Question about Lexmark C760 Laser Printer
Magenta printing streaked
By quizing lexmark we are told to check a few things one item is "Clean the Hsync Mirror" lookinng in your mannual and at lexmark the location of this does not show where would we look for it ??
  • rbabler Feb 28, 2008
    Replacing the toner did cure the trouble took but took forever to get replacement through Lexmark!!
  • 94 Answers
It can be toner cartrige problem.
their was a lot which had manufacturing defect.
pls gte it replace free fm vendor
Posted on Feb 28, 2008
  • Girish P May 05, 2008
    Push your case to lexmark and u should get free toner eplacement, as this is manufactuing isse and they do give it.
Not printing magenta
Print quality issues could be due to dirty or clogged print cartridge nozzles. Please follow the steps below to improve the print quality:
On the printer operator panel:
  1. Press Copy.
  2. Press Options until Maintenance appears on the display.
  3. Press the right arrow until Clean Cartridges appears on the display.
  4. Press Select. A nozzle page prints, forcing ink through the nozzles to clean the clogged nozzles.
  5. Print your document again to verify that your print quality has improved.
Using the Lexmark Solution Center:
  1. Click Start > Programs > Lexmark X6100 Series > Lexmark X6100 Series All-In-One Center.
  2. From the Maintenance tab, click Clean to fix horizontal streaks.
  3. Click Print. A nozzle page prints, forcing ink through the nozzles to clean the clogged nozzles.
  4. Print your document again to verify that your print quality has improved.
If the problem continues, try to insert a different known working cartridge or better yet replace it with a new genuine Lexmark cartridge.
Should the problem continue, please contact Lexmark Technical Support Center for additional assistance.
Oct 11, 2011 | Lexmark X6170 All-In-One InkJet Printer
Lexmark x6170 not printing magenta
  1. Press Copy.
If the problem continues, try to insert a different known working cartrdidge or better yet replace it with a new genuine Lexmark cartridge.
I have been having trouble printing my red. My letterhead contains a red "A" in it and a few other items have red. Normally, the red items have pink, yellow or white vertical streaks through...
Replace the magenta image unit. Yellow image unit also and for the white streaks have the glass that cover the laser cleaned.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jul 29, 2011 | Brother HL4040CDN Duplex Unit
It is leaving heavy blue streaks on everything printed
Hey, blue streaks could be a few different things. The first thing I would check is the image unit. Try swapping out the cyan(blue) image unit with another color, such as magenta. If the streaks change from cyan(blue) to magenta in color then you know the image unit is bad and must be replaced (part # 108R00581). If it is not the image unit then it most likely is the developer. The developer takes about 40 minutes to install and really should be done by a service technician.
Here is a video that shows you how to remove the image unit and where you can purchase one.. Just go to 57 seconds in the video. Hope this helps, good luck!
May 17, 2011 | Xerox Phaser 7750GX Laser Printer
Erreur 933.00 printed erreur
Error indicates that the mirror motor is locked, no first HSYNC received... which means no information was received from the printhead.
* Check printhead
* Check cables and connectors
* Check system board
Hope this helps
Apr 19, 2011 | Lexmark T640 Laser Printer
The color red is dull when printing
I assume you've checked magenta toner cartridge level, and tried cleaning.
If so, the next thing to do is try cleaning the scanner mirror. On these models the mirror nearest the magenta toner builds up dust the most quickly, hence why it is the first colour to fade on prints. Only use dry swabs (no solvents) and compressed clean air on the mirrors.
Nov 03, 2010 | HP Color LaserJet 2600n Printer
I am getting a 108.08 Printhead error message on my new C543dn. This error occurs as the printer is warming up/setting up. I have looked at Lexmark's website and the only thing I can find is to plug...
If it is a new printer call Lexmark, because this is a problem with the magenta printhead. To solve it you need to have some expertise on this printer.
Oct 18, 2010 | Lexmark C543DN Laser Printer
How to fix 108 service printhead error on c762 lexmark printer
Hello, Please try this: Power off the printer, take the Color cartridge out(Magenta), take a thin and dust-free cloth or tissue and clean the hysinc mirror and the printerhead lens. The hysinc mirror and printerhead lens is in the printer not on the magenta cartridge. Reinstall the print cartridge and power on. Try again to print this will help.
Mar 19, 2010 | Lexmark C762 Laser Printer
Service printhead error 108
Error Code(s) Printhead Color
106, 111, 115, 171, 172 Cyan
107, 112, 116, 173, 174 Magenta
108, 113, 117, 175, 176 Yellow
109, 110, 114, 169, 170 Black
Power off the printer, take the Magenta cartridge out, take a lint and dust-free cloth or tissue and clean the hysinc mirror and the printerhead lens. I just did it and it took me three minutes to clean with toilet paper rolled up like a cigarette.
My printer is back on line. The hysinc mirror and printerhead lens is in the printer not on the magenta cartridge. Reinstall the print cartridge and power on. This has happened to me before with a different color.
here is the Lexmark c750 support link:
http://support.lexmark.com
I hope this helps. - This is from Joey V on fixyourownprinter dot com
Oct 13, 2008 | Lexmark C752 Printer
Lexmark C752 108 Printhead error
They mean the respective printheads have lost the HSynch.  The first thing the we do (and have had great success with) is to clean the laser lenses.  Then check the head wiring.  The following codes apply:
106 & 110 CYAN 107 & 111 MAGENTA 108 & 112 YELLOW 109 & 113 BLACK
Jan 10, 2008 | Lexmark C752 Printer
Lexmark C760 Laser Printer Logo
142 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
