Question about Nikon N65 35mm SLR Camera
Flash How do I take off the automatic flash so that the attated flash will work?
    Problem Solver:
  • 8 Answers
You can't take off the attached flash. The camera body flash should not fire when you have a flash attached to the hotshoe on the camera. I don't know what kind of flash you are using, since you never said but I use Sunpak and Metz flashes. You can see if your flash is compatible with the N-65. If not, then you should look for one that is. Ritz sells Quantary flash units that have modules for Nikon cameras. They are great flashes for the money.
Posted on Dec 20, 2008
Canon sx 150
Hi
1. The flash on this model Canon works only if you manually raise the flash. It does not rise automatically, and is only on the raised flash.
2. Flash on the module has a switch - it sometimes fails and then flash "does not understand" that she had to get involved.
3. Not working flash capacitor charging circuit - usually after any water
4. Flash lamp is not working - usually after a light blow
5. Command does not work (a piece circuit) from the processor to light the lamp flashes - after a blow or hit the water.
If you follow steps 1 - Raise the flash and the camera is turned on in the menu mode - "shoot with the flash" - but your flash does not work - the rest can fix broken only engineer to repair.
Oct 23, 2012 | Canon Powershot Sx150 Is 14.1 Mp black...
DOES THIS FLASH WORK ON CANON REBEL XSI?
Yes and no. It will work fine as a manual flash, putting the burden of figuring out correct exposure on your shoulders. It will work fine in the automatic modes on a Nikon camera.
Quantaray makes a Canon version of the flash which will work in the automatic modes on the Rebel XSi.
Jul 27, 2010 | Quantaray PZ-1 DSZ for Nikon TTL Flash
Auto flash wont work
did it pop up automatically or did you pop it manually? if it popped up by itself then the flash unfortunately is probably dead, since on automatic, it won't pop unless it's going to fire. If you popped it manually then - the camera doesn't think that the flash is necessary for the conditions that you're shooting in.
Oct 21, 2009 | Nikon Cameras
Flash won't open on Canon Rebel XSi? It has been working fine but yesterday I went to take a picture and the flash wouldn't open. It won't open on any setting and it won't open if I push the manual flash...
The openning flash button only works on non automatic shooting modes.
On creative zone (automatic options with predefined options) the flash will rise automatically, based on the current exposure conditions. On "Flash Off" mode won't rise the flash ever.
Let me know, please if it solve the problem
Jul 10, 2009 | Canon EOS Rebel XSi Digital Camera
I have a canon rebel xti with an 18 to 55 lens .. I recently bought an external flash to sit in the hot shoe .. now when I removed the flash from the hot shoe .. the cameras own flash will not pop up and...
I had the same problem.
Look closely at the hotshoe. Inside it, way over to the side, under one of the tabs on the side, is a tiny metal strip. When you attach an external flash, the strip is pushed down and holds down a tiny button that deactivated the pop-up flash. The strip can get bent so that it doesn't let the button come up even when the external flash is removed.
Very gently take a fingernail or a jeweler's screwdriver and run it underneath the metal strip. I had to do it a couple of times to get mine working again, but it's working great now!
Dec 30, 2008 | Canon EOS 400D / Rebel XTi Digital Camera...
Flash button won't work
have you checked your settings so the flash is on automatic?
Jul 05, 2008 | Olympus Stylus 760 Digital Camera
SB-600 Flash not working
Make sure both camera and flash are set to TTL automatic mode. One time this happened to me and I had forgotten to lock the flash to the hotshoe connector.
May 10, 2008 | Nikon Speedlight SB-600 TTL Flash
External Flash can't fix
Its becoz that flash is not compitable with your camera. You should buy only flash that are compitable with your camera.
Nov 16, 2007 | Konica Minolta DiMAGE Z3 Digital Camera
Automatic flash problems
I have the same problem as Irichard, in that the flash won't pop up automatically, the camera wont work when you pop it up manually all all modes that allow flash photography do not work.
Nov 01, 2007 | Canon EOS Rebel Ti / 300V 35mm SLR Camera
Flash Problem
Using the flash When shooting with the built-in flash, open the flash manually. The flash does not pop-up automatically. The flash will not fire if it is closed. The flash will work when it is opened up. When the flash is open, the (flash on) icon or (automatic) icon will appear on the LCD monitor (or in the viewfinder). Flash on: The flash fires in every shot. Automatic: The flash fires automatically. Press the (flash) button to switch between the and flash modes while the flash is open. In some shooting modes, the flash mode does not switch even if the flash button is pressed. Please refer to Functions Available in Each Shooting Mode in the Camera User Guide provided with your camera for more information. When you are not using the flash, close it manually. When the flash is closed, the flash will not fire and the icon appears on the LCD monitor (or in the viewfinder).
Aug 31, 2005 | Canon PowerShot S2 IS Digital Camera
Nikon N65 35mm SLR Camera Logo
97 people viewed this question
Top Nikon Photography Experts
pontelemon
pontelemon
michael galang
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Nikon Photography Expert? Answer questions, earn points and help others
