FixYa.com
Tags:
Jenn-Air 24 in. JDB1090AWS Stainless Steel Built-in Dishwasher
Start button will not work (by 3 users)
posted by scedarst on Nov 27, 2007
All the other buttons work except the start button!
Comment by scedarst, posted on Nov 28, 2007
The button will not come on. All other buttons work. I have turned the power off at the breaker for 30 min and still nothing. I cant run a diag test because you need the start button!
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Comment by Guest, posted on Jun 11, 2008
Same problem. A repair man said we need a new control board.
Comment by grainguy, posted on Jan 01, 2008
Just outside warrentee the door handle became loose on one side... simple right? I took off the front panel to figure out how to get to the handle bolts and fugured out I need to go thru the front panel (stainless side). Easy.. yes. I tightened the door handle and put it back together. Now, none of the buttons work.
I did not event touch the electrical components and I am frustrated. Help!
Best Solution
Thanks for Trying (70)
close
Rank:Wiz Wiz
Rating: 82%, 175 votes
do you mean it will not press in ???
Comment by close, posted on Nov 28, 2007
in that case it could be door switch ,try it with door open and see is it the same
Rating Locked! (?) scedarst has rated this solution as Thanks for Trying
Can you Help with these Dishwashers problems?
Jenn-Air 24 in. JDB1090AWS Stainless Steel...
Door
How do you get the door apart... Answer This...
all of a sudden very noisy
All of a sudden the diswasher... Answer This...
Door sticks; soap doesn't...
Periodically, the soap... Answer This...
Service Manual
I have the same problem. Almost... Answer This...
Jenn-Air Dishwasher JDB1090AWS
Washer has no power. Electrical... Answer This...
Repair Service
Find Dishwasher Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
