Question about Zanussi WJS1397W Front Load Washer / Dryer
Starting dryer When I press the start button it makes a humming sound. Sometimes it starts, and sometimes it don't. It's not starting hardly at all anymore. It's only started doing this about 5 loads ago.
  • 999dozer Dec 01, 2007
    The reason I marked inappropriate, because that wasn't the correct machine. I was asking about the Matag Neptune electric dryer. I resubmitted my question and was told the motor was going out. I haven't had a chance to check it yet, but I did get a quick response to my question. Thank you so much for your help!
    999dozer
    Champion:
  • 249 Answers
THE HUMMING IS THE WATER VALVE WHICH IS OK,CHECK WATER PRESURE AND FILTERS IT MAY BE DOOR INTERLOCK
Posted on Nov 28, 2007
  • eamonn close Dec 01, 2007
    It could easy be the motor 'condensur' it gives a higher voltage to the motor if its faulty the motor won't start .close Ire good luck
Why does it stop in the middle of a cycle?
Could be a dirty/defective dryness sensor
Dec 01, 2015 | Dryers
I have a maytag dryer that sometimes when I hit the start button will start and run for only a few minutes and stop and wont start again for a while and does a humming noise when it does star why?
Sounds like the motor is going into thermal overload (Getting hot) it may be caused by the motor itself, or could be overloaded by bearings or fan etc
Jul 28, 2014 | Maytag Dryers
Dryer sometimes works and sometimes doesn't, what's the problem?
i have a feeling that it's a fault in the power chord, take it out and double check. it would make sense if it only work now and then after you have plugged it back in because it could have made the wires touch again to make it work
Jun 29, 2014 | Whirlpool Washing Machines
Dryer hit start button and it hums
sounds like a motor is going bad or you have a sock in the blower fan but if it was a sock, it wouldn't work at all
Feb 12, 2013 | LG Dryers
I have a kenmore 90 gas dryer modal # 110-77904792, the dryer gets power but wont start when you push the power button, it makes a humming sound?
possible could be the drum motor depending on type of hum. if a motor is trying to start sometimes will make that sound
Feb 09, 2012 | Kenmore Dryers
When the button is pressed to start the dryer it begins to hum as iff the drum is stuck. It does this for about 5 to 10 seconds then shuts off. If I attempt to start it again nothing happens. sound like...
If you hear the motor humming and not starting at all it most likely has a severe friction problem with the drum or motor. It could possibly have some type of garment jamming the blower wheel preventing the motor from starting too.
Open the dryer door and manually rotate the dryer drum counter clockwise (CCW). It should take very little effort to rotate the drum. If it's hard to rotate that could explain why the motor hums instead of starting up. If it turns freely, shut the door and see if will start. If it still hums and not start it may have bad motor or a low voltage supply to the motor.
Apr 17, 2011 | Whirlpool LER7646E Dryer
Dryer Start Button is not Working
sounds like the board may be faulty
Oct 24, 2008 | Dryers
Starting dryer
you need to replace the motor
Dec 17, 2007 | Dryers
Starting dryer
the motor needs to be replaced. the bearing are going bad and they are only sold as the whole motor
Nov 28, 2007 | Dryers
Zanussi WJS1397W Front Load Washer / Dryer Logo
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
