Question about Kenmore 62702 Microwave Oven
Replacing the Control Panel
The control panel looks like it will be fairly easy to replace without major disassembling on my Kenmore over the range microwave #66568601891, is this true or am I in for a treat. :)
    Champion:
  • 249 Answers
It should easy if you follow the wireing on the faulty panel,take your time.
Posted on Nov 28, 2007
No power
Depending on the brand and full model number, it may.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
Also at our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you don't find yours, or if you want to look at it without disassembling the oven, you can download many brands' mini-manuals here.
Sometimes the problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid with aone year guarantee.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights can can be inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly affect the fan operation or inside light, too.
Jul 09, 2010 | Hotpoint RVM1535MMSA Microwave Oven
The microwave won't stop beeping
Your membrane keypad has failed. I'm guessing it's giving an error code of F2 also?
On the KHMS155LSS# models, the membrane keypad is available as part of the control panel frame assembly which comes with a new keypad.
Replacing this is actually a pretty easy do it yourself job.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Next, disconnect the keypad strip as shown in the photo below, then remove the screws that hold your circuit board in the old frame.
Then carefully (since the display is made of glass) move your circuit board to the new frame, and reassembly is the reverse of disassembly.
You can get the control panel assembly here.
You can also find helpful exploded view diagrams at that link.
Just enter your model number (as KHMS155LSS# for example where # is the last digit) without the dash.
Jul 06, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Keep getting f3 error message
F3 means you have a shorted membrane keypad.
It all depends on the full model number, but on some, the keypads can be replaced separately, and on other models, it only comes with a new control panel frame.
Replacing this as an assembly is actually a pretty easy do it yourself job.
Just enter your full model number without any dashes.
If the keypad must be replaced on the existing frame, it's a much harder job. I have uploaded a handy guide with pictures showing you what's typically involved.
We do that job for $39.95 plus part cost and shipping.
Feel free to contact me directly (and please remind me of your full model number) for more DIY help or a free estimate.
William E. "Ed" Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Jul 06, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I have a GE microwave and F3 has just come up on the display screen???
F3 Shorted key panel (touch pad).
1. Will occur if a shorted key panel is detected continuously over 60 seconds.
2. Replace key panel (touch pad).
What you can first try before replacing the keypad is first unplugging the microwave. Then you can get access to the panel by first removing the top grill and then unscrew the top of the control panel. There is a strip that looks like tape which attaches to the control panel which you need to wipe off and then blow dry. may not work the first time but be patient. also clean the bottom of the door and the latches to make sure the connection is clean. After that is should hopefully work without replacing the touch pad.
Let me know how this works out for you.
Benjamin
Apr 26, 2010 | GE Profile Spacemaker Over-the-Range...
My over the range microwave oven light(underneath) does not work. The bulbs were tested, they are OK. Is there a fuse to replace?
Maybe. In some Whirlpool models there are several fuses.
If you don't find yours, or if you want to look at it without disassembling the oven, you can download it here.
I doubt that it's a fuse, though. We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week or so.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
Microwave Oven Control Panel Repair Nationwide
Jan 09, 2010 | Whirlpool Microwave Ovens
NTC cover message after replacing fuse in my whirlpool microwave MH1170xsb
The "negative temperature coeffecient" (NTC) thermistor was left unplugged after reassembly or it is defective.
It is the hood thermistor, and should be plugged into connector P4 on the circuit board.
I think it should be at the bottom of the board, on a little tongue-like protrusion, as shown in the attached photo.
If you don't find yours, or if you want to look at it without disassembling the oven, you can download it here (just enter your model number).
You can also find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Aug 16, 2009 | Whirlpool MH1170XS Microwave Oven
Microwave oven will not heat. Everything else works.
With the symptoms you
have, especially with that pop, I would most strongly suspect a shorted high voltage rectifier
diode.
The diode is a fairly cheap & easy fix.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
d:%5cele%5crepair%5cmicrowave%5cge_hotpoint%5cmini_manual_behind_grille_small.jpgdee77f7.jpg
Here are some links you
or someone you know can use for test help, but read their safety
warnings first:
http://www.microtechfactoryservice.com/diode.html
(if it\'s not shorted or burned, it\'s probably okay)
http://www.microtechfactoryservice.com/cap_test.html
http://www.microtechfactoryservice.com/mag_test.html
http://www.microtechfactoryservice.com/xformer.html
You can usually find
exploded views and order parts by entering your model number
(665.68611891) at the Sears parts site.
We\'re happy to help you with free advice and we\'d appreciate your thoughtful rating of our answer.
Mar 03, 2009 | Kenmore Microwave Ovens
Kenmore galaxy microwave model 721.80002 1500 watts does not heat
With the symptoms you have, I would most strongly suspect a shorted high voltage rectifier diode or a bad magnetron, or a loose and possibly corroded connection on the magnetron's terminal.
The diode is a fairly cheap fix, and the mag will cost more.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/diode.html (if it's not shorted, it's probably okay)
http://www.gallawa.com/microtech/mag_test.html
http://www.gallawa.com/microtech/xformer.html
Dec 19, 2008 | LG MV-1444Y Microwave Oven
JENN Air bulb replacement problems
We see (and repair) this a lot. The problem is indeed on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week.
At our site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa.
Feel free to contact me directly (and please remind me of your model number) for more information & help.
William E. Miller
prototech@usa.net
Nov 08, 2008 | GE JVM1850 1000 Watts Microwave Oven
Kenmore microwave range hood model 665.61612100 manufactured 2001
The problem is likely on the control panel, which we repair nationwide for $39.95 postpaid.
This often can affect the exhaust fan operation, too. The lights and fan can be inopoerable or stuck on.
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Oct 13, 2007 | Kenmore 62622 Microwave Oven
Kenmore 62702 Microwave Oven Logo
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
