Aiwa HS-TX426 Personal Cassette Player Logo
Posted on Aug 08, 2009
Have Aiwa NSX-V9090 Stereo with jammed cassette. I removed the cassette; however the system still thinks it's in there? When I power up the system it tries to play the tape the stops. I am not able to load or play cassettes. Any ideas?
davetech48
Level 1:
  • Contributor 63 Answers
  • Posted on Aug 19, 2009
davetech48
Contributor
Level 1:
Answers
63
Questions
Helped
23513
Points
93
Check with a small torch, to ensure that there is no tape broken arround the pinch roller or head, if there was no tape broken away, between the pinch roller and the cassette head there is a white cassette bar, this may have become bent.
Where can i get a owners manual for an AIWA home stereo system model number cx-nma845?
ManualsLib has the manual here: https://www.manualslib.com/products/Aiwa-Cx-Nma845-5886493.html . SearsPartsDirect also has the manual here: https://www.searspartsdirect.com/manual/1m0bt3vgnd-001547/aiwa-nsx-ma845-compact-stereo-system-parts . Note: the system model number is NSX-MA845; this includes the front, center and surround speakers. The CD stereo cassette receiver is CX-NMA845.
I hope this helps.
My Aiwa NSX-AJ310 has no remote control. Which one do I need to buy to play cassettes
yes,Abctay.com is a samsung tv parts online store ,and include ORIGINAL SAMSUNG BN44-00428A POWER SUPPLY / LED BOARD FOR UN55D7000LFXZA
2answers
My aiwa nsx kt9 system is not powering on
Find out, where the Fuses are ? if outer power source is okay,some fuses are hidden under some cover or inside the box .Replace fuse with the same value if found burnt.
Aiwa NSX-A-J800 Manual
Retrevo has the manual for the Aiwa NSX-AJ800 Stereo System here: http://www.retrevo.com/support/Aiwa-NSX-AJ800-manual/id/1076dj383/t/2/ . You will need to enter a code to download the pdf.
I hope this helps.
(note you will need Adobe Reader or a similar program to read the file)
2answers
I have a nsx-9000 cassette deck will not play.
Make a note of how the belt fits, then remove it and measure the diameter. Then buy a replacement, belts do go bad from time to time, so a new one might cure the problem. Put the diameter size (to the nearest mm result, IE: 50 or 55mm, not 52mm! Into google and "cassette belt" and you should find one for the job.
1helpful
3answers
Aiwa nsx v900
did you check on speaker wires? Red is +Positive, Black is -Negatives....
3helpful
3answers
I NEED A MANUAL FOR AN AIWA STEREO BOOKSHELF SURROUND SOUND SYSTEM CX_NHMA86
Click Sony-Aiwa Support to download instruction manual of NSX-HMA86 (CX-NHMA86) stereo system.
Cassette door stuck closed
Firstly: do not think about forcing the cassette door! Look inside the unit. You need to hand rotate the capstan flywheel a bit,( a large-ish metal disc attached to the motor via a rubber drive belt.)That should release the powered deck mechanism and allow ejection. Then buy a new drive belt , so that problem does not recurr. Good Luck
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Mohammad Abumuailek
Mohammad Abumuailek
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
