Question about Samsung RS2630SH Side by Side Refrigerator
Samsung RB2055Sl Top refrigerator couling coil freezing up every 2 or 3 weeks
I have a RB2055SL
The top refrigerating coil is freezing up ,then the air from the fan will not flow thrue the coil and the refrigerator temp goes up to 10.
The auto defrost does not seem to be working.
  • Anonymous Sep 10, 2008
    I have the same problem. I wonder if there is a problem with this modle?
  • 833 Answers
The problem is freeze up. Bad door gasket or too much window shopping are the biggest issues. Could be low gas. Either take off the back freezer panel and defrost or unplug for 2 days to defrost fully. Oh, and clean the condenser coil. Then, let's see what the unit does.
Posted on Dec 19, 2007
Samsung rb2055sl running warm 55 degrees in refrigerator and 70 degrees in freezer fan is working no ice, way to warm
Is there a clicking noise? Feel the compressor to see if too hot to keep your hand on top. Look ate the frost pattern in rear of the freezer compartment and tell me the results. Several things could be causing the compressor to get hot and not run. Freon leak is one thing that could happen and defective start relay, overload and run capacitor is another. You could also have a defective cooling fan under fridge or inside the freezer compartment
Sep 18, 2016 | Samsung Refrigerators
Why freezer part is not working on my samsung rb2055sl
The most common part to replace is the timer motor. It's usually located on the back bottom of fridge, It's a little thingy about 1 1/2 " in diameter. One screw will usually get it loose where you can take a look at it better to see if it's turning. It has a small window where you can see a little wheel turning.
Sep 05, 2014 | Samsung RF265AA Bottom Freezer French Door...
Rb1855sw / rb1855sl -- rb2055sw / rb2055sl --- the frig temp is rising and so is freezer. There is a signal beeping behind the frig. No idea what it is
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
Jul 19, 2011 | Samsung RB2155 Bottom Freezer Refrigerator
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in efrigerator from Freezer
Aug 18, 2010 | LG Refrigerators
I need the part number of the door switch of my Samsung Regrig. Model# RB2055SL
Hello there:
here is the number that you are refering to
Door Switch DA34-00006C ok?
best regards michael
Oct 08, 2009 | Samsung RB2155SH Bottom Freezer...
Freezer side not freezing
Turn off the refrigerator.Remove the freezer shelves/bins and rear panel.
Take a hair dyer and thaw the ice completely. The defrost heater will be across the bottom of the freezer coil. The defrost thermostat will be attached to a refrigerant coil at the top of the freezer coil.It is about the size of a quarter and 1/2 inch thick.There will be wires from top to bottom on the sides of the coil.
May 25, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Samsung RS253BASB leak at bottom veggie drawer
I had the same problem. I called tech support and they were no help. Being a handy man I dove into the problem myself and discovered the problem. If you want this solution, I have pictures and information. Simply email and I will send you this infomation.
Jun 07, 2008 | Frigidaire FRT15G4B Top Freezer...
Kenmore Refrigerator-Freezer top
install a defrost drain tube heater call sears for a part number have the model handy befor calling
Apr 21, 2008 | Kenmore 64254 / 64252 / 64259 Top Freezer...
Samsung RS2630SH Side by Side Refrigerator Logo
415 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
