Question about HP OfficeJet 6210 All-In-One InkJet Printer
Remove and check right cartridge
I have opened it up and taken out both cartriges and put them back in and hi ok and the flashing exclaimation will not go away.
  • 1 more comment
  • gigcyth Nov 27, 2007
    did that.. still flashing excalimation.. now what
  • cadieuxs Dec 13, 2008
    Try to clean it and that didn't work. Now what?
  • threeshseets Dec 20, 2008
    Same problem - no solution??
    Renaissance:
    An user who is expert in 3 categories / brands.
  • HP Master
  • 1,362 Answers
Try cleaning the contacts where the cartridge goes.
good luck
Posted on Dec 12, 2007
On my samsung fax sf5100 machine there has been a new ink cartridge installe dand the machine is still asking to insatll new cartridge , do i need to tell the machine new cartridge installed if so how
you will see there is a fuse on the cartridge. replace it with a new one. it can be biger becouse you will remove it again.
put the cartrige back with other fuse and close door for 3 secons. take cartridge out and remove the fuse.
put cartrige back with out the fuse. it sould work.
the other way is to push setup and then # 1934.
push setup again check for new cartrige or egnore cartrige.
swich m/c off and on.
Aug 10, 2011 | Samsung SF-5100 Plain Paper Laser Fax
Hp officejet j3500- refer to device documentation to troubleshoot
problem with any one of your cartrides. open the carridge door and renove color cartridge and close it.if it says insert left cartridge then it could be the problem with color cartrige.or the same error come then put the color cartridge and remove the block cartrige.if display says insert right cartridge then it could br the problem with black cartridge.try clesn the cartridge contacts & ink nozzles and put it back (use a soft cloth to clean the cotact)
Aug 04, 2011 | HP Office Equipment & Supplies
Remove and replace ink cartrige
  1. Write down the printer name and brand.
  2. Remove the empty cartridge and check the writing on it. If it has any bold and big numbers on it, write these down.
  3. Go to office supply store and give the clerk your notes.
  4. Make sure you get the right one and take it home.
  5. Check to be sure your printer is on.
  6. Open your printer's lid.
  7. Take out the old cartridge and put inside a small ziploc if you want to.
  8. Dispose of the old cartridge. Or if possible, have the cartridge recycled.
  9. Unpack new cartridge and place inside the printer.
  10. Print a test page.
  11. Reconfigure printer heads for best quality.
May 22, 2009 | Dell 810 All-In-One InkJet Printer
Just had cartridge refilled,printer says its still empty,and wont print. help!!
take it back to the refilling agent and report the error, I think some cartriges have a chip which needs to be reset.
Oct 06, 2008 | Dell 924 All-in-One InkJet Printer
Remove and check cartridge keeps flashing, wont stop flashing, even after in remove cartriges and replace them
I've found out what was wrong. My cartridges expired. HP has put a "limit" on how long your cartridges last. They do this to try to prevent refilling. Cartridges typically last for a little less than two years after the expiry date listed on them.
You can fix this (as I did) by buying a couple of new cartridges # 56 and #57. They sell them together in the same pack for 50-something bucks in Walmart.
Hope this helps.
Sep 04, 2008 | HP PSC 2175 All-In-One InkJet Printer
My hp photosmart 2575 says 'ink cartridge problem, remove and check cartridge on right. Refer to printer documentation
open the front cover the cartriges will come in the centre position where you can remove the cartridges check which cartridge is on your right side remove and clean the brown dotted circuit on both the printer and cartridge with the tissue paper .insert it back in the proper position and then check if the same problem then remove and replace the cartride printer will work properly.thanks
Aug 14, 2008 | HP Office Equipment & Supplies
Printer says right cartrige is incorrect
remove the cartridges and reinstall them back, turn the printer off , if that does not work, did you use a new original cartridge or a recycled cartridge ?, either way will trick the printer into the new cartridges, i, hope this solves the problem good luck.
Jun 01, 2008 | Dell 922 All-In-One InkJet Printer
CANON FAX JX200
remove the cartridge and see if it goes away, if does then you probably have a defective cartridge are are not inserting it correctly.
Thank You,
Mikey
Apr 04, 2008 | Canon FAX-JX200
HP OfficeJet 6210 All-In-One InkJet Printer Logo
154 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
