Question about FIRST Computers & Internet
First 3 rows of combo lock are 0thre 9 next two rows are k thrust need choices
2 Suggested Answers
SOURCE:
  • 92 Answers
SOURCE: Cant unlock combo lock
cut the lock
Posted on Dec 15, 2008
Cell freeze 3 rows together at a time.
Freeze a Row in Microsoft Excel
Microsoft Excel 2010 can freeze, or lock, a top row as you scroll down the worksheet.
For example, you may need to keep the top row of column titles visible at all times.
The "View" tab on the command ribbon contains the "Freeze Panes" button in the "Window" group.
A single row or a range of rows can lock through the "Freeze Top Row" or "Freeze Panes" options.
Open the Excel worksheet.
Click the top row heading.
The row heading displays a number just left of the first column of cells. The selected row appears shaded.
Click the "View" tab on the command ribbon.
Click the "Freeze Panes" button in the "Window" group.
A list of options appears.
Click the "Freeze Top Row" option.
A black horizontal line appears on the worksheet.
This line indicates the locked row that stays on the screen as you scroll down the worksheet.
http://office.microsoft.com/en-us/excel-help/freeze-or-lock-rows-and-columns-HP010342542.aspx?CTT=1
Freeze or lock rows and columns
also
Use Freeze Panes in Excel
Scrolling down to look at a number and then scrolling up to make sure the number you looked at is under the header you expected is not an efficient way to view a spreadsheet.
The Freeze Panes feature of Excel allows you to freeze the labels of your data in place while you review the data.
Follow the instructions in Section 1 to freeze the top row or the left column.
Freeze multiple rows, multiple columns, or rows and columns, by following the instructions in Section 2.Freeze the Top Row or Left Column
Open the Excel spreadsheet.
Navigate to the "View" tab on the top menu.
3 Click on "View," then click on "Freeze Panes." A drop-down menu opens.
Select the "Freeze Top Row" option to freeze the top row.
5
Select the "Freeze Left Column" or "Freeze First Column" option to freeze the left column.
6
Freeze the top row by using the keyboard and sequentially pressing the keys "ALT, W, F, R." Ignore Steps 3 through 7 if using this choice.
7
Freeze the left column using the keyboard by sequentially pressing the keys "ALT, W, F, C." Ignore Steps 3 through 7 if using this choice.
8
Unfreeze panes by repeating Steps 3 through 5 and selecting "Unfreeze Panes" or sequentially press the keys "ALT, W, F, F."
Freeze Rows and Columns, Multiple Rows, Multiple Columns, or Multiple Rows and Columns
9
10
Freeze column(s) and row(s) at the same time by selecting the cell to the right of and below the location you want to freeze.
11
Freeze multiple rows only by selecting the cell in the left (first) column below the rows you want to freeze.
12
Freeze multiple columns only by selecting the cell in the top row to the right of the columns you want to freeze.
13
14
15
Select the "Freeze Panes" option. You have now frozen the columns or rows, or columns and rows you designated.
16
Freeze panes using the keyboard by sequentially pressing the keys, "ALT, W, F, F." Ignore Steps 5 through 8 if using this choice.
17
Unfreeze panes by repeating Steps 5 through 7 and selecting "Unfreeze Panes" or sequentially press the keys, "ALT, W, F, F."
http://office.microsoft.com/en-us/excel-help/freeze-or-lock-rows-and-columns-HP001217048.aspx
http://office.microsoft.com/en-us/excel-help/demo-hide-or-unhide-rows-and-columns-HA010241040.aspx
Hide or show rows and columns
Aug 14, 2013 | Microsoft Office Computers & Internet
How to use RecZone password vault to change from alphabetical to numberical
on the reczone password vault you can enter numbers. on the button with 1@/.:, if you press the button once you will see @ entered. press the button 2 times quickly to enter a /. press the button 3 times quickly to enter a . press the button 4 times quickly to enter a :. press the button 5 times quickly to enter the number 1. press the next button 4 times quickly to enter a number 2. press the next button 4 times quickly to enter a number 3. press the next button 4 times quickly to enter a number 4. press the next button 4 times quickly to enter a number 5. bottom row: press the first button 4 times quickly to enter a number 6, the next button 5 times quickly to get a number 7, the enxt button 4 times quickly to get the number 8, the next button 5 times quickly to get the number 9, and the last button on the bottom row press it 4 times quickly to enter a number 0. pressing caps lock does NOT switch it from alpha to numeric mode. caps lock only gets the letters entered in UPPERCASE.
