Question about Canon PIXMA MP530 All-In-One InkJet Printer
Refill catrdiges for Canon 530 multifunction prointer
How can I avoid problems with inkjet refil cartridges-particularly with ourCanaon MP530 Multifunction printer that gives error messages when a refilled OEM catrdige is installed? Thanks
I allready raported the problem that MP 530 does not scan or do anything before I buy a new cartridge. How can I pass this demand after refilling the cartrige or installing the continious ink system?
Anu Suomela
Helsinki
Finland
  • fred4051 Apr 13, 2008
    Yes I Have the Same problem, When I refill catrduges The Cannon MP530 will not reconize the refill.
  • Anonymous Apr 23, 2008
    my canon 530 will not recognize that I installed a refilable ink tubs
  • Canon Master
  • 1,113 Answers
Drivers are on canon site under Multifunction but here is direct link
http://software.canon-europe.com/products/0010324.asp
These printers are not keen on being refilled
No bypass that I know of ...refills just cause printers to die a earily and inferior quality death.
Posted on Dec 30, 2007
Karatela, your copy n' paste answer doesn't help.
I'm not sure if you work for one of the companies that you link to, but you could at least attempt to check your links.
I did not find any drivers for MP530 online...even on the Canon site.
Posted on Dec 27, 2007
  • 38 Answers
There are possibilities that you might not have installed the ink cartridges properly or the drivers might not be working.
Here is a link for a manual click here
Here is a link for drivers click here
Posted on Dec 07, 2007
I can't afford new ink for my Canon MP530 just yet, but want to still use the scanner? Is this possible?
yes it is possible, you have 2 solutions for your problem.
1. Refill the cartridge and use it refilled.
2. Dont refill the cartridge and use it like that. BUT when the erro E 1 6 appears you will find on the printers control board you have a buton that is called Resume/Cancel, it is the buton near the copy black and copy color butons. You can recognize it by the red triangle in a red circle.
Press this buton for at least 10 seconds, if the error is not gone from the first time press and hold the buton for at least 10 seconds for the second time.
Now the printer will have the ink level counter disabled but do not worrie it will worj just as well.
Nov 19, 2010 | Canon PIXMA MP530 All-In-One InkJet...
Won't scan. alarm light is on say's out of ink but has been refilled all buttons when pushed dubble beep.
Your refilled cartridge didn't get the ink level chip reset. Your printer will refuse to print, scan, copy, etc.. until you replace the cartridge that's "empty." I would return the cartridge to the refiller you purchased it from and buy a refill from Cartridge World. These simple problems do not happen with Cartridge World refills.
Jan 19, 2010 | Canon PIXMA MP530 All-In-One InkJet...
Canon mp 530 error u043 cant get rid of it
It is registering a empty ink cartridge. If you had the cartridge refilled instea of replacing the cartridge that is what happened. The chip on the cartridge wont register the refilled ink and tells the printer it is empty.
Oct 01, 2009 | Canon PIXMA MP530 All-In-One InkJet...
I NEED TO KNOW HOW TO REFILL INK FOR A CANON MX310 #41 COLOR.i DON,T KNOW IF YOU PRY THE TOP OFF OR IF THERE ARE SOME REFILL HOLES SOMEWHERE.SHIRL85@EMBARQMAIL.COM
Your printer uses the following cartridges:
canon-pg-30
Black Pigmented
canon-cl-31
Color
canon-pg-40
Black Pigmented
canon-pg-50
Black Pigmented canon-cl-41
Color
canon-cl-51
Color
ou find the refill instructions for your cartridges in the book at the link below:
Download Inkjet Refill Instructions
You can also buy refill kit here: inkjet refill products.
You also need to reset the cartridge after refill, see: Reset Ink levels for canon mx310 - FixYa
Mar 02, 2009 | Canon PIXMA MX310 All-In-One Printer
PM530 printer: PGBK cartridge not working. Just
Clean the feeder use Que tip With Alcohol only let it dry and clean the cartridge the same way replace the That should solve the problem, Also keep in mind if you are using a cartridge that is a refill The cartridge sometimes dry out Have that checked it might be bad other words plugged up. Good luck with it
Feb 21, 2009 | Canon PIXMA MP530 All-In-One InkJet...
I am trying to reset the empty ink cartridge error code on a Canon mp-530 multifunction printer after installing a refilled a refilled black ing cartridge
Hi, did you refill yourself or did you buy a refilled cartridge. If you purchased a refilled cartridge and the chip is missing, you will need to take the chip off your old cartridge and install on the refilled cartridge.
Jun 21, 2008 | Canon Office Equipment & Supplies
How to refill Canon FX3 Laser Toner Cartridge
I drilled the hole on the side with no handle. I put packing tape over the hole and it worked fine. I'm refilling it again right now... Good luck, have fun, and save some $$$!
Mar 08, 2008 | Epson Stylus Multifunction Inkjet Printer/...
How to remove the ink cartridge from the wrong slot for canon mp530
halo dear
for mp530, you can use a plugins catridge ... as cahnge your chips original , after use that you can refill your catrigde as well
the price about $4-5
try this site for clear information
http://exchangerate.ws/inkjetprinter.php?printer=Canon+PIXMA+MP530&lazySID=LcuxpiHFCsshJVujrrruBaNoo1203340519
oke
thks
cropp
Feb 29, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Your printer drivers may not be installed properly
Here is a link for
Manual click here
drivers click here
Nov 25, 2007 | Canon PIXMA MP530 All-In-One InkJet...
Canon PIXMA  MP530 All-In-One InkJet Printer Logo
261 people viewed this question
old marine
old marine
