takes up to an hour to come on, Mitsubishi 35'' tv
A $700 dollar estimate for a sound problem seems out of line - get asecond opinion (did some one look at it or just a guess). If the sound eventually comes on you probably have a connection (internal) problem or a intermittent part in audio section -cap o/p IC.
If you use a satellite or cable box can you hook your sound from that to an audio system thereby bypassing the TV?
Sep 30, 2009 | Mitsubishi CK-35308 35" TV
Picture goes out right after turning on, have to
My 3 year old Sharp LC-40C32U would start up fine but within a minute would go dark (audio continued fine). For a while I could turn the set off and on again and it would be fine, but over time this became less effective. My solution, which has worked for a week now, was to a) unplug the set's power cord; b) after 3 minutes plug it back in and turn the set on; c) on the remote hit MENU and slide over to SETUP (3 clicks to the right if the screen is dark) and one up to RESET; d) hit ENTER and follow the prompts. This puts the set in it's factory configuration so you will have to rescan for channels. Worked for me.
Sep 24, 2009 | Sharp AQUOS LC-40C32U 32 in. LCD TV
Picture fades in and out
filament circuit look for glow neck of crt. make sure socket on firmly.
Dec 02, 2008 | Samsung TXE1986 TV
TV quits after a few minutes-get a blue screen, no picture and no audio
My best recommendation is to pull the back off it and blow the dust out. Dust is electrostatically attraced to the components inside and acts like a blanket. This causes overheating. Remember to leave your tv unplugged for at least an hour before taking the back off as the CRT (picture tube) will store a charge which can kill you.
Dec 30, 2007 | RCA T19408 19 in. TV/VCR Combo
Delay to see the picture
Your power supply is going south, I have an old sony with the same problem. The voltage level drops and does not have enough 'kick' to start. It will work better when it is warm. The module will need to be replaced.
Nov 29, 2007 | Sony KV-27XBR45 27" TV
Sony FD Trinitron WEGA KV-36FV310 36" TV Logo
79 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
