Question about HP PhotoSmart 7550 InkJet Printer
Cartridge cradle is stuck
How do you clear the cartridge cradle jam, it is stuck at the right side of the printer?
  • 5 more comments
  • Maidz Dec 01, 2007
    The control panel shows the words "clear jam then press ok" then "print cartridge cradle is stuck" with blinking yellow light on print button
  • durphman Dec 07, 2007
    My problem is simular to others here regarding stuck cradle. Mine is stuck at left side with same error telling me to clear jam and press ok. Due to left side position I can't get in to remove cartridges or see what's holding the cradle to the left. This problem started out intermittantly and is now a solid failure.
  • tjvw79 Aug 12, 2008
    my print cartridge is stuck on the left side and the error message print cartridge stuck is displayed when I looked inside the printer I noticed that the middle print cradles blue thing to secure the print cartridge had come open and it is stuck in the up position. I am not sure if I should take the cover off the printer or not.
  • Jami Godshall Jan 05, 2009
    I have the same problem as others with my PhotoSmart 7550. The print cartridge is jammed on the left hand side. I can see the proposed solution but I can't figure out how I would take off the top cover. I'm not seeing any way to pull it off. Anybody know how to get it off?
    Thanks!
  • Anonymous Feb 15, 2009
    My printer cartridge seems to be stuck because the door holding the cartridge is popped open and I can't reach it since it is far to the laft position. How do I open the entire unit from the top to close the door or remove the cartridges?
  • Anonymous Mar 21, 2014
    receiving a flashing signal Error 0x07a74dd6
  • Anonymous Mar 24, 2014
    print cartridge cradle stuck
I have had this problem with my 7550 for a while now and I finally found this on the HP website and it seems to have fixed my problem, I also replaced all of the cartridges:
Issue While printing from an HP Photosmart printer, the printer screen displays Print cartridge cradle is stuck / clear jam and then press OK . The printer may also make grinding sounds. This can occur after a paper jam when another printer part blocks the cradle. Solution Follow these instructions to adjust the clutch on the printer.
  1. Disconnect the USB cable.
  2. Press the printer power button to turn off the printer.
  3. Disconnect the power cord from the back of the printer.
  4. Open the top cover of the printer.
  5. Remove the print cartridges from the printer.
  6. Slide the cradle to the right side of the printer.
  7. Locate the clutch on the left side of the printer.
    NOTE: The clutch is a flat, white, plastic component that rests just above the white roller gear wheel. In the HP Photosmart P1000 and P1100 printers, the clutch is black metal. Figure 1: Printer clutch cartridge cradle is stuck - c00020494.jpg
  8. Remove the rear access door from the back of the printer.
  9. Press the clutch firmly towards the back of the printer, while rolling the wheels in the back of the printer upward two full rotations.
  10. Release the clutch and roll the wheels up two more rotations.
  11. Reinstall the rear access door.
  12. Reinstall the print cartridges and secure the latches in place.
  13. Close the top cover and reconnect the power cord.
  14. Turn on the printer.
  15. Print a test page.
Posted on Dec 31, 2007
There are some great solutions I have read here. Recently I started receiving the 'stuck cradle' error message on my HP 7550 and was about to give up and trash it. I decided to take the entire top cover off and found that the 58 cartridge door was open. This prevented the carriage from sliding to the right and also caused the error message. I then reassembled the printer and it is working as before. If you decide to remove the top casing be sure to remove the control panel first. There is a pin and two ribbon connectors to disconnect. Something I didn't do first. Good luck.
Posted on Sep 04, 2012
5 Suggested Answers
dahaka
  • 347 Answers
SOURCE: cartridge cradle is stuck
Hi KHphoto, you can see this steps to fix your printer jam,
    NOTE: The clutch is a flat, white, plastic component that rests just above the white roller gear wheel. In the HP Photosmart P1000 and P1100 printers, the clutch is black metal. Figure 1: Printer clutch c00020494.jpg
original post*
If you are still having problems let me know.
Posted on Jan 03, 2008
myob247
  • 1342 Answers
SOURCE: HP8250 printer
Try this: Remove both ink cartridges. Unplug the printer for a few minutes. Plug it back in and re-install the cartridges.
Posted on Jun 26, 2008
  • 523 Answers
SOURCE: printer keep saying print cartridge cradel is stuck and clear jam, but there is no jam.
check the sensor , either there is somthing stucking on the sensor you cannot see it, either the sensor it self becomes bad.
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
Posted on Apr 17, 2009
pineworks
  • 4041 Answers
SOURCE: Printer cartridge cradle is stuck.