Nov 30, 2011 | Computers & Internet
Evinrude "high thrust" 1998 model just bought boat
Hi, replace the sparkplugs and the carby(s) will probably need stripping down and cleaning as stale fuel leaves a residue in the bowl and jets. Hope this helps, regards Phil.
May 31, 2011 | Yamaha Boating
Need to know location of all fuses that corespond with the clock and radio and cassett player
On the driver side fuse box, you have 5 larger fuses.
You have rows of 9 fuses across. In these rows, the far right fuse in the 3rd row down is the radio cluster fuse. This should be a constant on fuse that provides power to the clock and keeps power for the memory preset stations. The next to last fuse in the 4th row down is the radio fuse. This one looses power when the key is turned off.
I hope this helps. God Bless.
Apr 06, 2011 | 1997 Buick LeSabre
I set my lock code on my master lock speed dial lock and it wont open to the combo and i wantto know if i can reset it or something
if the lock is locked up and the combo that you set it to is not working then I would say that there might be a problem with the lock itself. I would suggest returning to the store that you bought it from and exchange it for a new one. if you want to try and get the lock open - you can try and progress the numbers, since you already have a combo set, this is a little easier then if you didn't have a combo at all. try setting the lock to the combo that you selected, starting with the first number - rotate the first wheel to the next number and try the lock and then to the next number and try the lock, when you get back to your original number, go to the next wheel and rotate that one around to every number ( testing the shackle everytime you get to a new number )---- repeat this process for the next two number wheels,, hopefully this will work,, but again it could be a broken wheel and I would just exchange it for a new one and start fresh.
here is an example of progression --- 1973 ( combo set )
1974,1975,1976,1977,1978,1979,1970,1971,1972 --
1983,1993,1903,1913,1923,1933,1943,1953,1963,---
1073,1173,1273,1373,1473,1573,1673,1773,1873---
2973,3973,4973,5973,6973,7973,8973,9973,0973 ---
I just used 1973 for an example -- if you want a more exact progression chart tailored to your combo, just let me know and I can write it up for you.
c...
Jan 03, 2011 | Locks & Locksmithing
THE KEYS ARE ALL SWITCH TO DIFFERENT CHARATERS WHEN I PRESS M GIVES ME 0
ok here from left to right top row esc f1 f2 f3 f4 f5 f6 f7 f8 f9 f10 f11 f12 prtscrn scrolllock pause second row ~ 1 2 3 4 5 6 7 8 9 0 - = bkspc insert home page up num lock / * - third row tab q w e r t y u i o p [ ] \ del end pgdn 789+ fourth row caps lock a s d f g h j k l ; ' enter 4 5 6 fifth row shift z x c v b n m , . / shift up 1 2 3 enter bottom row ctrl windows key alt spacebar alt windows right click ctrl 0. hope that helped
Oct 11, 2009 | Compaq Keyboard
I need to locate the 2004 saab 9-3 the radio fuse
Hi I'm litoshop in the fuse block on the left hand side of the driver seat behind panel fuse #3 on the first row that has 9 fuses and on the next row fuse # 14 it will be the 5th fuse good luck if this information has been useful please let us know thank you
Sep 15, 2009 | 2004 Saab 9-3
Is a minn kota 35 suitable on a 10ft rowing boat . I normally row on my local lake when fishing , each trip consist of no more than 1 hour of rowing
I have a 30# thrust and it pushes my 14' jon boat well. I think a 35# motor should work well for your boat, unless there are very high winds, in which case, any motor will have trouble, even your outboard.
Jun 07, 2009 | Boating
Computers & Internet Logo
15 people viewed this question
Top FIRST Computers & Internet Experts
Bill Boyd
Scott Campbell
Scott Campbell
Dan Apthorp
Are you a FIRST Computer and Internet Expert? Answer questions, earn points and help others
