Question about 2wire (1000-400108-001) Router
2wire modem/router keeps rebooting
Hi ive got a 2wire wireless modem/ router the problem im haveing with it is that it keeps rebooting its self.this is on an adsl connection.any ideas
  • Anonymous May 06, 2009
    i have same problem
  • 3 Answers
ANOTHER COMMON ISSUE: If your modem keeps restarting once the power LED turns solid green, the most likely cause is the power adaptor. Replace the power adaptor and all should be well again.
Posted on Jul 29, 2008
    Problem Solver:
  • 10 Answers
Its possible thats its not properly configured :like time out is not set to zero or higher,2nd:probably needs an upgrade for software version,3rd better contact your isp provider to check if line issue,....however if isp says not line issue then most probably it just needs to be reconfigured so i strongly recommend you could call your isp or att since there tech support for it...i hope you'll have it fixed already
Posted on Nov 28, 2007
How to install to att 2wire 2701hgb modem router
Plug one end of an Ethernet cable into the modem's Ethernet output port and plug the other end into the router's single WAN/Internet input port.
Nov 09, 2017 | NetGear RangeMax Dual Band Wireless-N...
Plug power cord into back of modem and then into an electrical outlet. At this point you should see the lights on the front of the modem beginning to come on.
Check the front of the modem for a solid green DSL light. If the light is still blinking, allow a few more moments before proceeding to step 5. A blinking DSL light indicates a break in the network and will require the help of your service provider if it does not turn solid green.
Open your internet browser and type the default gateway into address bar. The default gateway will be provided by your service provider. Newer model 2Wire modems automatically direct you to the installation instructions when the browser is opened.
Click on "Run System Setup Wizard" in the lower right-hand corner. It may require the system password. This password will be provided by your service provider.
Select your timezone and click 'Next.'
Enter your ISP provided login information and click 'Next'. This should authenticate your credentials on the network and complete the installation.
Jan 02, 2013 | NetGear RangeMax Dual Band Wireless-N...
2wire 1701 hg dsl connection drops when laptop is connected via wireless
This is a known issue with this model.. The power supply is not large enough to handle the extra current that is needed when the unit broadcasts on wifi.
May 05, 2017 | 2wire Computers & Internet
How do i setup my 2 wire router with dsl modem to network iat home
Try this links:
2wire installation guide: http://support.2wire.com/?page=view&article=765
changing wireless settings: http://support.2wire.com/?page=view&article=60
wireless configuration guide for windows XP: http://support.2wire.com/?page=view&article=224
wireless quick reference guide: http://support.2wire.com/?page=view&article=47
note: 2wire is already a wireless router / modem need for other modem to have a good network at home
AT&T ' Yahoo! High speed Internet
Call +1 877 722 3755 (877-SBC-DSL5)
Aug 12, 2011 | 2wire (2701HG-B) Wireless Router
My iphone keeps dropping the "password" for my 2wire router. Then anytime I do something that requires the router to do some things it shows that Im NOT connect to my Wi-Fi in my house. How...
first check for any computer that is connected to you modem.
try to access your modem gui or software
since you have a 2wire modem go to the wireless setting page
then configure your wireless settings
you can call your isp for the correct wireless setting configuration
May 27, 2011 | 2wire (2701HG-B) Wireless Router
I have a small problem with a Belkin N1 wireless router modem, we used to have a 2wire modem (basic telstra one with 1 ethernet prot) and that seemed to be faster than the new Blkin modem, when im running...
Very possible that the 2Wire is slower. I have had a ton of complaints about all kinds of 2Wire devices. As a suggestion though, check their tech support site to see if there may be a firmware or driver update for the modem. I had a Linksys router once that kept kicking me off and was crazy slow when it was up and working. A firmware patch fixed both.
Aug 30, 2009 | Belkin N1 Vision Wireless Router
Have SBCglobal with 2wire but want N wireless capability
Follow the dots -
2 wire DSL wire to back of DSL modem.
Ethernet cable out of DSL modem, to current router (if you have one).
Ethernet cable out of current router (if you have one) to new Wireless N router.
If you currently have a wireless G router, keep it, or, use the new Wireless G/N router alone. You will need to set up all security settings again if you remove your current router, and if the new router is N only, you will need to make sure all your wireless connecting computers have wireless N cards in them.
Jan 24, 2009 | 2wire 2700HG-B Router (2700HGB)
CAN A 2WIRE DSL ROUTER WORK WITH A CABLE INTERNET CONEECTION
The 2wire dsl modem/router cannot be use with a another cable modem , since this 2wire device is also a modem/router and its made for the DSL conenction that's why it wont work with Cox cable, the best thing that you can do is to ask Cox to give a wireless modem/router like this 2wire so you can still use the wireless connection of your computer..
Hope that helps..........
Sep 06, 2008 | 2wire (1000-400108-001) Router
Modem reboots when using wireless
Did you try upping your lease time and see if that changes things.
The lease time is the amount of time before a DHCP request a new IP address.
Ususally it get the same, but if it is malfunctioning it can cause problems like this.
Jul 15, 2008 | 2wire (1000-400108-001) Router
2wire dropping xp pc
hello!
you may try this and see if this help solve your problem
Step 1try to connect your computer directly to the modem and check if you will also experience problem
Step 2: Shutdown the computer.
Step 3: reset the router while power on then Unplug the router’s power cable.
Step 4: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 5: Plug in the Broadband modem’s power cable and wait for its lights to appear
stable.
Step 6: Plug in the router's power cable once the modem’s lights appear stable.
Step 7: Power on the computer on and configure router settings if neede
Step 8:test the Internet connection.
if this still didnot work, maybe you need to upgrade the firmware of your router
May 01, 2008 | 2wire (1000-100052-000) 802.11g/b Wireless...
2wire (1000-400108-001) Router Logo
2,528 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
