FixYa.com
Tags:
Home Theater Speakers and Subwoofers
Generic problem for all Home Theater Speakers and Subwoofers
Buzzing Cerwin Vega LS-12 Subwoofer (by 5 users)
posted by Vince3962 on Nov 27, 2007
There is a constant loud buzzing when I turn my subwoofer on (regardless of whether there is anything playing). Any thoughts on how to fix it?
Comment by Vince3962, posted on Nov 28, 2007
Great
Great thoughts. I did as you instructed. Unfortunately, the loud buzzing sound remains. The buzzing occurs anytime the speaker is "on," regardless of whether it is even plugged into my receiver.
Any other suggestions?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
4 Other Users Have The Same Problem
Comment by Guest, posted on Jun 01, 2008
NONE
Comment by Guest, posted on Feb 06, 2008
Hi.
I had the same problem. It is most likely a bad ground in the home wireing. A temp solution is to stop the ground connection in the 120 input to the sub. you can do this by putting a non conductive like clear plastic over the ground prong and slide the plug part into place. I did this and it works well. Just need to get the master electrician over to fix the bad ground in my breaker box now.
Comment by DViper2399, posted on Feb 03, 2008
Same exact problem!
Comment by lbstarfish, posted on Jan 06, 2008
Loud buzzing noise coming from the subwoofer even when the television is off. I must turn off the speakers to stop the noise.
Best Solution
posted on Nov 27, 2007
Helpful (85)
likwidstate
Rank:Master Master
Rating: 73%, 12 votes
Generally, a buzz from your sound equipment indicates some sort of nearby EMI. The normal culprits and.or possible fixes that I've found are:
- Remove any other electronic devices plugged into the same outlet as your subwoofer
- If the woofer is on a power strip/surge protector, remove it and plug directly into the wall
- If there are any nearby wireless devices (cordless phiones, WiFi eqiupment), disconnect/power down them
- Try connecting different speaker wire between the woofer & the receiver
- Try turning off all other eletronic equipment with the exception of your receiver
Let me know if any of these help and good luck!
Comment by likwidstate, posted on Nov 30, 2007
Maybe this might help? It's a quick story of a similar problem I had with my amplifier speakers:
Back in high school, I used to play electric guitar. One day, I noticed a low humming that seemed to become more & more apparent as the days went on.
It eventually got bad enough that I took apart the amplifier. After some visual examination, I noticed a wire whose insulation had melted away from resting against one of the vacuum tubes during operation.
Upon wrapping the faulty sectionin electrical tape and powering the unit back on, I noticed (to my delight) that the humming was finally gone.
Rating Locked! (?) Vince3962 has rated this solution as Helpful
Solution #2
posted on Mar 06, 2008
Not Rated (0)
dredlox
Rank:Apprentice Apprentice
Rating: 100%, 1 votes
i also had a problem with buzzing on my eltax atomic a8 weather the amp was switched on or off.
i followed many solutions and the one that worked was isolating the earth pin on the plug.
now not even a hum
Was this solution helpful? Show your Appreciation by rating it:
Solution #3
posted on Feb 23, 2008
Not Rated (0)
AshbyBill
Rating: 0%, 0 votes
If it's not interference or a ground problem it might be a bad amp. I have the same sub and not only did I have the buzzing, but also a noticable "whacking" sound instead of smooth bass. I found an online seller who at the time just happened to have obtained some surplus Cerwin Vega amps that fit perfectly. Paid $60 shipped. Problem solved.
Solution #4
posted on Dec 13, 2007
Not Rated (0)
icecool667
Rank:Master Master
Rating: 78%, 13 votes
There is too much electrical feed back coming from your earth, you can install a line level filter, or get an electrician to do it. Or you can remove the earth pin on your subwoffer.
I have done this to many subwoffers and it worked every single time.
This Problem Also Relates To: Jensen JS800 Subwoofer Jensen JW250 Main / Stereo Speaker Kenwood KVS-64 Speaker Jensen JPS12 Subwoofer Sony 12" 200-Watt Powered Subwoofer Sony SA-VE315 Speaker Sony SA-WM20 Subwoofer
Can you Help with these Home Theater Speakers and Subwoofers problems?
RCA WSP155 Main / Stereo Speaker
RCA Wireless speaker
One of my speakers will not... Answer This...
Bose Cinemate Digital Home Theater System...
unable to find code for the...
I have a Dish DVR 625 and I am... Answer This...
Bose Acoustimass 15 System
Acoustimass V20 will not power...
We just bought (used) this... Answer This...
Durabrand HT-3915 System
need to buy a new remote...
need a phone number to call to... Answer This...
Logitech X-140 Speaker
I can't install my Logitech
I can't install my Logitech... Answer This...
Repair Service
Find Home Theater Spe. Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
