Question about Toshiba 51H83 51" Rear Projection HDTV-Ready Television
Convergence ic needs to be replaced. Where do I find a part number?
Where do I find a part number for the convergence ic? (Blue) Thank you!
  • bowlinfool Nov 27, 2007
    Step by step directions for replacing this part will also be helpful! I'm getting greedy now! Thanks!
    President:
  • 4,402 Answers
Http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Posted on Dec 05, 2007
Convergence red blue green
Have You replaced the convergence ICs Yet? They are Big Black ICs and will have part number on them .
example STK392-110
Mats Electronics has ICs 1-800-628-1118
Jul 25, 2011 | JVC AV-56WP30 56" Rear Projection...
Blue will not adjust in the cross hairs. red does just fine. all three color bulbs in the back seem to be fine and are on and I can adjust them with the "adjusters" just under the bulbs. the blue can be...
Hello:
The problem you are having is your blue convergence IC has failed, It must be replaced if you can solder and unsolder you can do this yourself, the parts are large black IC's mounted on large metal Heatsinks.
Note: If the blue convergence Ic has failed then it would be wise to also replace the IC that controls the Red and Green, because if may be not long before it fails also. There are two Ic's that control the convergence one for Blue and one for Red and Green together. The part number for the Ic's are STK-392-110, replace with STK-392-120 for longer life.
Dec 21, 2009 | Philips Magnavox 9P6034C 60" Rear...
My projection screen has blue and green lines across the screen id do not know how to converge the lines akai screen where do i go to fix it
Hi, thank you for visiti fix ya.
Your tv need convergence ICs service ( replace).
Can you send me model number tv, please?.
Thank you
Jul 25, 2009 | Televison & Video
Our TV (Mitsubishi WS65711) is 6 years old, and has recently started showing a blue ghost image on everything. It stopped for a while for a week or two, but started back up, and has continued ever since. I...
You have convergence problem in your tv as your local repair shop told you. You need to replace convergence IC . YOu can get from the link below .
Convergence IC can be obtained from the link
You need to replace both convergence ICs .It will cost you around $30
If you can replace it by yourself . If you take to repair shop they will charge you around $200 for this job. .
The IC number is STK393-110 .
You can get some idea on how to replace convergence IC from the link below
http://www.fixya.com/support/r704766-convergence_solutions
Hope this helps .
Feb 19, 2009 | Mitsubishi WS-65511 65" Rear Projection...
Blue Convergence on Toshiba 42H82 42-Inch
it should just need new STK392-110 ICs which is actually not very difficult. You will need two ICs both STK392-110 and you can get replacements at the following link and they provide instructions on how to remove and replace Convergence ICs.
Heres the link.
http://servicemanuals.vstore.ca/
Oct 22, 2008 | Televison & Video
Convvergence problem w/ Toshiba 50H82
You need to replace following ICs, may be 2 pieces in your tv for convergence problem.
IC, STK392-110T
Toshiba Part Number: 23135090X
Please search on net for availability in part stores
Sep 27, 2008 | Toshiba 50H82 50" Rear Projection...
Blue gohst image
need your model number sounds like the convergence ICs need replacing. post the model number and I will post the correct ICs for your model and post a link where you can get replacement ICs with free instaltion instructions.
May 26, 2008 | Televison & Video
Blue Convergence Problems
You will need to replace the conversion IC that controls the blue STK392-110 or STK392-120 however these are so cheap I recommend replacing both as the red wont last much longer. As they usually wear out around the same time. Heres a link where you can buy the replacement ICs and they include step by step instructions on how to install the new ICs.
Mar 29, 2008 | Philips 43P8341 43" Rear Projection...
PT-47WX53 blue convergence
you will need to change or have the convergence IC's replaced I'm afraid. Good Luck
Aug 15, 2007 | Panasonic PT-47WX53 47" Rear Projection...
Toshiba 51H83 51" Rear Projection HDTV-Ready Television Logo
63 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