Hi ok sorry to heer but try I found this I know your error not in here but it may work for It worth a try nothing to lose and it may work. I know your error code is not in this but it some times it clean the error with this type of error number you can gave it a go try not harm it Error code: 0xc18a0201, 0xc18a0206, 0xc18a0306, 0xc18a030a, 0xd0620130, 0x887dd03a, 0xd05d010d, 0xf0af8004, 0xc19ac3ff, 0xc18a050...
Reset the product:
1. Without turning off the product, disconnect the USB cable from the rear of the product.
2. Remove the cartridges from the product.
3. Wait for the 'Insert Cartridges ' message to display on the control panel.
4. Disconnect the power cord from the back of the product.
5. Wait 60 seconds.
6. Reconnect the power cord. If the product does not automatically turn on, press the Power button ( ).
7. Reinsert the cartridges, and then close any open doors on the product.
8. If you receive a prompt to print a calibration page, do so.
9. Reconnect the USB cable to the rear of the product, and then try printing again.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 08, 2010
My printer keeps saying print cartridge cradle is stuck clear jam then press ok, but there is no paper jam
Because it's NOT a paper jam, but a cartridge cradle jam, I suppose it's an ink jet printer??? if so, check for debrie arround the cradle shaft that could prevent the printing cradle to move from left to wright... you could also lubricate the shaft by rubbing a little bit of grease on it with the tip of your finger (verry thin layer), as ink sometimes gets on it and tends to become sticky with time...
Aug 10, 2011 | HP Office Equipment & Supplies
original post*
Jan 03, 2008 | HP PhotoSmart 7550 InkJet Printer
Print Cartridge stuck
Look at the pad on the right side of the printer under where the ink cartridges are loaded. It may have ink deposits built up into lumps which interfere with the movement of the cartidges on the rod. Clean the deposits by scraping the lumps and removing all debris. This worked for me.
Jan 23, 2010 | HP PhotoSmart 7550 InkJet Printer
Paper cartrige cradle is stuck.
print cartrige cradle is stuck clear jam then press ok in hpphotosmart 7550
Sep 08, 2009 | HP Photosmart 8150 InkJet Printer
Printer keep saying print cartridge cradel is stuck and clear jam, but there is no jam.
Apr 17, 2009 | Office Equipment & Supplies
HP8250 printer
Jun 26, 2008 | Office Equipment & Supplies
Print cartridge cradle is stuck ican't find where it is jammed
This might help . . . Mine finished printing one doc & then made a terrible noise & sent a message to my screen that "print cartridge cradle is stuck." When i opened door, i could see it was stuck off to the left side so left cartridge was obscured. I could not get it to budge, although i kept turning it off, gently pushing & turning it back on. Finally, i got my hand inside & determined that the little door to the left-side cartridge had popped open & was causing it to remain stuck. After some struggles (turn off printer first!) i was able to maneuver it around & close it tight. Now, all is well . . .
Apr 16, 2008 | HP Office Equipment & Supplies
Print cartridge cradle stuck there was a paper jam. That was cleared, but now it says the cradle is stuck and the paper does not feed please help print cartridge cradle will not move
Hi, I have a HP Photosmart 8050. Runs good till Now. 1, ONE Sheet of paper Jamed. THe RED Light Keeps Blinking Like crazzzy. I unhooked it to re-boot. It says Print Cartridge Cradle is stuck. Clear Jam & press OK. Iv'e L@@KED 4 anything. Nothing in way. I took the ONE sheet out. Still Nothing. It's Like my X-wife. 1 item wrong and a Bunch of ****. New Ink. Got Milk. Oh wrong Commercial. Got Fix. Retired Handi-capped sanior, Ron
Mar 17, 2008 | HP Photosmart 2575 All-In-One Printer,...
There seems to be a problem with the cradle not "lifting" itself up and over what appears to be some sort of guide. Rock the cradle gently back by hand (it will only move a few millimeters) and move it all the way to the right into its bay. Cycle the printer power and it should be fine.
Mar 03, 2008 | HP PhotoSmart 7260 InkJet Printer
HP 7660 "Print Cartridge Cradle is Stuck" Message
I was having same problem but it was a paper jam all the time and then it started to state Cairrage Jam. And what was happening was the unit the cartridges sit in was not going all the way to the right. A little nudge and you could feel it move. Closed lid and sometimes it would print but eventually it would fail. Just replaced but I suspect if you can get to the cairrage you could clean/repair whatever was keeping it from going all the way to the right.
Hope that helps!
Dec 18, 2007 | HP Photosmart 7660v InkJet Printer
HP PhotoSmart 7550 InkJet Printer Logo
3,279 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
